Indigo Web Server
Web Assets Folder Structure
Indigo 2022.1 contains special folders that are accessible to the Indigo Web Server which are located in:
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/images
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/plugins
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/public
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/static
As a convenience, you can access these folders under the Indigo Help menu: Help --> Show Web Assets Folder
images folder
plugins folder
With Indigo 2022.1, web server plugins are no longer supported.
public folder
This directory can be used to publish files from the Indigo Web Server that will be made available to anyone *without any authentication*. If someone knows the URL of your reflector, they will have access to any files that are in this directory, so use it wisely.
For example:
static folder
This directory can be used to publish files from the Indigo Web Server that will be made available to anyone *with authentication*. If someone knows the URL of your reflector, they will have access to any files that are in this directory once they have entered the appropriate authentication credentials for your reflector.
For example:
Authentication
Information on Indigo Authentication options can be found on the Restful URLS page under the authentication section.
Example
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8">
  </head>
      Hello world.
    </div>
  </body>
</html>
Using a plain text editor, save this code as index.html within the .../Web Assets/static folder (to serve it with authentication) or within the .../Web Assets/public folder (to serve it without authentication). You can refer to assets located in other folders by referencing them with the Web Assets folder as the root.
