apiVersion string No API v1.7: the currently connected Indigo Server plugin API version as a string (ex: "1.7")
connectionGood boolean No true if the connection to the Indigo Server is currently good
portNum integer No the port number of the currently connected Indigo Server
License Status Enumeration
Value Description
*ActiveSubscription* license has an active Indigo Up-to-Date subscription (access to a reflector)
Broadcast to Subscribers
| Command Syntax Examples | | --- | | python indigo.server.broadcastToSubscribers(messageName) |
Calculate Sunrise
direct parameter No datetime.date a *datetime.date* object representing the day to calculate the sunrise time for
Calculate Sunset
Event Log List
Get Database File Name
Get Database File Path
Get Deprecated Elements
Returns the server's list of elements that have attributes or properties that are now deprecated.
Get Install Folder Path
Get Latitude and Longitude
| Command Syntax Examples | | --- | | python latLong=indigo.server.getLatitudeAndLongitude() lat = latLong[0] long = latLong[1] |
Get Plugin
direct parameter Yes string the id of the plugin to retrieve
Get Plugin List
Get Reflector URL
Get Serial Ports
filter No string currently there’s only one valid filter: "indigo.ignoreBluetooth" which will remove the "Bluetooth-PDA-Sync" option from the list
for posixPath in ports:
    print(posixPath)
    print(uiName)
# iterate through both
    print(posixPath)
    print(uiName)
Get Time
indigo.server.getTime()
No Parameters
Get Web Server URL
  1. Reflector (*%%https:*reflector.indigodomo.net%%//) if a reflector is configured.
  2. Bonjour name (*%%http:*MacName.local:PORT%%//) if it can be determined.
  3. Localhost (*%%http:*localhost:PORT%%//) if all else fails.
No Parameters
Log
*type* No string a string representing the type - if it’s not included and is run from a Server Plugin, the name of the plugin will automatically be used
*isError* No boolean if *True*, it will show up in red in the event log - default is *False* - if no *type* is included, the name of the plugin will automatically be used with " Error" appended
Remove All Delayed Actions
Restart Plugin
Save Plugin Preferences
Send Email
This tells IndigoServer to send an email using the SMTP settings configured in the preferences "Email" tab.
*subject* No string the subject of the email
*body* No string the body of the email
Speak
*waitUntilDone* No boolean should the method call block until speaking is complete or should it just return immediately (queue up the speech)
Stop Plugin
Tell the server to shut down our plugin process. Plugin will remain enabled but be in a stopped state. This command can only be called from a plugin and it refers to the plugin itself (not all plugins). | Command Syntax Examples | | --- | | indigo.server.stopPlugin("Stopping now for some reason", isError=True)) |
Subscribe To Log Broadcasts
Subscribes to all server event log broadcasts. This command does not take any parameters. | Command Syntax Examples | | --- | | indigo.server.subscribeToLogBroadcasts() |
Wait Until Idle
Wait (block) until server has completed event processing and command sending. This command does not take any parameters. | Command Syntax Examples | | --- | | indigo.server.waitUntilIdle() |
