Getting Started Guide
Welcome to Indigo 2022.1!
Z-Wave
- Thermostats, and
- Locks.
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
The Indigo 2022.1 application can be found here:
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2022.1 installer again (which will repair any permission issues that Time Machine may have introduced).
Upgrading from Indigo 2021.1 or 2021.2
Server Folder Change
Web Assets Folder Change
The installer moves customer-installed images and other files from either of these folders:
/Library/Application Support/Perceptive Automation/Indigo 2021.1/Web Assets/
/Library/Application Support/Perceptive Automation/Indigo 2021.2/Web Assets/
Lastly, the shared Python modules folder available during script execution has changed from:
to a Python 3 version:
If you have any existing Python modules/libraries in the old folder you should copy them to the new folder and make sure they are Python 3 compatible.
Indigo 2021.x->Stop Servermenu item in the Mac client. This will shut down the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 2021.x->Quit Indigomenu item. - Open the
Indigo plugins can now run under Python 3 and we are working with plugin developers to upgrade Python 2.7 based plugins to 3.10. Indigo 2022.1 will continue to allow older (Python 2.7) plugins to run, but you will see a warning in the Event Log and they will be marked with a yellow status icon in the Plugins menu indicating that they won't be compatible with future versions of Indigo. Check the Plugin Store and Plugin user forum for updates to the 3rd party plugins you are using.
Moving an Indigo Installation to another Mac
Indigo 2022.1->License Details...menu item and clicking theDeactivate Licensebutton. Do this while the Indigo Server is still running (do not shut down the Indigo Server first) - Copy this folder over to the new Mac:
/Library/Application Support/Perceptive Automation/Indigo 2022.1/(if restoring from a backup, you'll need to locate this folder in whatever backup system you use) - Install Indigo 2022.1 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
!!! warning "NOTE"
this is not the Library folder that's in your home directory - it's the one at the top level of your hard drive. The easiest way to get there is to select the Go->Go To Folder... menu item in the Finder and paste in this:
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2022.1->License Details... menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2022.1 menu if the server is still running before you quit the Indigo Mac Client).
/Library/Application Support/Perceptive Automation/Indigo 2022.1/~(your user folder)/Library/LaunchAgents/com.perceptiveautomation.IndigoServer2.plist
Uninstalling the Mac Client
/Applications/Indigo 2022.1.app~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-client6.plist~(your user folder)/Library/Preferences/Indigo 2022.1 Client Prefs.indiPref~(your user folder)/Library/Preferences/Indigo 2022.1 Client Settings.indiPref
To uninstall older versions but leave 2022.1 installed correctly, delete these:
Indigo 2021.2:
Indigo 2021.1:
Indigo 7.5:
Indigo 7.4:
Indigo 7.3:
Indigo 7.2:
Indigo 7.0 and 7.1:
Indigo 6 and prior (substitute the previous version # for 6):
Starting Indigo Server
- Double click the
Indigo 2022.1application (/Applications/Indigo 2022.1.app). - If this is the first time to run
Indigo 2022.1on this Mac, then press theStart Local Server...button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 2022.1->Start Local Server...menu item.
Standard startup mode
Use the Also allow HTTP Basic authentication (less secure) checkbox to enable HTTP Basic authentication. This setting allows you to insert the username/password in the URL line. Older services may require this, though we recommend against using it.
Custom single app startup
Starting the Server
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 2022.1application (inside/Applications/Indigo 2022.1.app) on the remote Mac. - If this is the first time to run
Indigoon this remote Mac, then press theConnect to Remote Server...button in the connection status window. - If you are wanting to connect to a different Indigo Server, then select the
Indigo 2022.1->Connect to Remote Server...menu item. - Enter the
Connectbutton.
http://192.168.1.23:8176/
- Configuring and Managing your Z-Wave Network
- Configuring and Managing your Insteon Network
- Configuring and Using X10 devices
- Using the Virtual Devices Interface
Managing Plugins
Installing Plugins
- Click the
- NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the
Open Withmenu item, then select Indigo 2022.1.
- Click the
Plugin Menus in Indigo
Main Plugins Menu
a green dot with no arrows means the plugin is enabled
There is also a yellow version of the green dots - the meaning is the same as the green version except it's indicating that the plugin is using an API version that will be deprecated in an upcoming release. You should check the Plugin Store for an updated version or contact the plugin developer.
a green dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version - you should install the update before upgrading to the next version of Indigo
Individual Plugin Submenu
The next section contains:
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2022.1->Preferences... menu item and clicking the Plugins tab or by selecting the Plugins->Manage Plugins... menu item discussed above.
- the
Uninstalling a Plugin
Help->Show Indigo Server Install Foldermenu item. This will switch you to the Finder and open a window to the Indigo install folder. - Switch back to Indigo and shut down the Indigo Server by selecting the
Indigo 2022.1->Stop Servermenu item in the Mac client (you can leave the client app running). - In the Finder window opened in step 1, you'll see two folders:
PluginsandPlugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. - Switch back to the Indigo 2022.1 Mac client and click on the
Start Local Server...button in theServer Connection Statusdialog.
- Choose
Date & Timeicon. - Select the
Closet Citylocation is not near your location, then follow the instructions on the panel to choose your location. If you would like to precisely specify your location, then you can override the system location from within Indigo.
- Choose the
Indigo 2022.1->Preferences...menu item, then make sure theSunset & Sunrisetab is selected. - Select the
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2022.1->Preferences... menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2022.1->Check for Updates... menu item.
- Choose
Energy Savericon. - Move the
Where to Go Next
