Variables
id |
integer | the unique id of the variable, assigned on creation by IndigoServer |
folderId |
integer | the unique id of the folder this variable is in (0 if it's not in a folder) - use moveToFolder() method to change |
name |
string | the name of the variable - no two variable can have the same name |
readOnly |
string | is the variable read only - currently only the isDaylight variable is read only |
remoteDisplay |
boolean | should this variable be displayed in remote clients (IWS, Indigo Touch, etc) |
value |
string | the unicode string value of the variable |
Class Method
| bool | Boolean | True will be returned if the value is one of these: "true", "on", "yes", and "1". False will be returned if the value is one of these: "false", "off", "no", and "0". If no default value is specified and the value can't be successfully converted, the method will return False. |
Remember that accessing the value property of a variable object (*var.value*) will return a unicode string object so you don't need a conversion for that.
Class Method Examples
# Get a variable
unicodeValue = var.value
# Getting the boolean value
# Getting the integer value
# Getting the float value
Commands (indigo.variable.*)
indigo.variable.create("VariableName", value="Var Value", folder=843920) |
| Parameters | |||
folder |
No | integer | id or instance of the folder in which to put the newly created device - defaults to 0 (no folder) |
name |
Yes | string | the name of the variable |
value |
No | string | the value of the variable |
Delete the specified folder.
indigo.variable.delete(123) |
| Parameters | |||
indigo.variable.duplicate(123, duplicateName="NewName") |
| Parameters | |||
duplicateName |
No | string | name for the newly duplicated variable |
depDict = indigo.variable.getDependencies(123) |
| Parameters | |||
ID : 552463741 (integer)
ID : 296710860 (integer)
indigo.variable.moveToFolder(123, value=987) |
| Parameters | |||
value |
Yes | integer | id or instance of the folder to move the variable to |
indigo.variable.displayInRemoteUI(123, value=True) |
| Parameters | |||
value |
Yes | boolean | True to display the variable on remote user interfaces or False to hide it |
Update Value
indigo.variable.updateValue(123, value="New Value") |
| Parameters | |||
value |
Yes | string | the new value for the variable |
| Python | AppleScript (which will be deprecated in Indigo 7.2 and later) |
| ```python | |
| # Create a new variable | |
| newVar = indigo.variable.create("fooName", "fooMonster") |
Updating value via command space function:
indigo.variable.updateValue(newVar, "asleep789") newVar.refreshFromServer() # refresh needed to update local's .value
changing name property
newVar.name = "goodName" newVar.replaceOnServer()
changing name and values properties:
newVar.name = "goodName2" newVar.value = "searchingForWaldo" newVar.replaceOnServer()
Getting a variable using it's ID
Getting a variable using it's name
|text
-- Create a new variable
-- Update value set value of newVar to "asleep789"
-- Changing name property set name of newVar to "goodName" set newVar to variable "goodName" -- when the name changes, you have to get a fresh reference
-- Changing name and values properties set name of newVar to "goodName2" set newVar to variable "goodName2" -- when the name changes, you have to get a fresh reference set value of newVar to "searchingForWaldo"
delete variable "goodName2"
You can't get a variable using its ID in AppleScript
set someVar to variable named "MyVarName" ``` |
