Install the FTDI VCP Drivers
Connecting the Interface
  1. Choose Indigo 7->Preferences... menu, then make sure the Interfaces tab is selected.
First, make sure that Indigo has enabled communication with the interface. If Indigo is not online with the interface, then choose the Interfaces->INSTEON/X10 Power Line->Enable menu item. See connecting the Interface above for more details.
To add a new Insteon device:
  2. Press the New... button at the top of the Home window.
Insteon Device Detail Image
Define Insteon Dialog Image
Start Sync Dialog Image
Replacing a Device
Device Links Dialog Image
Device Links Example Image
Manage Powerlinc Scenes Image
Defining the Scene
Executing the Scene
Resetting your PowerLinc
  5. Release the button
Replacing Your PowerLinc
The Interfaces->INSTEON/X10 Power Line submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI:
Insteon Menu Image
Execute Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
if insteonPlugin.isEnabled():
    actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
Set Siren Alarm Sound
Set Siren LED Mode
Set OutletLinc Load Sense
