Airfoil Pro
Note: this plugin requires v1.5 or later of the Airfoil API. This was delivered in Airfoil 5 for Mac and Windows. If you need support for earlier versions of Airfoil for Mac, please see the legacy Airfoil plugin that we open-sourced. Note, however, that it may not work with Indigo 7.
Airfoil Device Types
Airfoil Instance
Adding an Instance
Add Airfoil Instance Image
When you click the "Save" button, the plugin will create your Airfoil Instance device, and it will query Airfoil and get all it's known speakers. It will then create devices for each of those speakers (see the next section for details on those devices).
Airfoil Edit Group Image
Airfoil Triggers Image
States available to Scripts
Notes
Speaker
Each Airfoil Instance device has a collection of "Speaker" devices in its group. These are all the various outputs to which Airfoil can direct its source audio. These devices are created automatically when you create your Airfoil Instance and any time a new source gets added to the instance. For instance, if you create an Airfoil Instance and it finds 3 speakers, then at a later time you add a bluetooth speaker to the Mac that Airfoil is running on, the plugin will automatically create a new speaker device for that bluetooth speaker.
Warning: you can't use the Delete... button above the device list without deleting ALL the devices in that Airfoil Instance Group. If you need to delete just a single speaker, select the Plugins->Airfoil Pro->Permanently Delete Speaker menu item. This will allow you to just delete a single speaker.
volume number If the source is iTunes and you've selected an iTunes server as the source in this device's config, this will mirror that device's playState
Airfoil Actions
Action Menu Image
If you examine the example scripts below, you'll note that each action call will return a result (which is new in Indigo 7). Unless otherwise specified, it's just a boolean indicating if the action correctly ran.
Speaker Actions
Connect Speaker
Scripting details
Action id: connect
airfoilPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.airfoilpro")
if airfoilPlugin.isEnabled():
        result = airfoilPlugin.executeAction("connect", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
    except Exception, e:
        print "Exception occurred: %s" % unicode(e)
Disconnect Speaker
Scripting details
Action id: disconnect
        result = airfoilPlugin.executeAction("disconnect", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Toggle Speaker
Scripting details
Action id: toggle
        result = airfoilPlugin.executeAction("toggle", deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Save Current Speaker States
Scripting details
Example 1 (no groups):
        result = airfoilPlugin.executeAction("saveCurrentSpeakerStates", deviceId=135305663, waitUntilDone=True)  # ID of Airfoil device
Example 2 (include groups):
        result = airfoilPlugin.executeAction("saveCurrentSpeakerStates", deviceId=135305663, props={"includeAirfoilGroups": True}, waitUntilDone=True)
Restore Saved Speaker States
Scripting details
        result = airfoilPlugin.executeAction("restoreSavedSpeakerStates", deviceId=135305663, waitUntilDone=True)  # ID of Airfoil device
Set Volume
Scripting details
Action id: setVolume
        result = airfoilPlugin.executeAction('setVolume', deviceId=135305663, props={'volume': 50}, waitUntilDone=True)  # ID of Speaker device
Increase Volume
Scripting details
Action id: increaseVolume
        result = airfoilPlugin.executeAction('increaseVolume', deviceId=135305663, waitUntilDone=True)  # ID of Speaker device
Example 2 (specifying delta):
        result = airfoilPlugin.executeAction('increaseVolume', deviceId=135305663, props={'volume': 15}, waitUntilDone=True)  # ID of Speaker device
Decrease Volume
Scripting details
Action id: decreaseVolume
        result = airfoilPlugin.executeAction('decreaseVolume', deviceId=135305663, props={'volume': 15}, waitUntilDone=True)  # ID of Speaker device
Airfoil Instance Actions
Disconnect All Speakers
Scripting details
        result = airfoilPlugin.executeAction('disconnectAllSpeakers', deviceId=12345678, waitUntilDone=True)  # ID of Airfoil device
Change Source
Scripting details
Action id: changeSource
sourceGroup One of the following: 'audioDevices', 'recentApplications', 'systemAudio'. You can see what sources are known by selecting the Plugins->Airfoil Pro->Show Sources menu item and all source groups and sources will be shown in the event log. You can also call it programmatically (as shown below with the Show Speakers Action/Menu Item) and it will return a dictionary of valid sources.
        props = {"sourceGroup": "systemAudio", "source": "com.rogueamoeba.source.systemaudio"}
        result = airfoilPlugin.executeAction("changeSource", deviceId=1346588091, props=props, waitUntilDone=True)
Save Current Source
Scripting details
Action id: saveCurrentSource
        result = airfoilPlugin.executeAction("saveCurrentSource", deviceId=1346588091, waitUntilDone=True)
Restore Saved Source
Scripting details
Action id: restoreSavedSource
        result = airfoilPlugin.executeAction("restoreSavedSource", deviceId=1346588091, waitUntilDone=True)
Toggle Play/Pause
Scripting details
Action id: playPause
        result = airfoilPlugin.executeAction('playPause', deviceId=12345678, waitUntilDone=True)
Next Track
Scripting details
Action id: nextTrack
        result = airfoilPlugin.executeAction('nextTrack', deviceId=12345678, waitUntilDone=True)
Previous Track
Scripting details
Action id: prevTrack
        result = airfoilPlugin.executeAction('prevTrack', deviceId=12345678, waitUntilDone=True)
Airfoil Scripting Actions
= getSources
Action id: getSources
        result = airfoilPlugin.executeAction('showSources', deviceId=12345678)  # deviceId is the Indigo ID of the Airfoil device
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
          Item : (dict)
               icon : [SNIP]
That's an indigo.Dict() object. Each group is the key, and the value for each group is a list of "source" indigo.Dict()'s. Each source dict has the following keys: friendlyName (the user friendly name), icon (a binhex'd string that is the source's icon - snipped from the above example to save space), identifier (the ID used in the source property above). You can unbinhex the icon and save it to a PNG file and store it somewhere for use if you like. You can use the group name and identifier combination in the changeSource action described above.
