Install the FTDI VCP Drivers
Connecting the Interface
- Choose
Indigo 2022.2->Preferences...menu, then make sure theInterfacestab is selected. - Select the
INSTEON/X10 Power Line Interfaceline in the table (you can also get to this dialog by selecting theInterfaces->INSTEON/X10 Power Line->Configure…menu item) - Choose your
- Optionally select the
Group addresses on transmissioncheckbox to combine like-command transmissions together. For example A1-On, A3-On, A4-On, would be transmitted as A1, A3, A4, On. - Some interfaces, such as the PowerLinc V2 and LynX-PLC, have additional settings that can be accessed from the Interface Options... button. Generally, these options don't need to be changed unless you're troubleshooting a problem.
If you click on the Interface Options... button, you'll see something like this:
First, make sure that Indigo has enabled communication with the interface. If Indigo is not online with the interface, then choose the Interfaces->INSTEON/X10 Power Line->Enable menu item. See connecting the Interface above for more details.
To add a new Insteon device:
- Press the
New...button at the top of the Home window and selectINSTEONfrom theTypepopup.
Resyncing Links
Replacing a Device
Managing INSTEON Links
Managing INSTEON Device Links
- Select the
Interfaces->INSTEON/X10 Power Line->Manage Device Linksmenu item. - Select the module's device name to edit in the
Defining the Scene
- Choose
Manage PowerLinc Links...from theInterfaces->INSTEON/X10 Power Linemenu. - Select a
PowerLinc Group/Scenename in the edit field (ex: "reading in bed").
Executing the Scene
- Follow the instructions to create a Trigger, Schedule, or Action Group.
- Select the
INSTEON Actions->[Execute INSTEON Scene](overview.md#execute-insteon-scene)from the actionTypepopup item. - Use the
Scenepopup item.
INSTEON Link Syncing
Resetting your PowerLinc
Interfaces->Insteon/X10 Power Line->Disablemenu item - Unplug your PowerLinc and wait about 15 seconds
- Release the button
- In Indigo, select the
Interfaces->Insteon/X10 Power Line->Enablemenu item - Select the
Interfaces->Insteon/X10 Power Line->Configure...menu item - Click the
Interface Options...button - Click the
Sync Linksbutton
Replacing Your PowerLinc
The Interfaces->INSTEON/X10 Power Line submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI:
Execute Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
if insteonPlugin.isEnabled():
actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
Set Siren Alarm Sound
Set Siren LED Mode
Set OutletLinc Load Sense
