Indigo Object Model Reference
About this Reference
# some code here
# that does something
!!! warning "NOTE" Indigo uses Python v2.7. Different versions of macOS might have newer versions of python installed, so make sure that you're using Python 2.7 for your development or you could get a nasty surprise when you turn your code into a plugin (if you're developing code outside of the plugin architecture).
| Term | Meaning |
Introduction
For Scripters and Developers:
For Developers:
| Devices | ||||
| Schedule | ||||
Schedule (indigo.Schedule) |
| Triggers | ||||
| DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger) | indigo.devStateChange.* | manipulate a device state change trigger | ||
| Action Groups | ||||
| Variables | ||||
| General Commands | ||||
There are a few classes that are special. One is Action and it’s subclasses (collectively referred to as "actions"). Why are these classes different? Because outside of the trigger, schedule, action group, or control page that they’re associated with they aren’t individually addressable in the IndigoServer: for instance, there is no way to identify an action without first identifying the trigger that it’s associated with.
IOM Class Hierarchy
Indigo specific data types
- keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
python_dict = my_indigo_dict.to_dict() # recursively convert an indigo.Dict instance to a python dict instance
python_list = my_indigo_list.to_list() # recursively convert an indigo.List instance to a python list instance
Built-in objects
| Object | Description |
The other additional method is subscribeToChanges(). This method doesn't return anything - rather, it tells the IndigoServer that your plugin wants notification of all changes to the specific object type. Use this method sparingly as it causes a significant amount of traffic between IndigoServer and your plugin. What kind of plugins would use this? One good example is a logging plugin - one that's logging activity within Indigo (like our SQL Logger). Another example is a plugin that's doing some kind of scene management - you would probably want to issue a indigo.devices.subscribeToChanges() at plugin start so that you'll always be notified when any device changes - you can then determine if your scene "state" has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change.
Object Events
Lower-level Events
if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
# do stuff with dev here
Triggers also have filters:
| Filter | Description |
for var in indigo.variables:
# all variables
Common Python Exceptions
| Possible Exceptions | |
ArgumentError |
IndexError |
KeyError |
PluginNotFoundError |
TypeError |
ValueError |
Classes and Commands
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
Object Dictionaries
>>> dev = indigo.devices[123]
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
<'indigo.Device'>
>>> dev_dict = dict(dev)
<class 'dict'>
- Device classes
- Trigger classes
- Action classes
- Action Group class
- Variable class
- Folder class
Utility Classes and Functions
Classes
| Name | Base | Description |
FileNotFoundError |
Exception |
This is a useful exception if you handle files in any way. There is no built-in processing to catch such exceptions, it's just a useful exception to use. |
IndigoJSONEncoder |
JSONEncoder |
Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder)) |
Functions
Return Static File
| Parameters | |||
file_path |
Yes | string | a string that represents the path to a file |
*status* |
No | int | the HTTP status code to return, defaults to 200 |
*path_is_relative* |
No | boolean | is the path a full path or relative to the plugin, defaults to True |
*content_type* |
No | string | a string to return as the mime type of the content, returns the appropriate type based on the file extension if none is specified |
"status": 404,
"headers": {
"Content-Type": "text/html"
"file_path": "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
| Parameters | |||
address |
Yes | string | a string that represents an email address |
