About this Reference
# some code here
# that does something
You should be able to tell from the context if it's Python code or, sometimes, AppleScript (which will be deprecated in Indigo 7.2 and later), if we're comparing how to do something.
| Term | Meaning |
Introduction
For Scripters and Developers:
For Developers:
| Devices | ||||
| Schedule | ||||
Schedule (indigo.Schedule) |
| Triggers | ||||
| Action Groups | ||||
| Variables | ||||
| General Commands | ||||
IOM vs AppleScript Dictionary
If you are a user of the Indigo AppleScript Dictionary (AppleScript support will be deprecated in Indigo 7.2 and later), you may have certain expectations set about how you would use the IOM in Python. While there are similarities, there are also some non-trivial differences. Most of these will become apparent in the following sections, but we’d like to outline a few here.
First, and most obvious, is the nature of most objects in the IOM as we discussed earlier - using copies and updating the server when you change the properties. In AppleScript, when you alter an object’s property the change is instantaneous since the script is running in the IndigoServer process. That significant architectural difference is what led us to the split between objects and the commands that work on them.
item 1 of myArray
myArray[0]
IOM Class Hierarchy
Indigo specific data types
- keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
Built-in objects
| Object | Description |
The other additional method is subscribeToChanges(). This method doesn't return anything - rather, it tells the IndigoServer that your plugin wants notification of all changes to the specific object type. Use this method sparingly as it causes a significant amount of traffic between IndigoServer and your plugin. What kind of plugins would use this? One good example is a logging plugin - one that's logging activity within Indigo (like our SQL Logger). Another example is a plugin that's doing some kind of scene management - you would probably want to issue a indigo.devices.subscribeToChanges() at plugin start so that you'll always be notified when any device changes - you can then determine if your scene "state" has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change. Use the lower-level subscribeToIncoming() and subscribeToOutgoing() methods in the indigo.insteon and indigo.x10 command spaces to see commands regardless of their effect on device state.
Iterating Object Lists
| Python | AppleScript (which will be deprecated in Indigo 7.2 and later) |
| ```python | |
| for dev in indigo.devices: | |
| # do stuff with dev here | |
|text |
| repeat with dev in every device | |
| -- do stuff with dev here | |
| end repeat | |
Here's a list of all device filters: | Filter | Description | | --- | --- | | indigo.zwave | include Z-Wave devices | | indigo.insteon | include INSTEON devices | | indigo.x10 | include X10 devices | | com.mycompany.myplugin | include all devices defined by a plugin | | indigo.responder | include devices whose state can be changed | | indigo.controller | include devices that can send commands | | indigo.iodevice | input/output devices | | indigo.dimmer | dimmer devices | | indigo.relay | relay, lock, or other 2 state devices | | indigo.sensor | sensor devices (motion, temperature, etc.) | | indigo.speedcontrol | multi-speed controlled device (fans, motors, etc.) | | indigo.sprinkler | sprinklers | | indigo.thermostat | thermostats | | self | include devices defined by the calling plugin | | self.myDeviceType | include myDeviceType's devices defined by the calling plugin | | com.company.plugin.xyzDeviceType | include xyzDeviceType's defined by another plugin |
Triggers also have filters:
for var in indigo.variables:
# all variables
Common Python Exceptions
| Possible Exceptions | |
ArgumentError |
IndexError |
KeyError |
PluginNotFoundError |
TypeError |
ValueError |
Classes and Commands
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
- Device classes
- Trigger classes
- Action classes
- Action Group class
- Variable class
- Folder class
