Getting Started Guide
Welcome to Indigo 2023.2!
Z-Wave
  • Thermostats, and
  • Locks.
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
The Indigo 2023.2 application can be found here:
/Applications/Indigo 2023.2.app
/Library/Application Support/Perceptive Automation/Indigo 2023.2/
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2023.2 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
  1. Shut down the Indigo Server by selecting the Indigo 202x.y->Stop Server menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running.
  2. Quit the Mac client via the Indigo 202x.y->Quit Indigo menu item.
Indigo plugins can now run under Python 3. Check the Plugin Store and Plugin user forum for updates to the 3rd party plugins you are using.
  1. Deactivate Indigo on your Mac by selecting the Indigo 2023.2->License Details... menu item and clicking the Deactivate License button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first)
  2. Copy this folder over to the new Mac: /Library/Application Support/Perceptive Automation/Indigo 2023.2/ (if restoring from a backup, you'll need to locate this folder in whatever backup system you use)
  3. Install Indigo 2023.2 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
It'll open the correct folder and you'll see the "Perceptive Automation" folder - that's the one you want to copy over. That should get all of your customizations and allow the installer to update anything as necessary. You may also need to install the drivers for the technology you use - see the appropriate section below for details.
If you're moving Indigo to a Mac with a different architecture, read on...
When you move your Indigo installation from one macOS architecture to another (for example from an Intel-based Mac to an M-series Mac) -- especially if you use Migration Assistant or Time Machine -- you will likely need to take additional steps because many Python libraries are compiled to the specific hardware they're installed on. One signal that this has become an issue is an error message like:
In some cases, you may wish to transfer your license to another user--for example, if you sell your home along with the Indigo system. We are happy to assist you in this process, and there are only a few steps you need to take. It is important that the steps be taken in this order:
  4. When we're done with that, the new owner will need to deactivate/reactivate the license by selecting the Indigo 20XX.Y -> License Details... menu item and first clicking on the Deactivate License button then--in the resulting dialog--log in using the username/password they created in the step 1 above.
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2023.2->License Details... menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Deactivate Sheet Image
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2023.2 menu if the server is still running before you quit the Indigo Mac Client).
  • Optional : If you don't use Python 3.11 for anything (other than Indigo 2023.2), you can delete this folder: /Library/Frameworks/Python.framework/Versions/3.11 and this file: /Library/Frameworks/Python.framework/Versions/Current Note: this will leave any other version of Python alone including any previous versions that older Indigo installs may have installed (if you plan on reverting to an older version). To completely remove all Python installations that any version of Indigo may have installed, just delete the entire Python framework: /Library/Frameworks/Python.framework
Uninstalling the Mac Client
  • ~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-2023-2.plist
  • ~(your user folder)/Library/Preferences/Indigo 2023.2 Client Prefs.indiPref
  • ~(your user folder)/Library/Preferences/Indigo 2023.2 Client Settings.indiPref
To uninstall older versions but leave 2023.2 installed correctly, delete these:
  • Indigo 2023.1:
  • Indigo 2022.2:
  • Indigo 2022.1:
  • Indigo 2021.2:
  • Indigo 2021.1:
  • Indigo 7.5:
  • Indigo 7.4:
  • Indigo 7.3:
  • Indigo 7.2:
  • Indigo 7.0 and 7.1:
    • /Applications/Indigo 7.app
    • /Applications/Indigo 6.app
Starting Indigo Server
  1. Double click the Indigo 2023.2 application (/Applications/Indigo 2023.2.app).
  2. If this is the first time to run Indigo 2023.2 on this Mac, then press the Start Local Server... button in the connection status window.
  3. If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the Indigo 2023.2->Start Local Server... menu item.
Start Server Dialog Image
Standard startup mode
Custom single app startup
Starting the Server
Login Dialog Image
Remote Indigo Access
Modifying Firewall Settings
Firewall Prompt Image
IPH Firewall Prompt Image
Network WiFi Image
Network Wired Image
  2. Double click the Indigo 2023.2 application (inside /Applications/Indigo 2023.2.app) on the remote Mac.
  4. If you are wanting to connect to a different Indigo Server, then select the Indigo 2023.2->Connect to Remote Server... menu item.
  7. Press the Connect button.
Client Connect Dialog Image
http://192.168.1.23:8176/
Interfaces Menu Image
Interfaces Tab Image
Managing Plugins
Installing/Updating Plugins
  9. NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the Open With menu item, then select Indigo 2023.2.Open With Menu Item Image
  11. Done!
Plugin Configuration Dialog
Plugin Menus in Indigo
Main Plugins Menu
Plugins Menu Image
Individual Plugin Submenu
Plugin Enabled Submenu Image
The next section contains:
Other Menus with Plugin Items
Plugin New Device Image
Plugin Events Image
Plugin Actions Image
Plugins Tab Image
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2023.2->Preferences... menu item and clicking the Plugins tab or by selecting the Plugins->Manage Plugins... menu item discussed above.
Uninstalling a Plugin
  2. Switch back to Indigo and shut down the Indigo Server by selecting the Indigo 2023.2->Stop Server menu item in the Mac client (you can leave the client app running).
  4. Switch back to the Indigo 2023.2 Mac client and click on the Start Local Server... button in the Server Connection Status dialog.
Location Services Image
Longitude Latitude Tab Image
  • Choose the Indigo 2023.2->Preferences... menu item, then make sure the Sunset & Sunrise tab is selected.
General Preferences Tab Image
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2023.2->Preferences... menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2023.2->Check for Updates... menu item.
Where to Go Next
