Indigo Server Plugin Tutorial
Note most of the code examples below are calling methods on the object self. In this context, self is meant to be the Plugin instance as defined inside the plugin.py file. To execute the sample code outside Plugin instance methods use the indigo.activePlugin object instead.
Important: For simplicity some of the samples below specify objects based on name ("office desk lamp"). However, the preferred lookup mechanism is to use the object's ID which can be retrieved by control-clicking on the object name in Indigo's Main Window. By using the ID you ensure the object will be found even if its name is changed.
Plugin task Plugin that illustrates an approach
Parsing XML from an IP source NOAA Weather, WeatherSnoop
Interacting with an IMAP mail server iCal Alarm Processor
Creating custom devices with states Simple: NOAA Weather, WeatherSnoop - Complex: EasyDAQ, iTunes
Creating custom actions Growl, Action Collection
Each of these plugins is installed by default with Indigo - in the /Library/Application Support/Perceptive Automation/Indigo [VERSION]/Plugins (Disabled)/ folder. To see the various XML and python source files, just right-click on it in the Finder and select Show Package Contents.
  • Per plugin prefs file is automatically managed (created, loaded, updated).
  • Key values defined in PluginConfig.xml are automatically mapped into the plugin's prefs space which is available via:text self.pluginPrefs["somePrefKey"] or, if you're not sure the key exists:self.pluginPrefs.get("somePrefKey", "default value if key doesn't exist") The latter will return the second parameter if they key doesn't exist in the dictionary - it's your responsibility to add it to the prefs dict if you want it to be stored permanently.
  • Plugin can also insert other values into its pluginPrefs space (not just values shown in the plugin's config UI).
  • To read a preference value access its key:```python someVal = self.pluginPrefs["somePrefKey"] indigo.server.log("value is " + str(someVal))
- To create a new or update an existing preference value assign it a new value:```text
  • Example adding new plugin metadata to the Device "den fixture":```python dev = indigo.devices["den fixture"] newProps = dev.pluginProps newProps["onCycles"] = 5 newProps["moreData1"] = "abc" newProps["moreData2"] = True newProps["moreData3"] = 123.45 dev.replacePluginPropsOnServer(newProps)
- Example reading the plugin specific property onCycles from the Device "den fixture":```python
  • Example incrementing by 1 the plugin specific property onCycles for the Device "den fixture":```python dev = indigo.devices["den fixture"] newProps = dev.pluginProps newProps["onCycles"] += 1 dev.replacePluginPropsOnServer(newProps)
dev = indigo.devices["den fixture"] onCycles = dev.pluginProps["onCycles"] indigo.server.log("onCycles is now " + str(onCycles))
- Plugins have read-only access to other plugin metadata via *`.globalProps`*.
- Plugins have read/write access to their own metadata space.
## Creating a Custom Plugin Device
- Properties define the user configurable options for a device instance, and are specified in the *`<ConfigUI>`* XML node. Every field *`id`* is automatically mapped into the device instance *`.pluginProps`* metadata dictionary (described above) as a unique key.
- States are specified in the Devices.xml *`<States>`* XML node, and are used to define the transient state information for a device (ex: on/off setting, brightness, temperature, etc.).
- States defined in Devices.xml are automatically shown in the Trigger Event `*Device State Changed*` options when that plugin device type is selected, and are automatically shown in the Control Page editor when a control is created inspecting that plugin device.
- States are read-only for everyone except the plugin that defines the device's states.
- Plugins should update a device state after it has sent commands to hardware, or somehow received new state information from hardware. Example that increments the plugin defined state `*heatSetPoint*` by 1:```python
  • Plugins should subclass *deviceStartComm* and *deviceStopComm* to start/stop any hardware communication (normally via a new per-device thread):```python def deviceStartComm(self, dev): self.easydaq.startCommThread(dev)
def deviceStopComm(self, dev): self.easydaq.stopCommThread(dev) `` - Calls todeviceStartCommanddeviceStopCommare automatically managed by the Indigo Server and Indigo Plugin Host. When a plugin first connects all enabled device instances owned by the plugin will receivedeviceStartCommcalls. Likewise,deviceStartCommis called when a new plugin device is created or duplicated.deviceStopComm` is called whenever a plugin is disabled, deleted, or when the plugin is shutting down. Therefore, these two functions should be the primary bottlenecks for starting/stopping device hardware or network connections.
Creating a Custom Plugin Trigger Event
Monitoring Device State Changes from a Plugin
FIXME Give examples of using indigo.devices.subscribeToChanges() and plugin subclasses of functions: deviceDeleted, deviceUpdated.
Monitoring Changes to Variables, Triggered & Scheduled Events, Action Groups, and Control Pages
