Variables
| Property |
Type |
Description |
id |
integer |
the unique id of the variable, assigned on creation by IndigoServer |
folderId |
integer |
the unique id of the folder this variable is in (0 if it's not in a folder) - use moveToFolder() method to change |
name |
string |
the name of the variable - no two variable can have the same name |
readOnly |
string |
is the variable read only - currently only the isDaylight variable is read only |
remoteDisplay |
boolean |
should this variable be displayed in remote clients (IWS, Indigo Touch, etc) |
sharedProps |
dictionary |
API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use var.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so as to not accidentally remove some other plugin's props). |
value |
string |
the unicode string value of the variable |
Class Method
| Type Literal |
Type Returned |
Default |
| bool |
Boolean |
True will be returned if the value is one of these: "true", "on", "yes", and "1". False will be returned if the value is one of these: "false", "off", "no", and "0". If no default value is specified and the value can't be successfully converted, the method will return False. |
| int |
Integer |
An integer object will be returned if the value is an integer number or a float/decimal. In the latter case, the number will be rounded to the nearest integer. If no default value is specified and the value can't be converted, the method will return 0 |
| float |
Float |
A float object will be returned if the value is a float/decimal or an integer. If no default value is specified and the value can't be converted, the method will return 0.0 |
Remember that accessing the value property of a variable object (*var.value*) will return a unicode string object so you don't need a conversion for that.
Class Method Examples
# Get a variable
unicodeValue = var.value
# Getting the boolean value
# Getting the integer value
# Getting the float value
Commands (indigo.variable.*)
indigo.variable.create("VariableName", value="Var Value", folder=843920) |
| Parameters |
| Parameter |
Required |
Type |
Description |
folder |
No |
integer |
id or instance of the folder in which to put the newly created device - defaults to 0 (no folder) |
name |
Yes |
string |
the name of the variable |
value |
No |
string |
the value of the variable |
Delete the specified folder.
indigo.variable.delete(123) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the variable to delete |
indigo.variable.duplicate(123, duplicateName="NewName") |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the variable to duplicate |
duplicateName |
No |
string |
name for the newly duplicated variable |
depDict = indigo.variable.getDependencies(123) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the variable to get the dependencies for. |
ID : 552463741 (integer)
ID : 296710860 (integer)
indigo.variable.moveToFolder(123, value=987) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the variable |
value |
Yes |
integer |
id or instance of the folder to move the variable to |
indigo.variable.displayInRemoteUI(123, value=True) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
value |
Yes |
boolean |
True to display the variable on remote user interfaces or False to hide it |
Update Value
indigo.variable.updateValue(123, value="New Value") |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
value |
Yes |
string |
the new value for the variable |
# Create a new variable
# changing name property
newVar.name = "goodName"
newVar.replaceOnServer()
newVar.name = "goodName2"
