REST API Conversion Examples
If you're using the old REST API (which has been deprecated), here are some examples of how you might convert your REST usages to the HTTP API.
The first thing you'll want to understand is how to use authentication with the HTTP API. The examples below use both headers and query args for authentication. You can use whichever works for you. You should replace YOUR-API-KEY with your actual API Key.
Second, all replies to the API will be JSON messages.
In the following examples, we'll be using a mix of authentication headers and the API Key as a query arg. You can use either. We mark the examples REST (old REST API) and HTTP (newer HTTP API).
Device Access
Getting Devices
get device list
REST
http://username:password@127.0.0.1:8176/devices.json
HTTP
http://127.0.0.1:8176/v2/api/indigo.devices?api-key=YOUR-API-KEY
This will return a JSON list of Device Objects.
get single device
REST
http://username:password@127.0.0.1:8176/devices/office-lamp.json
HTTP
http://127.0.0.1:8176/v2/api/indigo.devices/123456789?api-key=YOUR-API-KEY
Insert the ID of the office-lamp device rather than the name. Note you can quickly copy the device ID to the clipboard by right-clicking on the device in Indigo app's main window and choosing the Copy ID context menu.
This will return a single Device Object.
Device Commands
Sending commands to devices requires that you POST a JSON message to the /v2/api/command URL.
set brightness
REST
''curl -X PUT -u user:password --digest -d brightness=27 http://127.0.0.1:8176/devices/office-lamp''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.device.setBrightness","objectId":123456789,"parameters":{"value":27}}' http://127.0.0.1:8176/v2/api/command
Insert the ID of the office-lamp device as the objectId.
turn on/turn off
REST
''curl -X PUT -u user:password --digest -d isOn=1 http://127.0.0.1:8176/devices/office-lamp'' ''curl -X PUT -u user:password --digest -d isOn=0 http://127.0.0.1:8176/devices/office-lamp''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.device.turnOn","objectId":123456789}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.device.turnOff","objectId":123456789}' http://127.0.0.1:8176/v2/api/command
toggle
REST
''curl -X PUT -u user:password --digest -d toggle=1 http://127.0.0.1:8176/devices/office-lamp''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.device.toggle","objectId":123456789}' http://127.0.0.1:8176/v2/api/command
change speed index (fan)
These examples will set device office-ceiling-fan to 0 (off), then set to 3 (high), then decrease back to 0 (off).
REST
''curl -X PUT -u user:password --digest -d speedIndex=0 http://127.0.0.1:8176/devices/office-ceiling-fan'' ''curl -X PUT -u user:password --digest -d speedIndex=3 http://127.0.0.1:8176/devices/office-ceiling-fan'' ''curl -X PUT -u user:password --digest -d speedIndex=dn http://127.0.0.1:8176/devices/office-ceiling-fan'' ''curl -X PUT -u user:password --digest -d speedIndex=dn http://127.0.0.1:8176/devices/office-ceiling-fan'' ''curl -X PUT -u user:password --digest -d speedIndex=dn http://127.0.0.1:8176/devices/office-ceiling-fan''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.speedcontrol.setSpeedIndex","objectId":123456789,"parameters":{"value":0}}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.speedcontrol.setSpeedIndex","objectId":123456789,"parameters":{"value":3}}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.speedcontrol.decreaseSpeedIndex","objectId":123456789}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.speedcontrol.decreaseSpeedIndex","objectId":123456789}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.speedcontrol.decreaseSpeedIndex","objectId":123456789}' http://127.0.0.1:8176/v2/api/command
Insert the ID of the office-ceiling-fan device as the objectId.
change sprinkler zones
These examples will change device irrmaster-pro active sprinkler zone to 3 and all off.
REST
''curl -X PUT -u user:password --digest -d activeZone=3 http://127.0.0.1:8176/devices/irrmaster-pro'' ''curl -X PUT -u user:password --digest -d activeZone=0 http://127.0.0.1:8176/devices/irrmaster-pro''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.sprinkler.setActiveZone","objectId":123456789,"parameters":{"index":3}}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.sprinkler.setActiveZone","objectId":123456789,"parameters":{"index":0}}' http://127.0.0.1:8176/v2/api/command
Insert the ID of the irrmaster-pro device as the objectId.
set thermostat setpoints
These examples will set device thermostat's heat and cool setpoints
REST
''curl -X PUT -u user:password --digest -d setpointCool=76 http://127.0.0.1:8176/devices/thermostat'' ''curl -X PUT -u user:password --digest -d setpointHeat=70 http://127.0.0.1:8176/devices/thermostat''
Increase Heat Setpoint
''curl -X PUT -u user:password --digest -d setpointHeat=up http://127.0.0.1:8176/devices/thermostat''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setCoolSetpoint","objectId":123456789,"parameters":{"value":76}}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setHeatSetpoint","objectId":123456789,"parameters":{"value":70}}' http://127.0.0.1:8176/v2/api/command
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.increaseHeatSetpoint","objectId":123456789}' http://127.0.0.1:8176/v2/api/command
Insert the ID of the thermostat device as the objectId.
set thermostat mode
These examples will set device thermostat's mode to "cool on" and "auto on"
REST
''curl -X PUT -u user:password --digest -d hvacCurrentMode="cool on" http://127.0.0.1:8176/devices/thermostat'' ''curl -X PUT -u user:password --digest -d hvacCurrentMode="auto on" http://127.0.0.1:8176/devices/thermostat''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setHvacMode","objectId":123456789,"parameters":{"value":"indigo.kHvacMode.Cool"}}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setHvacMode","objectId":123456789,"parameters":{"value":"indigo.kHvacMode.HeatCool"}}' http://127.0.0.1:8176/v2/api/command
set thermostat fan mode
These examples will set device thermostat's fan mode to "always on" and "auto on"
REST
''curl -X PUT -u user:password --digest -d hvacFanMode="always on" http://127.0.0.1:8176/devices/thermostat'' ''curl -X PUT -u user:password --digest -d hvacFanMode="auto on" http://127.0.0.1:8176/devices/thermostat''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setFanMode","objectId":123456789,"parameters":{"value":"indigo.kFanMode.AlwaysOn"}}' http://127.0.0.1:8176/v2/api/command curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.thermostat.setFanMode","objectId":123456789,"parameters":{"value":"indigo.kFanMode.Auto"}}' http://127.0.0.1:8176/v2/api/command
Variable Access
Getting Variables
get variable list
REST
http://username:password@127.0.0.1:8176/variables.json
HTTP
http://127.0.0.1:8176/v2/api/indigo.variables?api-key=YOUR-API-KEY
This will return a JSON list of Variable Objects.
get single variable
REST
http://username:password@127.0.0.1:8176/variables/sprinklerDurationMultiplier.json
HTTP
http://127.0.0.1:8176/v2/api/indigo.variables/123456789?api-key=YOUR-API-KEY
Insert the ID of the sprinklerDurationMultiplier variable rather than the name.
This will return a single Variable Object.
Variable Commands
Sending commands to the server requires that you POST a JSON message to the /v2/api/command URL.
update variable value
REST
''curl -X PUT -u user:password --digest -d value=1.23 http://127.0.0.1:8176/variables/sprinklerDurationMultiplier''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.variable.updateValue","objectId":123456789,"parameters":{"value":"1.23"}}' http://127.0.0.1:8176/v2/api/command
Insert the ID of the sprinklerDurationMultiplier variable as the objectId. Note: variable values are always strings to make sure to enclose the value in quotes.
Action Group Access
Getting Action Groups
get action group list
REST
http://username:password@127.0.0.1:8176/actions.json
HTTP
http://127.0.0.1:8176/v2/api/indigo.actionGroups?api-key=YOUR-API-KEY
This will return a JSON list of Action Group Objects.
get single action group
REST
http://username:password@127.0.0.1:8176/actions/party%20scene.json
HTTP
http://127.0.0.1:8176/v2/api/indigo.actionGroups/123456789?api-key=YOUR-API-KEY
Insert the ID of the party scene action group rather than the name.
This will return a single Action Group Object.
Action Group Commands
execute action group
REST
''curl -X EXECUTE -u user:password --digest -d value=1.23 http://127.0.0.1:8176/actions/party%20scene''
HTTP
curl -X POST -H "Authorization: Bearer YOUR-API-KEY" -d '{"message":"indigo.actionGroup.execute","objectId":123456789}' http://127.0.0.1:8176/v2/api/command
Insert the ID of the party scene action group as the objectId.
