apiVersion string No API v1.7: the currently connected Indigo Server plugin API version as a string (ex: "1.7")
/ |portNum| integer | No |the port number of the currently connected Indigo Server / / |connectionGood| boolean | No |true if the connection to the Indigo Server is currently good| /
License Status Enumeration
Value Description
*ActiveSubscription* license has an active Indigo Up-to-Date subscription (access to a reflector)
Calculate Sunrise
direct parameter No datetime.date a *datetime.date* object representing the day to calculate the sunrise time for
Calculate Sunset
Event Log List
Get Database File Name
Get Database File Path
Get Install Folder Path
Get Latitude and Longitude
| Command Syntax Examples | | --- | | python latLong=indigo.server.getLatitudeAndLongitude() lat = latLong[0] long = latLong[1] |
Get Plugin
direct parameter Yes string the id of the plugin to retrieve
Get Plugin List
Get Reflector URL
Get Serial Ports
filter No string currently there’s only one valid filter: "indigo.ignoreBluetooth" which will remove the "Bluetooth-PDA-Sync" option from the list
for posixPath in ports:
    print(posixPath)
    print(uiName)
# iterate through both
    print(posixPath)
    print(uiName)
Get Time
indigo.server.getTime()
No Parameters
Get Web Server URL
  1. Reflector (*%%https:*reflector.indigodomo.net%%//) if a reflector is configured.
  2. Bonjour name (*%%http:*MacName.local:PORT%%//) if it can be determined.
  3. Localhost (*%%http:*localhost:PORT%%//) if all else fails.
No Parameters
Log
*type* No string a string representing the type - if it’s not included and is run from a Server Plugin, the name of the plugin will automatically be used
*isError* No boolean if *True*, it will show up in red in the event log - default is *False* - if no *type* is included, the name of the plugin will automatically be used with " Error" appended
Remove All Delayed Actions
Send Email
This tells IndigoServer to send an email using the SMTP settings configured in the preferences "Email" tab.
*subject* No string the subject of the email
*body* No string the body of the email
Speak
*waitUntilDone* No boolean should the method call block until speaking is complete or should it just return immediately (queue up the speech)
