Python Packages
Python Packages and Indigo
This page describes how Indigo 2023.2.0 works with Python, specifically with respect to packages/libraries.
Indigo 2023.2 shipped with API version 3.4 and is the first version to contain support for Python version 3 (check the Api Version Chart to see what version of the API is available in which Indigo versions). With this version of the API, Python 3 is now automatically installed as part of the Indigo installer. For Indigo 2023.2, we are including Python 3.11.6.
The Indigo 2023.2 installer includes the Python installer (including Intel and Apple Silicon support) from https://www.python.org - the official Mac installers for the Python language. As a result, any installs of other versions of Python from that website may cause unexpected results in Indigo and potentially cause it to break. We've taken all precautions we can to try and avoid conflicts, but there is only so much we can do. So please use caution when installing other Python versions to your server machine. If you have any questions about other Python versions, post your questions on our forums.
Installing Additional Python Packages with Indigo 2023.2
As noted above, Indigo 2023.2 ships with Python 3.11 and which contains several modules in addition to Python's standard core modules. The specific modules installed with each version of Python are listed below. However, in some instances, you may need to manually install one or more additional Python packages to support a third-party plugin or your own custom scripts. The manner in which this is done, depends on the Indigo API version that the plugin supports.
user@my mac ~ % pip3 list
Package            Version
astroid            2.9.3
certifi            2021.10.8
charset-normalizer 2.0.11
cycler             0.11.0
fonttools          4.29.1
user@my mac ~ %
!!! note "Note" Some Python packages -- and specifically those that are included in IPH3 as described below -- will not appear in the pip3 list output.
Version: 2.27.1
Author: Kenneth Reitz
License: Apache 2.0
Required-by:
user@my mac ~ %
Particularly helpful in the show output is the dependencies information -- both what the package requires and what requires the package. Note that the dependencies information may not include information about packages that are included with the IPH.
Installing additional Python versions on the Indigo 2023.2 server machine is *NOT* recommended (see above). Installing additional Python modules should only be done when necessary.
The PYTHONPATH for IPH3 is:
zeroconf==0.130.0
websocket-client==1.7.0
Troubleshooting:
Manual Installation by User
Using pip:
If you're going to instruct users to install needed packages individually, they should use a command similar to: pip3 install package -t /Path/To/Plugin/Contents/Packages/ or, if a specific version is required, use: pip3 install package==1.2.3 -t /Path/To/Plugin/Contents/Packages/ which will install the libraries to the specified folder that exists in your plugin bundle. It is strongly recommended that you use the Packages folder as this may be required in future versions of Indigo.
Logging Import Errors
import_errors = []
    import zeroconf
except ImportError:
def startup(self):
    if len(import_errors):
        for i in import_errors:
        self.logger.error(msg)
Access to IPH3 Libraries
There are some important implications that result from having some libraries included in the IPH3. Namely, those packages will be available to plugins, Indigo scripts (embedded and linked), the Indigo python shell (from the menu item or by doing indigo-host in a terminal window), but IPH3 libraries will *NOT* be available if you start the python interpreter directly (by doing python2 or python3 in a terminal window). Refer to this chart to determine accessibility:
Method Access to\ IPH3 Libraries
plugins yes
embedded scripts yes
linked scripts yes
Python Packages for Scripters
  1. IndigoPluginHost3
  • /Library/Application Support/Perceptive Automation/Scripts -- any linked scripts you use for Indigo Schedules and Actions using the "Execute Script (Script and File Actions" command should be stored in this folder.
  • /Library/Application Support/Perceptive Automation/Python3-includes -- any modules you have developed (a module is a file that contains classes, functions, constants, etc.) that you want to share across multiple scripts, should be stored in the /Library/Application Support/Perceptive Automation/Python3-includes folder. (Indigo versions prior to 2022 should use the /Library/Application Support/Perceptive Automation/Python2-includes folder).
If Something Goes Wrong
To provide users with a measure of safety regarding the Python packages that Indigo installs, the Indigo installer also includes the capacity to repair the Python installation if something should become damaged. For example, if a user were to accidentally upgrade one of the Python packages -- and as a result cause the Indigo server to stop functioning properly -- re-running the Indigo installer may be able to bring things back under control. There's a few things you can try should you run into conflicts between Python versions.
Indigo 2023.2 ships with support for the following Python 3 packages in addition to the packages installed with the standard Python framework. Generally, if earlier versions of the listed packages are installed at the location Indigo uses, they will be upgraded to the version numbers below. The >= symbol means the version installed by Indigo may be newer than the version listed, but will not be older. pyserial is also installed but is installed differently than the other packages listed above and should be unmodifiable.
PIP installed by Indigo\ PIP Modifiable (but not recommended)
Package Version
certifi 2023.11.17
charset_normalizer 3.3.2
cryptography 41.0.7
- cffi >= 1.16.0
- pycparser >= 2.21
cycler 0.12.1
dictdiffer 0.9.0
future 0.18.3
httpx 0.25.2
- anyio >= 4.1.0
- certifi >= 2023.11.17
- h11 >= 0.14.0
- httpcore >= 1.0.2
- idna >= 3.6
- sniffio >= 1.3.0
idna 3.6
janus 1.0.0
- typing_extensions >= 4.8.0
Jinja2 3.1.2
kiwisolver 1.4.5
MarkupSafe 2.1.3
matplotlib 3.8.2
- fonttools >= 4.45.1
- contourpy >= 1.2.0
numpy 1.26.2
oauthlib 3.2.2
Pillow 10.1.0
pudb 2023.1
- jedi >= 0.19.0
- packaging >= 23.2
- parso >= 0.8.3
- pygments >= 2.17.2
- urwid >= 2.3.4
- urwid-readline >= 0.13
py-applescript 1.0.3
pyaes 1.6.1
pyobjc 10.0
pyparsing 3.1.1
python-dateutil 2.8.2
requests 2.31.0
requests-oauthlib 1.3.1
sanic 23.6.0
- aiofiles >= 23.2.1
- httptools >= 0.6.1
- html5tagger >= 1.3.0
- multidict >= 6.0.4
- sanic-routing >= 23.6.0
- sanic-session >= 0.8.0
- tracerite >= 1.1.1
- ujson >= 5.8.0
- uvloop >= 0.19.0
- websockets >= 12.0
scipy 1.11.4
six 1.16.0
urllib3 2.1.0
xmljson 0.2.1
pyserial 3.5
