    New code equivalent that is much more efficient:
    "allowOnStateChange": false,
    "protocol": "ZWave",
    "configured": true,
    "states": {
        "onOffState": true,
        "batteryLevel.ui": "100%",
        "batteryLevel": 100
    "subType": "",
    "globalProps": {
            "zwConfigVals": {},
            "zwShowWakeIntervalUI": true,
            "zwModelId": 0,
            "zwClassIds": [
                4,
                7,
                1
            "zwShowDumpDevToLog": false,
            "zwLibType": 3,
            "SupportsBatteryLevel": true,
            "zwProtoVersMajor": 4,
            "zwEndpointDevTypeMap": {},
            "userWakeInterval": 60,
            "indigoObjVersion": 10,
            "version": "5.01",
            "zwClassCmdMap": {
                "c134": 1,
                "c90": 1,
                "c133": 1,
                "c132": 2,
                "c89": 1,
                "c94": 1,
                "c128": 1,
                "c122": 1,
                "c115": 1,
                "c114": 1,
                "c113": 1,
                "c32": 1
            "SupportsOnState": true,
            "zwShowMainUI": true,
            "zwAppVersMinor": 1,
            "userPollInterval": 0,
            "zwDevSubIndex": 0,
            "zwEncryptClassCmdMap": {},
            "address": 17,
            "zwEndpointClassMap": {},
            "zwModelDefnVers": 0,
            "zwManufactureId": 0,
            "SupportsSensorValue": false,
            "zwAssociationsMap": {
                "g1": [
                    1
            "zwShowPollingUI": false,
            "zwWakeInterval": 60,
            "zwClassCmdBase": 0,
            "zwAppVersMajor": 5,
            "zwProtoVersMinor": 5,
            "zwNodeNeighbors": [
                1,
                15,
                16
            "userPollingEnabled": true
    "pluginProps": {},
    "buttonGroupCount": 0,
    "id": 854505717,
    "supportsAllOff": false,
    "errorState": "",
    "remoteDisplay": true,
    "energyAccumBaseTime": null,
    "displayStateValUi": "on",
    "subModel": "",
    "version": "5.01",
    "energyAccumTimeDelta": null,
    "batteryLevel": 100,
    "supportsSensorValue": false,
    "ownerProps": {
        "zwConfigVals": {},
        "zwModelId": 0,
        "zwClassIds": [
            4,
            7,
            1
        "zwLibType": 3,
        "version": "5.01",
        "zwClassCmdMap": {
            "c134": 1,
            "c90": 1,
            "c133": 1,
            "c132": 2,
            "c89": 1,
            "c94": 1,
            "c128": 1,
            "c122": 1,
            "c115": 1,
            "c114": 1,
            "c113": 1,
            "c32": 1
        "zwDevSubIndex": 0,
        "address": 17,
            "g1": [
                1
            1,
            15,
            16
    "description": "",
    "onState": true,
    "energyAccumTotal": null,
    "address": "17",
    "sharedProps": {},
    "folderId": 1145028206,
    "supportsOnState": true,
    "sensorValue": null,
    "energyCurLevel": null,
    "enabled": true,
    "displayStateValRaw": true,
This will be a python dictionary with all details about a device. One other feature to note here: by default, Python datetime objects are not serializable by the json module (odd oversight we believe). We have included a JSON encoder class that will solve this problem: [indigo.utils.IndigoJSONEncoder](object_model_reference.md#classes). Just specify that as the cls parameter to a json dump call and any datetime class that's encountered during JSON encoding will be correctly converted to a string in the resulting json string:
Device Base Class
Device Base Class Properties
address string No* 1.0 the address for the device. *Plugin developers can change this value for their plugin's devices.
sharedProps dictionary No 2.3 an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use dev.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you don't accidentally remove some other plugin's props).
version boolean No* 1.0 indicates the device's version as appropriate. *Plugin developers can change this value for their plugin's devices.
Protocol Enumeration
indigo.kProtocol
Value Description
*X10* identifies the device as an X10 device
State Image Sel Enumeration
API v1.18+ only:
indigo.kStateImageSel
Value Description
Closed overrides to show a generic sensor off icon (grey circle)
DoorSensorClosed overrides to show a door sensor closed icon (grey circle)
DoorSensorOpened overrides to show a door sensor opened icon (green circle)
Locked overrides to show a green lock icon
Opened overrides to show a generic sensor off icon (green circle)
Unlocked overrides to show a red lock icon
WindowSensorClosed overrides to show a window sensor closed icon (grey circle)
WindowSensorOpened overrides to show a window sensor opened icon (green circle)
Value Description
replaceOnServer() No 1.0 Because you can't directly modify a device's properties on the server, you have to get a local instance of the device and modify the writable properties as necessary. You then call this method and the device will be updated on the server and changes will be sent out to all connected clients. A few examples appear below this table.
replacePluginPropsOnServer(newPropsdict) Yes 1.0 If you need to make a change to your plugin's property dictionary that's stored as part of the device (see #About Plugin Properties below) you just use this method to replace the entire dict with a new one. A typical usage will be to get the property dictionary from the device, make changes to the dict, then use this method to store the new dict. A few examples appear below this table.
stateListOrDisplayStateIdChanged() Yes 1.0 Plugins can subclass the method getDeviceStateList() to provide dynamic state list definition information. The default implementation provides a static solution by retrieving the device state list definition from the Devices.xml file. Likewise, the method getDeviceDisplayStateId() can be used to dynamically determine which device state should be displayed in the State column of the main device table UI. The problem is that the Indigo Server only calls getDeviceStateList() and *getDeviceDisplayStateId()* at very specific times, like when a plugin device dialog is dismissed. So, call stateListOrDisplayStateIdChanged() on the device instance you need refreshed at any time and Indigo will then automatically call your plugin's getDeviceStateList() and getDeviceDisplayStateId() methods (or use the base implementation of looking up the list from Devices.xml) and update the Indigo Server (and all clients). This is particularly useful for plugin updates that need to add new device states to existing device instances created by older versions. In this case, the plugin will need to update the device instances by calling stateListOrDisplayStateIdChanged(). A likely place to do this type of instance level upgrading is inside your plugin's deviceStartComm() method.
setErrorStateOnServer('error string') Yes 1.0 The supplied string will show in the state column and turn it red. Passing *None* will clear it.
updateStateOnServer(key='keyName', value='Value', clearErrorState=True) Yes 1.0 Use this method to update the value of one of your device's states on the server. The server will propagate the change out to any connected clients and fire any triggers that are defined on that state. Pass "true" (default) or "false" on the clearErrorState parameter (not required) to have the error state of the device (set with setErrorStateOnServer above) cleared.
dev.replaceOnServer()
dev.name = "My New Name"
# Set Enabled/Disabled state
# Set Remote Display Flag
new_props = dev.pluginProps
new_props['address'] = "abc"
new_props['version'] = "123"  # Indigo UI Firmware field
dev=indigo.devices[123]
About Custom Device States
    <State id="playStatus">
    <State id="sep1">
    <State id="playlist">
        <ValueType>String</ValueType>
    <State id="album">
    <State id="artist">
    <State id="track">
    <State id="volume">
    <State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Commands (indigo.device.*)
All Off
indigo.device.allOff()
Enumerated Type Description
Insteon specify all INSTEON devices that support ON/OFF
X10 specify all X10 devices that support ON/OFF
ZWave specify all Z-Wave devices that support ON/OFF
HouseCodeA specify all X10 devices in house code A
HouseCodeB specify all X10 devices in house code B
HouseCodeC specify all X10 devices in house code C
HouseCodeD specify all X10 devices in house code D
HouseCodeE specify all X10 devices in house code E
HouseCodeF specify all X10 devices in house code F
HouseCodeG specify all X10 devices in house code G
HouseCodeH specify all X10 devices in house code H
HouseCodeI specify all X10 devices in house code I
HouseCodeJ specify all X10 devices in house code J
HouseCodeK specify all X10 devices in house code K
HouseCodeL specify all X10 devices in house code L
HouseCodeM specify all X10 devices in house code M
HouseCodeN specify all X10 devices in house code N
HouseCodeO specify all X10 devices in house code O
HouseCodeP specify all X10 devices in house code P
Beep
indigo.device.beep(123)
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices. You can't currently create devices that use the Insteon or Z-Wave protocol because of the complex synchronization needed during definition. Use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the "device" factory method.
| Command Syntax Examples | | --- | | python indigo.device.create(protocol=indigo.kProtocol.Plugin, address='F8', name='Device Name Here', description='Description Here', pluginId='com.mycompany.pluginId', deviceTypeId='myDeviceTypeId', props={'propA':'value', 'propB':'value'}, folder=1234) |
*address* No string the address of the X10 device - plugins must set an address property in their property dictionary
*description* No string the description of the device
*deviceTypeId* Yes string the id of the device type – defined by the plugin or one of the defined X10 devices.
*folder* No integer id or instance of the folder in which to put the newly created device
*pluginId* No string the plugin ID - defaults to your plugin's id if in a Server Plugin
*props* No dictionary this is the properties for the device - they will be inserted in to the pluginId's property space as supplied above. If you are creating a device of a type defined in a different plugin, it's that plugin's id and properties.
*protocol* Yes kProtocol the protocol for the device (indigo.kProtocol.Plugin or indigo.kProtocol.X10)
indigo.device.delete(123)
Enable/Disable
| Command Syntax Examples | | --- | | python indigo.device.enable(123, value=True) # enable indigo.device.enable(123, value=False) # disable |
Get Group List
               ID : 1280166770 (integer)
               ID : 106487666 (integer)
Ping Device
| Command Syntax Examples | | --- | | python result = indigo.device.ping(123, suppressLogging=True) if result["Success"]: indigo.server.log("%.3f seconds ping for %s" % (result["TimeDelta"]/1000.0, dev.name)) else: indigo.server.log("ping failed for %s" % (dev.name), isError=True) |
Status Request
Toggle
indigo.device.toggle(123)
Turn Off
indigo.device.turnOff(123)
Turn On
indigo.device.turnOn(123)
Unlock
indigo.device.unlock(123)
Lock
indigo.device.lock(123)
# Creating a device
    name="Office Lamp",
    address="F7",
# Getting a device
# Getting a device
if (myDevice.remoteDisplay):
all off
DimmerDevice
Device States
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
direct parameter No kAllDeviceSel enumerated value to indicate which devices to turn off, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description
All Lights On
indigo.dimmer.allLightsOn()
Brighten
indigo.dimmer.brighten(123)
*by* No integer relative amount to brighten by where brightness is 0-100
*delay* No integer number of seconds to delay before executing the brighten command
Dim
indigo.dimmer.dim(123)
*by* No integer relative amount to dim by where dimness is 0-100
*delay* No integer number of seconds to delay before executing the dim command
Set Brightness
*value* Yes integer absolute value to set the brightness to on a scale of 0-100
Set LED State
*index* Yes integer the index of the button. Recall that Python-based arrays are 0-based, so the index is also 0-based. That is, the first object in an array is object 0.
*value* Yes boolean True to turn on the LED, False to turn it off
*suppressLogging* No boolean True to suppress logging (defaults to False)
*updateStatesOnly* No boolean True to only update Indigo's internal state - no command will be sent to the KPL (defaults to False)
Set Color Levels
| Command Syntax Examples | | --- | | python indigo.dimmer.setColorLevels(device, redLevel, greenLevel, blueLevel, whiteLevel, whiteLevel2, whiteTemperature, delay, suppressLogging, updateStatesOnly ) |
*redLevel* No integer 0 - 100
*greenLevel* No integer 0 - 100
*blueLevel* No integer 0 - 100
*whiteLevel* No integer 0 - 100
*whiteLevel2* No integer 0 - 100
*whiteTemperature* No integer 1200 - 15000
*delay* No integer Defaults to 0.
*suppressLogging* No integer Defaults to *False*
*updateStatesOnly* No integer is an argument that exists on several device instance APIs that has Indigo update its device state/UI but does not have the corresponding action sent out to physical module. The use cases for this are pretty few, but sometimes you just want the internal state to update and can skip the actual command to the module. Defaults to *False*
# RGB value / 255 * 100
redLevel = 128
Set On State
# Getting a device
    (myDevice.onState)):
myDevice.folderId
# OR
MultiIODevice
Device States
Commands (indigo.iodevice.*)
Set Binary Output
*index* Yes integer 0-based index of the output to change - should be less than the *binaryOutputCount* property of the device
*value* Yes boolean True to turn the output on, False to turn it off
        index=1,
        value=False)
SensorDevice
  • X10 Motion Sensors
Commands (indigo.sensor.*)
Set On State
-- none --
RelayDevice
*onState* boolean No indicates whether the device is on - shortcut to dev.states['onOffState']
Device States
Commands (indigo.relay.*)
Set LED State
# Toggle the device
SpeedControlDevice
*speedIndex* integer No indicates the current speed index for devices that support some fixed # of speeds - shortcut to dev.states['speedIndex']
*speedIndexCount* integer No indicates the number of indexes available for this device (defaults to 4)
*speedLevel* integer No indicates the level the device is set to (0-100) - shortcut to dev.states['speedLevel']
Device States
Decrease Speed Index
Decreases the speed index.
*by* No integer the number of index positions to decrease by. Defaults to 1 if not specified.
*delay* No integer delays the command by the specified number of seconds. Defaults to no delay if not specified.
Increase Speed Index
Increases the speed index.
*by* No integer the number of index positions to increase by. Defaults to 1 if not specified.
Set Speed Index
*value* Yes integer index position to set the index to.
Set Speed Level
*value* Yes integer level of the motor control, from 0-100.
SprinklerDevice
activeZone integer No 1.0 the 1-based index of the active zone (None=all zones off, 1=zone 1, 2=zone 2, ...). Note this property has undergone changes in name (previously called activeZoneIndex) as well as semantics (previously the index being 0-based).
zoneEnableList list of boolean No 1.13 list of booleans, starting at zone 1 through zone [*zoneCount*], that specify if a given zone is enabled (has a maximum zone duration > 0).
zoneNames list of string No 1.0 list of zone names, starting at zone 1 through zone [*zoneCount*]. You must include *zoneCount* strings in the list.
zoneMaxDurations list of floats No 1.0 list of zone durations in minutes, starting at zone 1 through zone [*zoneCount*]. You must include *zoneCount* integers in the list.
zoneScheduledDurations list of floats No 1.0 list of currently active zone durations in minutes if a schedule is running (empty list if no schedule is running), starts at zone 1 through zone [*zoneCount*]
pausedScheduleZone integer No 1.16 the 1-based index of the paused sprinkler zone index (None=schedule not paused, 1=zone 1 paused, 2=zone 2 paused, ...).
Device States
Commands (indigo.sprinkler.*)
Next Zone
Pause Schedule
indigo.sprinkler.pause(123)
Previous Zone
Resume Schedule
indigo.sprinkler.resume(123)
Run Schedule
Run a sprinkler schedule.
indigo.sprinkler.run(123, schedule=[10, 15, 8, 0, 0, 0, 0, 0])
Stop Schedule
indigo.sprinkler.stop(123)
Set Active Zone
*index* Yes integer 1-based index of the zone to turn on
# run schedule
    schedule=[10,15,8, 0, 0, 0, 0, 0])
ThermostatDevice
Thermostats have a wide variety of capabilities that we’ve tried to boil down to some specifics. They can have multiple temperature and humidity sensors and--depending on the device capabilities and region--may have a fan mode, an HVAC mode (heating, cooling, etc) and associated setpoints. Note: some thermostats don’t support getting the equipment state values: coolIsOn, fanIsOn, heatIsOn, dehumidifierIsOn, and humidifierIsOn. For those thermostats those properties will always be False.
To check whether the thermostat device actually supports the coolIsOn and heatIsOn properties, one can check: support_heat_and_cool = dev.pluginProps.get("ShowCoolHeatEquipmentStateUI", False)
Plugin Capabilities
These pluginProps can be updated by a plugin to describe the capabilities for a particular thermostat instance. Some of these are useful to provide a higher-level abstraction for accessing/changing thermostat properties or states. | Property | Type | Writeable | Description | | --- | --- | --- | --- | | NumTemperatureInputs | Integer | Yes | should range between 1 and 3 | | NumHumidityInputs | Integer | Yes | should range between 0 and 3 | | SupportsHeatSetpoint | Boolean | Yes | True or False | | SupportsCoolSetpoint | Boolean | Yes | True or False | | SupportsHvacOperationMode | Boolean | Yes | True or False | | SupportsHvacFanMode | Boolean | Yes | True or False | | ShowCoolHeatEquipmentStateUI | Boolean | Yes | True or False |
Some of these are reflected as attributes in the device instance as well: | Attribute | Read-Only | | --- | --- | | dev.hvacMode | Yes | | dev.fanMode | Yes | | dev.coolSetpoint | Yes | | dev.heatSetpoint | Yes | | dev.temperatureSensorCount | Yes | | dev.temperatures | Yes | | dev.humiditySensorCount | Yes | | dev.humidities | Yes | | dev.coolIsOn | Yes | | dev.heatIsOn | Yes | | dev.fanIsOn | Yes | | dev.dehumidifierIsOn | Yes | | dev.humidifierIsOn | Yes | | dev.supportsHvacFanMode | Yes | | dev.supportsHvacOperationMode | Yes | | dev.supportsCoolSetpoint | Yes | | dev.supportsHeatSetpoint | Yes |
Fan Mode Enumeration
*indigo.kFanMode*
Value Description
AlwaysOn signal the fan that it should be running continuously
Auto signal the fan that it should only run when the HVAC system needs it to be running
HVAC Mode Enumeration
*indigo.kHvacMode*
Value Description
Cool the hvac system is only reacting to cool setpoints
HeatCool the hvac system is reacting to both cool and heat setpoints
Heat the hvac system is only reacting to and heat setpoints
Off the hvac system is turned off
ProgramHeatCool the hvac system is executing it’s built-in automatic program, which usually responds to both heat and cool setpoints
ProgramCool the hvac system is executing it’s built-in cooling program
ProgramHeat the hvac system is executing it’s built-in heating program
Device States
Decrease Cool Setpoint
| Command Syntax Examples | | --- | | python indigo.thermostat.decreaseCoolSetpoint(123) indigo.thermostat.decreaseCoolSetpoint(123, delta=5) |
*delta* No integer Number of degrees to decrease the cool setpoint. If unspecified, the change will be equal to one degree.
Decrease Heat Setpoint
| Command Syntax Examples | | --- | | python indigo.thermostat.decreaseHeatSetpoint(123) indigo.thermostat.decreaseHeatSetpoint(123, delta=5) |
*delta* No integer Number of degrees to decrease the heat setpoint. If unspecified, the change will be equal to one degree.
Increase Cool Setpoint
| Command Syntax Examples | | --- | | python indigo.thermostat.increaseCoolSetpoint(123) indigo.thermostat.increaseCoolSetpoint(123, delta=5) |
*delta* No integer Number of degrees to increase the cool setpoint. If unspecified, the change will be equal to one degree.
Increase Heat Setpoint
| Command Syntax Examples | | --- | | python indigo.thermostat.increaseHeatSetpoint(123) indigo.thermostat.increaseHeatSetpoint(123, delta=5) |
*delta* No integer Number of degrees to increase the heat setpoint. If unspecified, the change will be equal to one degree.
Set Cool Setpoint
*value* Yes integer the absolute temperature of the setpoint
Set Fan Mode
Adjust the fan mode.
*value* Yes kFanMode the operating mode for the fan
Set Heat Setpoint
Set HVAC Mode
Adjust the HVAC mode.
*value* Yes kHvacMode HVAC mode identifier
# set the heat setpoint to 78
