Upgrading from Indigo 7.5
to:
  1. Shut down the Indigo Server by selecting the Indigo 7.5->Stop Server menu item in the Mac client. This will shut down the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.5->Quit Indigo menu item.
Upgrading from Indigo 7.4
to:
  1. Shut down the Indigo Server by selecting the Indigo 7.4->Stop Server menu item in the Mac client. This will shut down the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.4->Quit Indigo menu item.
Upgrading from Indigo 7.3
to:
  1. Shut down the Indigo Server by selecting the Indigo 7.3->Stop Server menu item in the Mac client. This will shut down the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.3->Quit Indigo menu item.
Upgrading from Indigo 7.2
to:
  1. Shut down the Indigo Server by selecting the Indigo 7.2->Stop Server menu item in the Mac client. This will shut down the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7.2->Quit Indigo menu item.
to:
  1. Shut down the Indigo Server by selecting the Indigo 7->Stop Server menu item in the Mac client. This will shut down the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 7->Quit Indigo menu item.
First, run the Indigo 2022.1 installer. Then look through this list for any final actions.
  • In Indigo 7, we moved to Python v2.7, so if you installed any shared scripts (as outlined here) then you'll need to move them from: /Library/Python/2.6/site-packages/ to /Library/Python/2.7/site-packages/
  • Indigo will also copy over any enabled and disabled Plugins from Indigo 6 or 5. If a newer version of a plugin is included in Indigo, then it will automatically be installed and used on launch.
  • Your old Indigo database file will automatically be converted to the new Indigo file format on first launch. A copy of your database will automatically be made before it is converted, but any changes made in Indigo to your database will not be available in older versions of Indigo.
    • //Scripts//: /Library/Application Support/Perceptive Automation/Indigo 6/Scripts/
    • //Control Page Images//: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/
    • //Web Server Plugins//: /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/
    • //Scripts//: /Library/Application Support/Perceptive Automation/Indigo 5/Scripts/
    • //Control Page Images//: /Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/
    • //Web Server Plugins//: /Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/plugins/
    • //Scripts//: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/
    • //Control Page Images//: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/images/
    • //Web Server Plugins//: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/plugins/
    • //Scripts//: /Library/Application Support/Perceptive Automation/Indigo 2/Scripts/
    • //Control Page Images//: /Library/Application Support/Perceptive Automation/Indigo 2/IndigoWebServer/images/
!!! warning "NOTE" Do not replace the new Indigo versions of any file with your Indigo 6, 5, 4, 3, or 2 files. They have been modified to run optimally under the new version of Indigo.
Upgrading from Indigo 1.x
  • Your old Indigo database file will automatically be converted to the new Indigo file format on first launch. You will be prompted to save the new copy of the Indigo database file. The new Indigo file format is not compatible with Indigo 1.x. You should not replace or delete your older Indigo 1.x database file. Any changes made in Indigo to your database settings will not be available in older versions of Indigo.
!!! warning "NOTE" Do not replace the new Indigo versions of any file with your Indigo 1.x files. They have been modified to run optimally under the new version of Indigo.
AppleScript after Upgrading
When Indigo first opens an Indigo 7.3 (or earlier) database, it will go through the database and identify items that will need changing and items you should look at to ensure that it will continue to function. The Event Log will contain the necessary information about where you can find those items. You can also select the Help->Show AppleScript Usage in Event Log menu item and Indigo will show you the list of those items in the Event Log window again.
If you have Execute Script actions that point to AppleScripts, those will continue to be run, though if the script contains a tell "IndigoServer" or using terms from "IndigoServer" they will fail.
