Get Contents Of Url
Get Contents of URL Action
The Get Contents of URL Action allows users to query APIs and other URLs and save the results of the query to an Indigo variable for display or for further processing. The Get Contents of URL Action was introduced in Indigo v2023.1.
Get Contents of URL Action Image
  • Enter the URL - use this field to enter the URL of the target resource.
  • Method - use this option to... The action supports all the major resource I/O methods including: *GET*, *POST*, *PUT*, *PATCH* and *DELETE*.
  • HTTP Auth - if the target resource requires authentication (as most do), use this option to enter the necessary authentication details.
    • Auth Type - use this option to select the authentication method used by the target resource. The control supports both *BASIC* and *DIGEST* auth types.
    • Username - use this field to enter the username of the target resource.
    • Password - use this field to enter the password of the target resource.
  • Show Headers - There are two major sections to the Show Headers control: the first set of controls is used to edit or delete an existing header key/value pair, and the second set is for adding a new header. The checkbox is only used to show/hide the controls; any added headers are used even if the checkbox is unchecked.
    • Header - use this option to select from a list of headers for the action. The list will be empty if no headers have been added. Use the add header controls to add a new header.
    • Key - use this option to... FIXME
    • Value - use this option to... FIXME
  • Body - use this field to enter the body message (including Indigo substitutions). Anything in this field will be inserted into the body of the HTTP message. We use it exactly as it comes from the field with no post processing other than the normal device and variable substitutions.
  • Store Result in Variable - use this option to store the results of the URL call to an Indigo variable. If enabled, you can select from a list of available variables. Note that Indigo stores all variable values as strings (text), so any value saved to a variable using the Get Contents from URL action will be coerced into a string.
Example 1
FIXME
Example 2
FIXME
