Indigo Object Model Reference
About this Reference
# some code here
# that does something
| Term | Meaning |
Introduction
For Scripters and Developers:
For Developers:
| Devices | ||||
| Schedule | ||||
Schedule (indigo.Schedule) |
| Triggers | ||||
| DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger) | indigo.devStateChange.* | manipulate a device state change trigger | ||
| Action Groups | ||||
| Variables | ||||
| General Commands | ||||
IOM Class Hierarchy
Indigo specific data types
- keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
python_dict = my_indigo_dict.to_dict() # recursively convert an indigo.Dict instance to a python dict instance
python_list = my_indigo_list.to_list() # recursively convert an indigo.List instance to a python list instance
Built-in objects
| Object | Description |
The other additional method is subscribeToChanges(). This method doesn't return anything - rather, it tells the IndigoServer that your plugin wants notification of all changes to the specific object type. Use this method sparingly as it causes a significant amount of traffic between IndigoServer and your plugin. What kind of plugins would use this? One good example is a logging plugin - one that's logging activity within Indigo (like our SQL Logger). Another example is a plugin that's doing some kind of scene management - you would probably want to issue a indigo.devices.subscribeToChanges() at plugin start so that you'll always be notified when any device changes - you can then determine if your scene "state" has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change.
Object Events
Lower-level Events
if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
# do stuff with dev here
Triggers also have filters:
| Filter | Description |
for var in indigo.variables:
# all variables
Common Python Exceptions
| Possible Exceptions | |
ArgumentError |
IndexError |
KeyError |
PluginNotFoundError |
TypeError |
ValueError |
Classes and Commands
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
So, from a discovery perspective, the dir(obj) method will list all properties and methods for an object. The hasattr(obj, attr) will test an object to see if it has a specific attribute. The obj.**class** attribute will show you what class the object is. As you explore IOM objects, these methods will help you figure out how to use IOM objects effectively.
Object Dictionaries
>>> dev = indigo.devices[123]
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
<'indigo.Device'>
>>> dev_dict = dict(dev)
<class 'dict'>
- Device classes
- Trigger classes
- Action classes
- Action Group class
- Variable class
- Folder class
Utility Classes and Functions
Classes
| Name | Base | Description |
FileNotFoundError |
Exception |
This is a useful exception if you handle files in any way. There is no built-in processing to catch such exceptions, it's just a useful exception to use. |
IndigoJSONEncoder |
JSONEncoder |
Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder)) |
Functions
Return Static File
| Parameters | |||
file_path |
Yes | string | a string that represents the path to a file |
*status* |
No | int | the HTTP status code to return, defaults to 200 |
*path_is_relative* |
No | boolean | is the path a full path or relative to the plugin, defaults to True |
*content_type* |
No | string | a string to return as the mime type of the content, returns the appropriate type based on the file extension if none is specified |
"status": 404,
"headers": {
"Content-Type": "text/html"
"file_path": "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
| Parameters | |||
address |
Yes | string | a string that represents an email address |
