Actions
Action Base Class
| Property |
Type |
Description |
delayAmount |
integer |
number of seconds to delay before executing the actions (0 for none) |
replaceExisting |
boolean |
if true then any existing delayed action is replaced by this one |
textToSpeak |
string |
this is the text to speak when the action is executed |
Complementary Delays
| Complementary Actions |
| Action |
Complement |
*DeviceAction* \ *kDeviceAction.TurnOff* \ *kDeviceAction.TurnOn* \ *kDeviceAction.Toggle* \ *kDeviceAction.Lock* \ *kDeviceAction.Unlock* |
*DeviceAction* \ *kDeviceAction.TurnOn* \ *kDeviceAction.TurnOff* \ *kDeviceAction.Toggle* \ *kDeviceAction.Unlock* \ *kDeviceAction.Lock* |
*DisableScheduleAction* |
*EnableScheduleAction* |
*DisableTriggerAction* |
*EnableTriggerAction* |
DeviceAction (API v2.0+ only)
API v2.0+ only: This class represents an action to control dimmers (lights), relay (appliances), and locks. Previously this class was named DimmerRelayAction -- it was renamed in API v2.0.
| Property |
Type |
Description |
complementDelay |
integer |
the number of seconds to delay before issuing the complementary action (0 for no action) - see Complementary Delays for details |
deviceId |
integer |
the id of the device |
deviceAction |
kDeviceAction |
this is the command to send to the device |
actionValue |
integer or dict |
if *deviceAction* is in [Brighten, Dim, SetBrightness] then this is an integer value |
Device Action Enumeration
| indigo.kDeviceAction |
| Value |
Description |
AllLightsOff |
turn off all dimmer (light) devices |
AllLightsOn |
turn on all dimmer (light) devices |
AllOff |
turn off all dimmer (light) and relay (appliance) devices |
BrightenBy |
brighten a dimmer (light) device by the amount specified in the actionValue integer property |
DimBy |
dim a dimmer (light) device by the amount specified in the actionValue integer property |
SetBrightness |
set a dimmer (light) device to the brightness specified in the actionValue integer property |
SetColorLevels |
set the color (RGB) and white levels to the values specified in the actionValue dict property |
Toggle |
toggle the on/off state of a dimmer (light) or relay (appliance) device |
TurnOff |
turn off a dimmer (light) or relay (appliance) device |
TurnOn |
turn on a dimmer (light) or relay (appliance) device |
Lock |
lock a deadbolt or door device |
Unlock |
unlock a deadbolt or door device |
| Property |
Type |
Description |
complementDelay |
integer |
the number of seconds to delay before issuing the complementary action (0 for no action), in this case an EnableScheduleAction - see Complementary Delays for details |
scheduleId |
integer |
the id of the schedule to disable |
| Property |
Type |
Description |
complementDelay |
integer |
the number of seconds to delay before issuing the complementary action (0 for no action), in this case an EnableTriggerAction - see Complementary Delays for details |
triggerId |
integer |
the id of the trigger to disable |
EmailAction
| Property |
Type |
Description |
emailBody |
string |
the body of the email to send |
emailSubject |
string |
the subject of the email to send |
emailTo |
string |
the (semicolon separated) list of email addresses |
| Property |
Type |
Description |
complementDelay |
integer |
the number of seconds to delay before issuing the complementary action (0 for no action), in this case an *DisableScheduleAction* - see Complementary Delays for details |
scheduleId |
integer |
the id of the schedule to enable |
EnableTriggerEventAction
| Property |
Type |
Description |
complementDelay |
integer |
the number of seconds to delay before issuing the complementary action (0 for no action), in this case an DisableTriggerAction - see Complementary Delays for details |
eventId |
integer |
the id of the event to enable |
ExecuteGroupAction
| Property |
Type |
Description |
groupId |
integer |
the id of the action group to execute |
ExecuteScriptAction
| Property |
Type |
Description |
scriptCode |
string |
this is the source code of the script to execute |
Return an indigo.Dict with all the dependencies on this action group.
depDict = indigo.actionGroup.getDependencies(123) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the action group to get the dependencies for. |
>>> print indigo.actionGroup.getDependencies(91776575)
ID : 552463741 (integer)
ID : 296710860 (integer)
| Property |
Type |
Description |
deviceId |
integer |
this is the ID of the I/O device |
action |
kIOAction |
this I/O action to execute |
index |
integer |
if *action* is *TurnOffOutput*, *TurnOnOutput*, the index of the input or output to control |
| indigo.kIOAction |
| Value |
Description |
TurnOffOutput |
turn off the output specified by index |
TurnOffAllOutputs |
turn off all outputs |
TurnOnOutput |
turn on the output specified by index |
RequestStatusAll |
request status of all hardware input/outputs |
RequestAnalogInputValues |
request all analog input values from the device |
RequestBinaryInputsStatus |
request all binary input statuses |
RequestBinaryOutputsStatus |
request all binary output statuses |
RequestSensorInputValues |
request all sensor input values |
ModifyVariableAction
| Property |
Type |
Description |
variableId |
integer |
the id of the variable |
variableAction |
kVariableAction |
the type of variable action to execute |
variableValue |
string |
the new variable value |
Variable Action Enumeration
| indigo.kVariableAction |
| Value |
Description |
DecrementValue |
decrement the variable value by 1 |
IncrementValue |
increment the variable value by 1 |
SetValue |
set the variable to the *variableValue* property |
PluginAction
| Property |
Type |
Description |
deviceId |
integer |
pluginId |
string |
the unique ID of the plugin, specified in the Info.plist for the plugin (or it’s documentation) |
pluginTypeId |
string |
the id specified in the Actions.xml (or it’s documentation) |
props |
dictionary |
an indigo.Dict() defining this action's parameters |
SendInsteonGroupCommandAction
| Property |
Type |
Description |
command |
kInstnGroupCommand |
this is the group command to send |
group |
integer |
this is the group number to send *command* to |
| indigo.kIOAction |
Value |
Description |
InstantOff |
send the instant (fast) off command to group ignoring ramp rate |
InstantOn |
send the instant (fast) on command to group ignoring ramp rate |
Off |
send the off command to group |
On |
send the on command to group |
SprinklerAction
| Property |
Type |
Description |
deviceId |
integer |
the id of the sprinkler device |
multiplierVarId |
integer |
API v1.20+ only: optional elem ID for the variable multiplier (None if no multiplier is specified) |
sprinklerAction |
kSprinklerAction |
this sprinkler action to execute |
zoneDurations |
list of float |
list of floats that represent the durations in minutes for each zone to schedule - used when *sprinklerAction* is *RunNewSchedule* |
zoneIndex |
integer |
the zone to turn on as a 1-based index -- used when *sprinklerAction* is *ZoneOn* |
Sprinkler Action Enumeration
| indigo.kSprinklerAction |
| Value |
Description |
RunNewSchedule |
run a new sprinkler schedule |
RunPreviousSchedule |
run the last executed sprinkler schedule |
PauseSchedule |
pause the current sprinkler schedule |
ResumeSchedule |
resume the current sprinkler schedule |
StopSchedule |
stop the current sprinkler schedule |
PreviousZone |
set sprinkler to the previous zone |
NextZone |
set sprinkler to the next zone |
ZoneOn |
turn on a single zone |
AllZonesOff |
turn off all zones |
RequestStatusAll |
request status of all valves |
ResetInterfacesAction
ThermostatAction
| Property |
Type |
Description |
deviceId |
integer |
this is the ID of the thermostat |
thermostatAction |
kThermostatAction |
this thermostat action to execute |
actionMode |
kFanMode \ OR \ kHvacMode |
if action is SetFanMode, then a kFanMode enumeration \ if action is SetHvacMode, then a kHvacMode enumeration |
actionValue |
float |
if action is *Decrease* or *Increase*, the amount to increase/decrease the setpoints \ if action is *Set**, the temperature to set the setpoint to |
Thermostat Action Enumeration
| indigo.kThermostatAction |
| Value |
Description |
DecreaseCoolSetpoint |
decrease setpoint by value |
DecreaseHeatSetpoint |
IncreaseCoolSetpoint |
increase setpoint by value |
IncreaseHeatSetpoint |
SetCoolSetpoint |
set the setpoint to value |
SetFanMode |
set the fan mode to mode |
SetHeatSetpoint |
SetHvacMode |
set the hvac mode to mode |
RequestStatusAll |
request all current values from the thermostat |
RequestMode |
request the current mode of the thermostat |
RequestEquipmentState |
request the current operational state of the compressor, furnace, etc. |
RequestTemperatures |
request all current temperatures from the thermostat |
RequestHumidities |
request all current humidities from the thermostat |
RequestDeadbands |
request the current deadband ranges from the thermostat |
RequestSetpoints |
request all current setpoints from the thermostat |
UniversalAction (API v2.0+ only)
API v2.0+ only: This class represents a universal action that can be used with devices of different classes. Previously this class was named GeneralDeviceAction -- it was renamed in API v2.0.
| Property |
Type |
Description |
deviceId |
integer |
deviceAction |
kUniversalAction |
| indigo.kUniversalAction |
| Value |
Description |
Beep |
request that the device perform an audible beep or buzz |
EnergyUpdate |
request that the energy meter send its most recent meter data |
EnergyReset |
request that the energy meter reset its accumulative energy usage data |
RequestStatus |
send a device a status request for a complete update |
