| Property | Type | Writable | Description | |
address |
string | No | the IP address of the currently connected Indigo Server | |
apiVersion |
string | No | API v1.7: the currently connected Indigo Server plugin API version as a string (ex: "1.7") | |
connectionGood |
boolean | No | true if the connection to the Indigo Server is currently good | |
licenseStatus |
string | No | API v2.5: returns one of the values specified in the indigo.kLicenseStatus enumeration below |
portNum |
integer | No | the port number of the currently connected Indigo Server | |
version |
string | No | the currently connected Indigo Server version string |
License Status Enumeration
| indigo.kLicenseStatus | |
Value |
Description |
ActiveTrial |
the license is a trial |
*ActiveSubscription* |
license has an active Indigo Up-to-Date subscription (access to a reflector) |
ExpiredSubscription |
license has an expired Indigo Up-to-Date subscription (no access to a reflector) |
Unknown |
license is in an unknown state |
Broadcast to Subscribers
| python
indigo.server.broadcastToSubscribers(messageName) |
Calculate Sunrise
indigo.server.calculateSunrise() |
indigo.server.calculateSunrise(myDateObject) |
| Parameters | |||
| direct parameter | No | datetime.date |
a *datetime.date* object representing the day to calculate the sunrise time for |
Calculate Sunset
indigo.server.calculateSunset() |
indigo.server.calculateSunset(myDateObject) |
| Parameters | |||
a datetime.date object representing the day to calculate the sunrise time for |
Event Log List
indigo.server.getEventLogList() |
indigo.server.getEventLogList(lineCount=5) |
indigo.server.getEventLogList(showTimeStamp=False) |
indigo.server.getEventLogList(lineCount=5, showTimeStamp=False) |
indigo.server.getEventLogList(returnAsList=True, lineCount=5) |
| Parameters | |||
Get Database File Name
name=indigo.server.getDbName() |
Get Database File Path
name=indigo.server.getDbFilePath() |
Get Deprecated Elements
Returns the server's list of elements that have attributes or properties that are now deprecated.
name=indigo.server. getDeprecatedElems(includeWarnings=[True/False] |
Get Install Folder Path
name=indigo.server.getInstallFolderPath() |
Get Latitude and Longitude
| python
lat = latLong[0]
long = latLong[1] |
Get Plugin
myPlugin=indigo.server.getPlugin("com.company.pluginId") |
| Parameters | |||
Get Plugin List
enabled_plugin_list=indigo.server.getPluginList() |
Get Reflector URL
indigo.server.getReflectorURL() |
Get Serial Ports
indigo.server.getSerialPorts() |
indigo.server.getSerialPorts(filter="indigo.ignoreBluetooth") |
| Parameters | |||
filter |
No | string | currently there’s only one valid filter: "indigo.ignoreBluetooth" which will remove the "Bluetooth-PDA-Sync" option from the list |
for posixPath in ports:
print(posixPath)
print(uiName)
# iterate through both
print(posixPath)
print(uiName)
Get Time
indigo.server.getTime() |
No Parameters
Get Web Server URL
- Reflector (
%%https://reflector.indigodomo.net) if a reflector is configured. - Bonjour name (
http://MacName.local:PORT) if it can be determined. - Localhost (
http://localhost:PORT) if all else fails.
indigo.server.getWebServerURL() |
No Parameters
Log
indigo.server.log("Info Text to log") |
indigo.server.log("Info Text to log", type="myType") |
indigo.server.log("Warning Text to log", level=logging.WARNING) |
indigo.server.log("Error Text to log1", level=logging.ERROR) |
indigo.server.log("Error Text to log2", isError=True) |
| Parameters | ||||
| direct parameter | Yes | string | this is the text that’s written to the log | |
*type* |
No | string | a string representing the type - if it’s not included and is run from a Server Plugin, the name of the plugin will automatically be used | |
level |
No | integer | API v2.4: the python logging level which determines both the type shown and the text color used. (ex: using level=logging.WARNING will show orange text) |
*isError* |
No | boolean | if *True*, it will show up in red in the event log - default is *False* - if no *type* is included, the name of the plugin will automatically be used with " Error" appended |
Remove All Delayed Actions
indigo.server.removeAllDelayedActions() |
Restart Plugin
indigo.server.restartPlugin("Restarting now for some reason", isError=True) |
Save Plugin Preferences
indigo.server.savePluginPrefs() |
Send Email
This tells IndigoServer to send an email using the SMTP settings configured in the preferences "Email" tab.
indigo.server.sendEmailTo("my.address@example.com") |
indigo.server.sendEmailTo("my.address@example.com", subject="Subject of email", body="Body of email") |
| Parameters | |||
*subject* |
No | string | the subject of the email |
*body* |
No | string | the body of the email |
Speak
indigo.server.speak("text to speak", waitUntilDone=True) |
| Parameters | |||
*waitUntilDone* |
No | boolean | should the method call block until speaking is complete or should it just return immediately (queue up the speech) |
Stop Plugin
Tell the server to shutdown our plugin process. Plugin will remain enabled but be in a stopped state. This command can only be called from a plugin and it refers to the plugin itself (not all plugins).
| indigo.server.stopPlugin("Stopping now for some reason", isError=True)) |
Subscribe To Log Broadcasts
| indigo.server.subscribeToLogBroadcasts() |
Wait Until Idle
| indigo.server.waitUntilIdle() |
