Glossary of Terms
Term Definition
*Action* Indigo actions are discrete tasks that cause things to happen -- such as turning on a light, changing a setpoint, writing information to the log, and so on. Indigo ships with many standard actions and plugin developers can create actions that apply to their plugins.
Overview Control Pages are user-created interfaces to control their Indigo system - for instance you could create a graphical floor plan with light icons in the various rooms.
*Condition* In Indigo, a condition is a logical test that's used to determine whether something should happen. For example, you might only want something to happen at nighttime, or only when all the windows are closed.
*Controller* In Indigo, a controller is a device that controls another device. Z-Wave controllers include various peripherals such as USB sticks -- which send commands from Indigo to a device (like a dimmer) or from the device to Indigo. A controller may also be a responder (i.e. INSTEON KeypadLinc). We've adopted the term from various INSTEON documentation.
*Developer* A person who writes plugins or scripts for the Indigo Server (IS).
*INSTEON Link* A connection between two INSTEON devices such that one device controls the other based on some input - a button press, etc.
Overview A device is any "thing" that Indigo can interact with - usually it's some kind of hardware (light switch, appliance module, motion sensor, etc), but devices can also be other non-hardware things (iTunes server, calendar, etc). Devices can also be "virtual" objects supported by plugins that have to potential to do all kinds of useful things.
*I/O Device* Any device that has binary or analog inputs or outputs. These devices are generally used to interface at a low-level to other devices (security systems, sensors, etc).
*Indigo Object Model* The Indigo Object Model (IOM) is how the various objects in Indigo are modeled in Python objects for scripters and plugin developers.
*Plugin* Indigo supports ways to extend its functionality such as Indigo Server (IS) plugins. IS plugins can extend Indigo by adding additional devices types, trigger events, and actions.
*Responder* In Indigo terminology, it's a device that responds to commands. A responder may also be a controller (i.e. INSTEON KeypadLinc). We've adopted the term from various INSTEON documentation.
Overview A schedule is similar to a trigger, but the event that causes the execution of the actions is a temporal event of some kind. Either a fixed point in time (5/2/2011 at 1:00pm) or more likely some repeating time (every day at 1:00pm).
*Scripter* Someone who uses Python scripts to implement automation logic in Indigo via embedded or file-based script actions and script conditions.
Overview A trigger is generally some kind of "event" that occurs. Indigo can use that event to execute actions in response. For example, turn on an exhaust fan if the humidity exceeds a certain level.
Overview A variable is a place where your home automation logic can store information that changes during the normal operation of your home and that can be used in other parts of your system: for instance, you can have a variable that represents whether your home is occupied or not - then you can have special automation logic that takes place when that variable changes. Indigo variables store values as plain text.
