The Indigo Reflector Service
About Reflectors
Reflectors provide:
  • Hassle free setup:
Activating your Reflector
  1. Choose the Indigo->Start Local Server... menu item.
  2. Turn on the Require authentication checkbox and enter a User name and good Password. You will definitely want password authentication on since you are about to enable access to the Indigo web server from the Internet.
Lastly, switch back to the Indigo Start Local Server... dialog. It should now show that the reflector status is activated and will show a link to your new reflector URL. Press the Start Server button and that is it – Indigo will restart and automatically connect to your reflector! To access from the web, simply go to https://YOUR-REFLECTOR-NAME.indigodomo.net/.
  1. Shut down the Indigo Server (select Indigo 2021.1->Stop Server) but don't quit the Indigo Client
Manual Reset
  4. In the Finder, select Go->Go to Folder…
  5. In the resulting dialog, copy and paste the following: /Library/Application Support/Perceptive Automation/Indigo 2021.1/Preferences/
Bandwidth Limits
