- To modify an device's definition get a copy of the device, make the necessary changes, then call
myDevice.replaceOnServer()
- To update a plugin's props on a device on the server, call
myDevice.updateStateOnServer(key='keyName', value='Value') -
To change multiple device states on the server at one time, use
myDevice.updateStatesOnServer(update_list)passing a dictionary that looks like this:New code equivalent that is much more efficient:
Device Base Class
Device Base Class Properties
| Property | Type | Writable | Min API | Description | |
address |
string | No | 1.0 | the address for the device | |
batteryLevel |
integer | No | 1.0 | battery level for the device - None if the device doesn't support battery operation - shortcut for dev.states['batteryLevel'] |
buttonGroupCount |
integer | No | 1.0 | the number of groups (or buttons in the case of the RemoteLinc and ControLinc) that the controller supports - currently used only for INSTEON devices - 0 for other devices | |
configured |
boolean | No | 1.0 | true if the device has been fully configured - if it's a plugin device use this to make sure that the device's config dialog has been run at least once. | |
description |
string | Yes | 1.0 | a description of the device as specified by the user | |
deviceTypeId |
string | No | 1.0 | the typeId specified in the Devices.xml (or it’s documentation) - only used for plugin defined devices | |
displayStateId |
string | No | 1.15 | main display stateId key which can be used as a key into states[] property below | |
displayStateValRaw |
boolean integer string or none | No | 1.15 | raw value of main display state (ex: 72.0) | |
displayStateValUi |
string | No | 1.15 | UI value (string) of main display state (ex: '72.0°F' ) | |
displayStateImageSel |
kStateImageSel | No | 1.18 | an enumeration specifying which state image icon is shown in Indigo Touch and Indigo client UI - see state image sel enumeration below for possible values | |
enabled |
boolean | No | 1.0 | is the device enabled - set using the indigo.device.enable() method |
energyCurLevel |
float | No | 1.11 | current Wattage energy being used by the device (None if not supported) | |
energyAccumTotal |
float | No | 1.11 | current accumulated energy used since last base time specified in energyAccumBaseTime (None if not supported) |
energyAccumBaseTime |
datetime | No | 1.11 | the base time from which to calculate the energy total (energyAccumTotal) (None if not supported) |
energyAccumTimeDelta |
integer | No | 1.11 | the time delta in seconds since the last base time (None if not supported) | |
errorState |
string | No | 1.0 | the string that represents the current error for the device, empty string if there is no error | |
folderId |
integer | No | 1.0 | the unique ID of the folder this device is in (0 if it's not in a folder) - use moveToFolder() method to change |
globalProps |
dictionary | No | 1.0 | an indigo.Dict() representing all name/value pairs associated with this device - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
id |
integer | No | 1.0 | id or instance of the device, assigned on creation by IndigoServer | |
lastChanged |
datetime | No | 1.0 | the last date/time that the device was changed - populated by IndigoServer | |
model |
string | No | 1.0 | the model name of the device - defined either by Indigo based on type or by the plugin's device definition | |
name |
string | Yes | 1.0 | the unique name of the device - no two devices can have the same name | |
ownerProps |
dictionary | No | 1.20 | an indigo.Dict() representing the name/value pairs defined by the plugin that created the device - this is a shortcut into the owner plugin's globalProps data |
pluginId |
string | No | 1.0 | if protocol is Plugin, the string ID for the plugin |
pluginProps |
dictionary | No | 1.0 | an indigo.Dict() representing the name/value pairs defined by your plugin for the device - plugin developers should publish this information if you want other plugins/scripts to create devices of this type - see About Plugin Properties below for details - use replacePluginPropsOnServer() method to change |
protocol |
kProtocol | No | All | an enumeration specifying the kProtocol of the device - see protocol enumeration below for possible values | |
remoteDisplay |
boolean | Yes | 1.0 | should this device be displayed in remote clients (IWS, Indigo Touch, etc) - may also be set with indigo.device.displayInRemoteUI() |
sharedProps |
dictionary | No | 2.3 | an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use dev.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you do not accidentally remove some other plugin's props). |
states |
dictionary | No | 1.0 | returns an indigo.Dict() of device states - the key is the state id and the value is the value. Note that enumerated states will have not only the state, but also each option for the state. So, for instance, if I had a state called status and it had 3 options (online, offline, error), then you'd not only have status as a key, but also status.online, status.offline, and status.error as keys in the dictionary. This is so that you can test each state enumeration independently in trigger actions (e.g. status.online is true). | |
supportsAllLightsOnOff |
boolean | No | All | indicates that this device should react to all lights On and all lights Off commands - always False for plugin defined devices | |
supportsAllOff |
boolean | No | 1.0 | indicates that this device should react to all Off commands - always False for plugin defined devices | |
supportsOnState |
boolean | No | 2.2 | indicates that the device has an on state | |
supportsStatusRequest |
boolean | No | 1.0 | indicates if the device supports querying the status - always False for plugin defined devices |
Protocol Enumeration
| indigo.kProtocol | |
Value |
Description |
Insteon |
identifies the device as an INSTEON device |
*X10* |
identifies the device as an X10 device |
ZWave |
identifies the device as an Z-Wave device |
Plugin |
identifies the device as a being defined by a plugin |
State Image Sel Enumeration
API v1.18+ only:
| indigo.kStateImageSel | |
Value |
Description |
Auto |
specifies Indigo Server to pick a device image icon that best represents this device class and/or state value (default for all devices) |
None |
overrides to show no device image icon |
Error |
overrides to show an error device image icon |
Custom |
overrides to show a plugin defined custom image icon (not yet implemented) |
PowerOff |
overrides to show a power off icon |
PowerOn |
overrides to show a power on icon |
DimmerOff |
overrides to show a dimmer or bulb off icon |
DimmerOn |
overrides to show a dimmer or bulb on icon |
FanOff |
overrides to show a fan off icon |
FanLow |
overrides to show a fan on (low) icon |
FanMedium |
overrides to show a fan on (medium) icon |
FanHigh |
overrides to show a fan on (high) icon |
SprinklerOff |
overrides to show a sprinkler off icon |
SprinklerOn |
HvacOff |
overrides to show a thermostat off icon |
HvacCoolMode |
overrides to show a thermostat in cool mode icon |
HvacHeatMode |
overrides to show a thermostat in heat mode icon |
HvacAutoMode |
overrides to show a thermostat in auto mode icon |
HvacFanOn |
overrides to show a thermostat with fan blower on only icon |
HvacCooling |
overrides to show a thermostat that is cooling icon |
HvacHeating |
overrides to show a thermostat that is heating icon |
SensorOff |
overrides to show a generic sensor off icon (gray circle) |
SensorOn |
overrides to show a generic sensor on icon (green circle) |
SensorTripped |
overrides to show a generic sensor tripped icon (red circle) |
EnergyMeterOff |
overrides to show an energy meter off icon |
EnergyMeterOn |
overrides to show an energy meter on icon |
LightSensor |
overrides to show a light meter off icon |
LightSensorOn |
overrides to show a light meter on icon |
MotionSensor |
overrides to show a motion sensor icon |
MotionSensorTripped |
overrides to show a motion sensor tripped/activated icon |
DoorSensorClosed |
overrides to show a door sensor closed icon |
DoorSensorOpened |
overrides to show a door sensor opened icon |
WindowSensorClosed |
overrides to show a window sensor closed icon |
WindowSensorOpened |
overrides to show a window sensor opened icon |
TemperatureSensor |
overrides to show a temperature sensor icon |
TemperatureSensorOn |
overrides to show a temperature sensor on icon |
HumiditySensor |
overrides to show a humidity sensor icon |
HumiditySensorOn |
overrides to show a humidity sensor on icon |
HumidifierOff |
overrides to show a humidifier turned off icon |
HumidifierOn |
overrides to show a humidifier turned on icon |
DehumidifierOff |
overrides to show a dehumidifier turned off icon |
DehumidifierOn |
overrides to show a dehumidifier turned on icon |
TimerOff |
overrides to show a timer off icon |
TimerOn |
overrides to show a timer on icon |
AvStopped |
overrides to show a A/V stopped icon |
AvPaused |
overrides to show a A/V paused icon |
AvPlaying |
overrides to show a A/V playing icon |
Value |
Description |
WindSpeedSensor |
overrides to show a wind speed sensor icon |
WindSpeedSensorLow |
overrides to show a wind speed sensor (low) icon |
WindSpeedSensorMedium |
overrides to show a wind speed sensor (medium) icon |
WindSpeedSensorHigh |
overrides to show a wind speed sensor (high) icon |
WindDirectionSensor |
overrides to show a wind direction sensor icon |
WindDirectionSensorNorth |
overrides to show a wind direction sensor (N) icon |
WindDirectionSensorNorthEast |
overrides to show a wind direction sensor (NE) icon |
WindDirectionSensorEast |
overrides to show a wind direction sensor (E) icon |
WindDirectionSensorSouthEast |
overrides to show a wind direction sensor (SE) icon |
WindDirectionSensorSouth |
overrides to show a wind direction sensor (S) icon |
WindDirectionSensorSouthWest |
overrides to show a wind direction sensor (SW) icon |
WindDirectionSensorWest |
overrides to show a wind direction sensor (W) icon |
WindDirectionSensorNorthWest |
overrides to show a wind direction sensor (NW) icon |
BatteryCharger |
overrides to show a battery charger icon |
BatteryChargerOn |
overrides to show a battery charger on icon |
BatteryLevel |
overrides to show a battery level icon |
BatteryLevelLow |
overrides to show a battery level (low) icon |
BatteryLevel25 |
overrides to show a battery level (25%) icon |
BatteryLevel50 |
overrides to show a battery level (50%) icon |
BatteryLevel75 |
overrides to show a battery level (75%) icon |
BatteryLevelHigh |
overrides to show a battery level (full) icon |
| Method | Restricted | Min API | Description | |
replaceOnServer() |
No | 1.0 | Because you can't directly modify a device's properties on the server, you have to get a local instance of the device and modify the writable properties as necessary. You then call this method and the device will be updated on the server and changes will be sent out to all connected clients. | |
replacePluginPropsOnServer(newPropsdict) |
Yes | 1.0 | If you need to make a change to your plugin's property dictionary that's stored as part of the device (see #About Plugin Properties below) you just use this method to replace the entire dict with a new one. A typical usage will be to get the property dictionary from the device, make changes to the dict, then use this method to store the new dict. | |
stateListOrDisplayStateIdChanged() |
Yes | 1.0 | Plugins can subclass the method getDeviceStateList() to provide dynamic state list definition information. The default implementation provides a static solution by retrieving the device state list definition from the Devices.xml file. Likewise, the method getDeviceDisplayStateId() can be used to dynamically determine which device state should be displayed in the State column of the main device table UI. The problem is that the Indigo Server only calls getDeviceStateList() and *getDeviceDisplayStateId()* at very specific times, like when a plugin device dialog is dismissed. So, call stateListOrDisplayStateIdChanged() on the device instance you need refreshed at any time and Indigo will then automatically call your plugin's getDeviceStateList() and getDeviceDisplayStateId() methods (or use the base implementation of looking up the list from Devices.xml) and update the Indigo Server (and all clients). This is particularly useful for plugin updates that need to add new device states to existing device instances created by older versions. In this case, the plugin will need to update the device instances by calling stateListOrDisplayStateIdChanged(). A likely place to do this type of instance level upgrading is inside your plugin's deviceStartComm() method. |
setErrorStateOnServer('error string') |
Yes | 1.0 | The supplied string will show in the state column and turn it red. Passing *None* will clear it. |
updateStateOnServer(key='keyName', value='Value', clearErrorState=True) |
Yes | 1.0 | Use this method to update the value of one of your device's states on the server. The server will propagate the change out to any connected clients and fire any triggers that are defined on that state. Pass "true" (default) or "false" on the clearErrorState parameter (not required) to have the error state of the device (set with setErrorStateOnServer above) cleared. |
updateStateImageOnServer(stateImageSel) |
Yes | 1.18 | Use this method to override which device state image icon is shown for this device on Indigo Touch and the Indigo client UI. The default behavior is for Indigo Server to automatically determine which icon should be shown based on the device class and state value. Only call this method if overriding the default behavior is needed. |
dev=indigo.devices[123]
About Custom Device States
<State id="playStatus">
<State id="sep1">
<State id="playlist">
<ValueType>String</ValueType>
<State id="album">
<State id="artist">
<State id="track">
<State id="volume">
<State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Commands (indigo.device.*)
All Off
indigo.device.allOff() |
indigo.device.allOff(indigo.kAllDeviceSel.HouseCodeA) |
indigo.device.allOff(indigo.kAllDeviceSel.Insteon) |
| Parameters | ||||
indigo.kAllDeviceSel |
Insteon |
specify all INSTEON devices that support ON/OFF |
X10 |
specify all X10 devices that support ON/OFF |
ZWave |
specify all Z-Wave devices that support ON/OFF |
HouseCodeA |
specify all X10 devices in house code A |
HouseCodeB |
specify all X10 devices in house code B |
HouseCodeC |
specify all X10 devices in house code C |
HouseCodeD |
specify all X10 devices in house code D |
HouseCodeE |
specify all X10 devices in house code E |
HouseCodeF |
specify all X10 devices in house code F |
HouseCodeG |
specify all X10 devices in house code G |
HouseCodeH |
specify all X10 devices in house code H |
HouseCodeI |
specify all X10 devices in house code I |
HouseCodeJ |
specify all X10 devices in house code J |
HouseCodeK |
specify all X10 devices in house code K |
HouseCodeL |
specify all X10 devices in house code L |
HouseCodeM |
specify all X10 devices in house code M |
HouseCodeN |
specify all X10 devices in house code N |
HouseCodeO |
specify all X10 devices in house code O |
HouseCodeP |
specify all X10 devices in house code P |
Beep (API v1.11+ only)
indigo.device.beep(123) |
| Parameters | |||
| python
address='F8',
name='Device Name Here',
folder=1234) |
| Parameters | ||||
*address* |
No | string | the address of the X10 device - plugins must set an address property in their property dictionary |
*description* |
No | string | the description of the device | |
*deviceTypeId* |
Yes | string | the id of the device type – defined by the plugin or one of the defined X10 devices FIXME link here | |
name |
Yes | string | the name of the device | |
*pluginId* |
No | string | the plugin ID - defaults to your plugin's id if in a Server Plugin | |
*props* |
No | dictionary | this is the properties for the device - they will be inserted in to the pluginId's property space as supplied above. If you are creating a device of a type defined in a different plugin, it's that plugin's id and properties. | |
*protocol* |
Yes | kProtocol | the protocol for the device (indigo.kProtocol.Plugin or indigo.kProtocol.X10) |
*folder* |
No | integer | id or instance of the folder in which to put the newly created device |
indigo.device.delete(123) |
| Parameters | |||
indigo.device.duplicate(123, duplicateName='New Name') |
| Parameters | |||
duplicateName |
No | string | name for the newly duplicated device |
Enable/Disable
| python
indigo.device.enable(123, value=False) #disable |
| Parameters | |||
value |
No | boolean | True to enable, False to disable |
Get Group List
groupList = indigo.device.getGroupList(123) |
| Parameters | |||
depDict = indigo.device.getDependencies(123) |
| Parameters | |||
ID : 1280166770 (integer)
ID : 106487666 (integer)
indigo.device.moveToFolder(123, value=987) |
| Parameters | |||
value |
Yes | integer | id or instance of the folder to move the device to |
Ping Device (API v1.16+ only)
| python
if result["Success"]:
indigo.server.log("ping failed for %s" % (dev.name), isError=True) |
| Parameters | |||
suppressLogging |
No | boolean | True to keep the request from being logged into the event log window (default is False) |
indigo.device.removeDelayedActions(123) |
| Parameters | |||
indigo.device.resetEnergyAccumTotal(123) |
| Parameters | |||
indigo.device.displayInRemoteUI(123, value=True) |
| Parameters | |||
value |
Yes | boolean | True to display the device on remote user interfaces or False to hide it |
Status Request
indigo.device.statusRequest(123) |
indigo.device.statusRequest(123, suppressLogging=True) |
| Parameters | |||
suppressLogging |
Toggle
indigo.device.toggle(123) |
indigo.device.toggle(123, delay=10, duration=300) |
| Parameters | |||
delay |
No | integer | number of seconds to delay before toggling the device |
duration |
No | integer | number of seconds delay before the device toggles back to it’s original state |
Turn Off
indigo.device.turnOff(123) |
indigo.device.turnOff(123, delay=10, duration=300) |
| Parameters | |||
delay |
No | integer | number of seconds to delay before turning off the device |
duration |
No | integer | number of seconds delay before the device turns back on |
Turn On
indigo.device.turnOn(123) |
indigo.device.turnOn(123, delay=10, duration=300) |
| Parameters | |||
delay |
No | integer | number of seconds to delay before turning on the device |
duration |
No | integer | number of seconds delay before the device turns back off |
Unlock (API v2.0+ only)
indigo.device.unlock(123) |
indigo.device.unlockOff(123, delay=10, duration=300) |
| Parameters | |||
delay |
No | integer | number of seconds to delay before unlocking the device |
duration |
No | integer | number of seconds delay before the device automatically locks |
Lock (API v2.0+ only)
indigo.device.lock(123) |
indigo.device.lock(123, delay=10, duration=300) |
| Parameters | |||
delay |
No | integer | number of seconds to delay before locking the device |
duration |
No | integer | number of seconds delay before the device automatically unlocks |
# Creating a device
name="Office Lamp",
address="F7",
# Getting a device
```|```text
-- Getting a device
if (myDevice.remoteDisplay):
```|```text
all off
## DimmerDevice
### Class Properties
| *`brightness`* | integer | No | an integer from 0-100 indicating the brightness of the device - plugin developers may decide if their device may be on but have a brightness of 0 (non-standard) - set using commands below |
| *`ledStates`* | list | No | this is a list of booleans that represent the state of LEDs on the device. So, to check to see if LED 3 is on you'd check dev.ledStates[2] (Python arrays are 0-based so the first element is element 0). Currently, only KeypadLinc devices use this array - however, future devices may use it as well so you should probably check the length first to make sure that the LED you're looking for is actually there. Use the len(dev.ledStates) method to see how many entries there are before you access a specific index. |
| *`onState`* | boolean | No | indicates whether the device is on - shortcut for *`dev.states['onOffState']`* |
### Device States
These are the states provided by this device type and accessible through the dev.states dictionary. They are read-only, but if you're a plugin developer you can use the *`updateStateOnServer()`* class method to update the value for devices owned by your plugin.
| *`brightnessLevel`* | integer | *`brightness`* | brightness of the device - value is in the range of 0 to 100. Can be accessed by *`dev.brightness`* |
| *`onOffState`* | boolean | *`onState`* | indicates whether the device is on - can be accessed by *`dev.onState`*. |
### Commands (indigo.dimmer.*)
#### All Lights Off
| `indigo.dimmer.allLightsOff()` |
| `indigo.dimmer.allLightsOff(indigo.kAllDeviceSel.HouseCodeA)` |
| `indigo.dimmer.allLightsOff(indigo.kAllDeviceSel.Insteon)` |
| Parameters | | | | | |
| Parameter | Required | Type | Description | | |
| direct parameter | No | *[kAllDeviceSel](#all-device-selector-enumeration)* | enumerated value to indicate which devices to turn off, all if no parameter is passed - see the [kAllDeviceSel](#all-device-selector-enumeration) enumeration for a full description |
#### All Lights On
| `indigo.dimmer.allLightsOn()` |
| `indigo.dimmer.allLightsOn(indigo.kAllDeviceSel.HouseCodeA)` |
| `indigo.dimmer.allLightsOn(indigo.kAllDeviceSel.Insteon)` |
| direct parameter | No | *[kAllDeviceSel](#all-device-selector-enumeration)* | enumerated value to indicate which lights to turn on, all if no parameter is passed - see the [kAllDeviceSel](#all-device-selector-enumeration) enumeration for a full description |
#### Brighten
| `indigo.dimmer.brighten('Office Lamp')` |
| `indigo.dimmer.brighten(123)` |
| `indigo.dimmer.brighten('Office Lamp', by=50, delay=4)` |
| Parameters | | | |
| `*by*` | No | integer | relative amount to brighten by where brightness is 0-100 |
| `*delay*` | No | integer | number of seconds to delay before executing the brighten command |
#### Dim
| `indigo.dimmer.dim('Office Lamp')` |
| `indigo.dimmer.dim(123)` |
| `indigo.dimmer.dim('Office Lamp', by=50, delay=4)` |
| Parameters | | | |
| `*by*` | No | integer | relative amount to dim by where dimness is 0-100 |
| `*delay*` | No | integer | number of seconds to delay before executing the dim command |
#### Set Brightness
| `indigo.dimmer.setBrightness(123, value=75)` |
| `indigo.dimmer.setBrightness(123, value=75, delay=360)` |
| Parameters | | | |
| `*value*` | Yes | integer | absolute value to set the brightness to on a scale of 0-100 |
#### Set LED State
Turns on/off the specified LED. Useful for KeypadLinc (and similar) devices. <span class="dw-color-red">Note</span>: you can't use this method to control the LED of the button(s) that control the direct load - use Turn ON/Turn OFF for those.
| `indigo.dimmer.setLedState(123, index=0, value=True)` |
| `indigo.dimmer.setLedState(123, index=0, value=True, suppressLogging=True)` |
| `indigo.dimmer.setLedState(123, index=0, value=True, updateStatesOnly=True)` |
| Parameters | | | |
| `*index*` | Yes | integer | the index of the button. Recall that Python-based arrays are 0-based, so the index is also 0-based. That is, the first object in an array is object 0. |
| `*value*` | Yes | boolean | True to turn on the LED, False to turn it off |
| `*suppressLogging*` | No | boolean | True to suppress logging (defaults to False) |
| `*updateStatesOnly*` | No | boolean | True to only update Indigo's internal state - no command will be sent to the KPL (defaults to False) |
#### Set On State
### Examples
```python
# Getting a device
(myDevice.onState)):
myDevice.folderId
# OR
InputOutputDevice
analogInputs |
list of integer | No | a list of the current analog input values, one per input, in a python list - can be accessed individually using the states below |
analogInputCount |
integer | No | number of analog inputs this device supports |
binaryInputs |
list of boolean | No | a list of the current binary input values, one per input - can be accessed individually using the states below |
binaryInputCount |
integer | No | number of binary inputs this device supports |
binaryOutputs |
list of boolean | No | a list of the current binary output values, on per output (max 12 total outputs) - can be accessed individually using the states below |
binaryOutputCount |
integer | No | number of binary outputs this device supports |
sensorInputCount |
integer | No | number of sensor inputs this device supports |
sensorInputs |
list of integer | No | a list of the current sensor input values, one per input - can be accessed individually using the states below |
Device States
analogInput# |
integer | N/A | value of input number represented by the # sign (input 1 would be analogInput1) - there will only be dev.analogInputCount inputs available |
analogInputsAll |
string | N/A | a comma separated list of all analog input values. Can be accessed as a Python list of integers by using dev.analogInputs. |
binaryInput# |
boolean | N/A | value of input number represented by the # sign (input 1 would be binaryInput1) - there will only be dev.binaryInputCount inputs available |
binaryInputsAll |
string | N/A | a comma separated list of all binary input values. Can be accessed as a Python list of booleans by using dev.binaryInputs. |
binaryOutput# |
boolean | N/A | value of output number represented by the # sign (output 1 would be binaryOutput1) - there will only be dev.binaryOutputCount outputs available |
binaryOutputsAll |
string | N/A | a comma separated list of all binary output values. Can be accessed as a Python list of booleans by using dev.binaryOutputs. |
sensorInput# |
integer | N/A | value of input number represented by the # sign (input 1 would be sensorInput1) - there will only be dev.sensorInputCount inputs available |
sensorInputsAll |
string | N/A | a comma separated list of all binary input values. Can be accessed as a Python list of booleans by using dev.sensorInputs. |
Commands (indigo.iodevice.*)
Set Binary Output
indigo.iodevice.setBinaryOutput(123, index=2, value=True) |
| Parameters | |||
*index* |
Yes | integer | 0-based index of the output to change - should be less than the *binaryOutputCount* property of the device |
*value* |
Yes | boolean | True to turn the output on, False to turn it off |
SensorDevice
- X10 Motion Sensors
- the Wireless INSTEON Motion / Occupancy Sensor (2420M) from SmartLabs
allowOnStateChange |
boolean | No | 1.6 | True if UI controls should be shown or enabled to change the onState |
allowSensorValueChange |
boolean | No | 1.6 | True if UI controls should be shown or enabled to change the sensorValue |
onState |
boolean | No | 1.0 | indicates that the device is currently in a triggered or ON state (None if sensor doesn't support ON/OFF) |
sensorValue |
integer or float | No | 1.6 | the numerical value of a sensor, such as temperature (None if sensor doesn't support sensor values) |
Commands (indigo.sensor.*)
Set On State
indigo.sensor.setOnState(123, value=True) |
| Parameters | |||
-- none --
RelayDevice
ledStates |
*onState* |
boolean | No | indicates whether the device is on - shortcut to dev.states['onOffState'] |
Device States
onOffState |
boolean | onState |
indicates whether the device is on - use dev.onState property as a shortcut |
Commands (indigo.relay.*)
Set LED State
indigo.relay.setLedState(123, index=0, value=True) |
indigo.relay.setLedState(123, index=0, value=True, suppressLogging=True) |
indigo.relay.setLedState(123, index=0, value=True, updateStatesOnly=True) |
| Parameters | |||
*index* |
*value* |
*suppressLogging* |
*updateStatesOnly* |
# Toggle the device
SpeedControlDevice
*onState* |
*speedIndex* |
integer | No | indicates the current speed index for devices that support some fixed # of speeds - shortcut to dev.states['speedIndex'] |
*speedIndexCount* |
integer | No | indicates the number of indexes available for this device (defaults to 4) |
*speedLevel* |
integer | No | indicates the level the device is set to (0-100) - shortcut to dev.states['speedLevel'] |
Device States
onOffState |
boolean | onState |
speedIndex |
boolean | speedIndex |
indicates the current speed index for devices that support some fixed # of speeds - use dev.speedIndex property as a shortcut |
speedIndex.ui |
string | n/a | a more user friendly name for the current index (e.g. high, medium, low, off) |
speedLevel |
integer | speedLevel |
indicates the level the device is set to (0-100) - use dev.speedLevel property as a shortcut |
Decrease Speed Index
Decreases the speed index.
indigo.speedcontrol.decreaseSpeedIndex(123) |
indigo.speedcontrol.decreaseSpeedIndex(123, by=2) |
indigo.speedcontrol.decreaseSpeedIndex(123, delay=10) |
| Parameters | |||
*by* |
No | integer | the number of index positions to decrease by. Defaults to 1 if not specified. |
*delay* |
No | integer | delays the command by the specified number of seconds. Defaults to no delay if not specified. |
Increase Speed Index
Increases the speed index.
indigo.speedcontrol.increaseSpeedIndex(123) |
indigo.speedcontrol.increaseSpeedIndex(123, by=2) |
indigo.speedcontrol.increaseSpeedIndex(123, delay=10) |
| Parameters | |||
*by* |
No | integer | the number of index positions to increase by. Defaults to 1 if not specified. |
*delay* |
Set Speed Index
indigo.speedcontrol.setSpeedIndex(123, value=2) |
indigo.speedcontrol.increaseSpeedIndex(123, value=2, delay=10) |
| Parameters | |||
*value* |
Yes | integer | index position to set the index to. |
*delay* |
Set Speed Level
indigo.speedcontrol.setSpeedLevel(123, value=50) |
indigo.speedcontrol.setSpeedLevel(123, value=75, delay=10) |
| Parameters | |||
*value* |
Yes | integer | level of the motor control, from 0-100. |
*delay* |
SprinklerDevice
activeZone |
integer | No | 1.0 | the 1-based index of the active zone (None=all zones off, 1=zone 1, 2=zone 2, ...). Note this property has undergone changes in name (previously called activeZoneIndex) as well as semantics (previously the index being 0-based). As of API v1.12 (Indigo 7.0.3) the property is final and stable. |
zoneCount |
integer | No | 1.0 | the number of zones available for this sprinkler |
zoneEnableList |
list of boolean | No | 1.13 | list of booleans, starting at zone 1 through zone [*zoneCount*], that specify if a given zone is enabled (has a maximum zone duration > 0). |
zoneNames |
list of string | No | 1.0 | list of zone names, starting at zone 1 through zone [*zoneCount*]. You must include *zoneCount* strings in the list. |
zoneMaxDurations |
list of floats | No | 1.0 | list of zone durations in minutes, starting at zone 1 through zone [*zoneCount*]. You must include *zoneCount* integers in the list. |
zoneScheduledDurations |
list of floats | No | 1.0 | list of currently active zone durations in minutes if a schedule is running (empty list if no schedule is running), starts at zone 1 through zone [*zoneCount*] |
pausedScheduleZone |
integer | No | 1.16 | the 1-based index of the paused sprinkler zone index (None=schedule not paused, 1=zone 1 paused, 2=zone 2 paused, ...). |
pausedScheduleRemainingZoneDuration |
float | No | 1.16 | the paused sprinkler zone duration in minutes (None if schedule not paused) |
Device States
activeZone |
integer | activeZone |
the number of the active zone, 0 if off (1=zone 1, 2=zone 2, etc) |
zone# |
boolean | N/A | replace the # with the zone number (up to dev.zoneCount) to return whether the zone is running or not |
Commands (indigo.sprinkler.*)
Next Zone
indigo.sprinkler.nextZone(123) |
| Parameters | |||
Pause Schedule
indigo.sprinkler.pause(123) |
| Parameters | |||
Previous Zone
indigo.sprinkler.previousZone(123) |
| Parameters | |||
Resume Schedule
indigo.sprinkler.resume(123) |
| Parameters | |||
Run Schedule
Run a sprinkler schedule.
indigo.sprinkler.run(123, schedule=[10,15,8, 0, 0, 0, 0, 0]) |
| Parameters | |||
schedule |
Yes | list of reals | list of reals representing the number of minutes to run for each zone - the list must have [zoneCount] elements, with 0 for any zone that shouldn’t run |
Stop Schedule
indigo.sprinkler.stop(123) |
| Parameters | |||
Set Active Zone
indigo.sprinkler.setActiveZone(123, index=2) |
| Parameters | |||
*index* |
Yes | integer | 1-based index of the zone to turn on |
# run schedule
ThermostatDevice
coolIsOn |
boolean | No | 1.0 | is the cooling system (compressor) currently running - shortcut for dev.states['hvacCoolerIsOn'] |
coolSetpoint |
float | No | 1.0 | current cool setpoint value - shortcut for dev.states['setpointCool'] |
dehumidifierIsOn |
boolean | No | 1.7 | is the dehumidifier currently turned ON - shortcut for dev.states['hvacDehumidifierIsOn'] |
fanMode |
kFanMode | No | 1.0 | the operating mode for the fan attached to the thermostat - shortcut for dev.states['hvacFanMode'] |
fanIsOn |
boolean | No | 1.0 | is the fan currently running - shortcut for dev.states['hvacFanIsOn'] |
heatIsOn |
boolean | No | 1.0 | is the heater currently running - shortcut for dev.states['hvacHeaterIsOn'] |
heatSetpoint |
float | No | 1.0 | current heat setpoint value - shortcut for dev.states['setpointHeat'] |
humidities |
list of float | No | 1.0 | a list of floating point values representing the current values of all humidity sensors connected to the thermostat | |
humiditySensorCount |
integer | No | 1.0 | number of humidity sensors this thermostat supports | |
humidifierIsOn |
boolean | No | 1.7 | is the humidifier currently turned ON - shortcut for dev.states['hvacHumidifierIsOn'] |
hvacMode |
kHvacMode | No | 1.0 | the operating mode for the HVAC system attached to the thermostat - shortcut for dev.states['hvacOperationMode'] |
temperatureSensorCount |
integer | No | 1.0 | number of temperature sensors this thermostat supports | |
temperatures |
list of float | No | 1.0 | a list of floating point values representing the current values of all temperature sensors connected to the thermostat |
Fan Mode Enumeration
*indigo.kFanMode* |
| Value | Description |
AlwaysOn |
signal the fan that it should be running continuously |
Auto |
signal the fan that it should only run when the HVAC system needs it to be running |
HVAC Mode Enumeration
*indigo.kHvacMode* |
Cool |
the hvac system is only reacting to cool setpoints |
HeatCool |
the hvac system is reacting to both cool and heat setpoints |
Heat |
the hvac system is only reacting to and heat setpoints |
Off |
the hvac system is turned off |
ProgramHeatCool |
the hvac system is executing it’s built-in automatic program, which usually responds to both heat and cool setpoints |
ProgramCool |
the hvac system is executing it’s built-in cooling program |
ProgramHeat |
the hvac system is executing it’s built-in heating program |
Device States
| State ID | Type | Property Name | Notes | |
humidityInput# |
float | N/A | replace the # with the humidity sensor # (up to humiditySensorCount) to directly access the humidity value for that input |
humidityInputsAll |
string | N/A | a comma separated list of all humidity values | |
hvacCoolerIsOn |
boolean | coolIsOn |
True if the cooling system currently running |
hvacDehumidifierIsOn |
boolean | dehumidifierIsOn |
True if the dehumidifier is currently running |
hvacFanIsOn |
boolean | fanIsOn |
True if the fan currently running |
hvacFanMode |
kFanMode | fanMode |
operating mode for the fan attached to the thermostat | |
hvacFanIsAlwaysOn |
boolean | N/A | True if the fan mode is set to AlwaysOn. Note: this state can't be directly updated but rather will be updated automatically when you update hvacFanMode. |
hvacFanIsAuto |
boolean | N/A | True if the fan mode is set to Auto. Note: this state can't be directly updated but rather will be updated automatically when you update hvacFanMode. |
hvacHeaterIsOn |
boolean | heatIsOn |
True if the heating system currently running |
hvacHumidifierIsOn |
boolean | humidifierIsOn |
True if the humidifier is currently running |
hvacOperationMode |
kHvacMode | hvacMode |
operating mode for the HVAC system attached to the thermostat | |
hvacOperationModeIsAuto |
boolean | N/A | True if the HVAC is set to HeatCool. Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode. |
hvacOperationModeIsCool |
boolean | N/A | True if the HVAC is set to Cool. Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode. |
hvacOperationModeIsHeat |
boolean | N/A | True if the HVAC is set to Heat. Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode. |
hvacOperationModeIsOff |
boolean | N/A | True if the HVAC is set to Off. Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode. |
hvacOperationModeIsProgramAuto |
boolean | N/A | True if the HVAC is set to ProgramHeatCool. Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode. |
hvacOperationModeIsProgramCool |
boolean | N/A | True if the HVAC is set to ProgramCool. Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode. |
hvacOperationModeIsProgramHeat |
boolean | N/A | True if the HVAC is set to ProgramHeat. Note: this state can't be directly updated but rather will be updated automatically when you update hvacOperationMode. |
setpointCool |
float | coolSetpoint |
the cool setpoint | |
setpointHeat |
float | heatSetpoint |
the heat setpoint | |
temperatureInput# |
float | N/A | replace the # with the temperature sensor # (up to temperatureSensorCount) to directly access the humidity value for that input |
temperatureInputsAll |
string | N/A | a comma separated list of all temperature values |
Decrease Cool Setpoint
indigo.thermostat.decreaseCoolSetpoint(123, delta=5) |
| Parameters | |||
Decrease Heat Setpoint
indigo.thermostat.decreaseHeatSetpoint(123, delta=5) |
| Parameters | |||
*value* |
Yes | integer | number of degrees to decrease the heat setpoint |
Increase Cool Setpoint
indigo.thermostat.increaseCoolSetpoint(123, delta=5) |
| Parameters | |||
*value* |
Yes | integer | number of degrees to increase the cool setpoint |
Increase Heat Setpoint
indigo.thermostat.increaseHeatSetpoint(123, delta=5) |
| Parameters | |||
*value* |
Yes | integer | number of degrees to increase the heat setpoint |
Set Cool Setpoint
indigo.thermostat.setCoolSetpoint(123, value=78) |
| Parameters | |||
*value* |
Yes | integer | the absolute temperature of the setpoint |
Set Fan Mode
Adjust the fan mode.
indigo.thermostat.setFanMode(123, value=indigo.kFanMode.AlwaysOn) |
| Parameters | ||||
| direct parameter | Yes | integer | id or instance of the device | |
*value* |
Yes | kFanMode | the absolute temperature of the setpoint |
Set Heat Setpoint
indigo.thermostat.setHeatSetpoint(123, value=78) |
| Parameters | |||
*value* |
Set HVAC Mode
Adjust the HVAC mode.
indigo.thermostat.setHvacMode(123, value=indigo.kHvacMode.HeatCool) |
| Parameters | ||||
*value* |
Yes | kHvacMode | HVAC mode identifier |
# set the heat setpoint to 78
