Send Scene Decrease
indigo.insteon.sendSceneDecrease(11) |
indigo.insteon.sendSceneDecrease(11, repeatCount=5) |
indigo.insteon.sendSceneDecrease(11, suppressLogging=True) |
indigo.insteon.sendSceneDecrease(11, updateStatesOnly=True) |
indigo.insteon.sendSceneDecrease("working in office scene") |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
either the scene number or the scene name - we encourage numbers since they won't change and the scene names can. |
repeatCount |
No |
integer |
a value from 1-32 for the number of times to repeat the decrease (default is 1) |
suppressLogging |
No |
boolean |
True if entries in the event log should be suppressed (default is False) |
updateStatesOnly |
No |
boolean |
use if you only want Indigo's internal device state representation to be updated - no actual INSTEON command will be sent on RF or the power line (default is False) |
Send Scene Increase
indigo.insteon.sendSceneIncrease(11) |
indigo.insteon.sendSceneIncrease(11, repeatCount=5) |
indigo.insteon.sendSceneIncrease(11, suppressLogging=True) |
indigo.insteon.sendSceneIncrease("working in office scene") |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
repeatCount |
No |
integer |
a value from 1-32 for the number of times to repeat the increase (default is 1) |
suppressLogging |
No |
boolean |
updateStatesOnly |
No |
boolean |
Send Scene ON
indigo.insteon.sendSceneOn(11) |
indigo.insteon.sendSceneOn(11, sendCleanUps=False) |
indigo.insteon.sendSceneOn(11, suppressLogging=True) |
indigo.insteon.sendSceneOn(11, updateStatesOnly=True) |
indigo.insteon.sendSceneOn("working in office scene") |
indigo.insteon.sendSceneOn("working in office scene", sendCleanUps=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
sendCleanUps |
No |
boolean |
True if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might affect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True) |
suppressLogging |
No |
boolean |
updateStatesOnly |
No |
boolean |
Send Scene OFF
indigo.insteon.sendSceneOff(11) |
indigo.insteon.sendSceneOff(11, sendCleanUps=False) |
indigo.insteon.sendSceneOff(11, suppressLogging=True) |
indigo.insteon.sendSceneOff(11, updateStatesOnly=True) |
indigo.insteon.sendSceneOff("working in office scene") |
indigo.insteon.sendSceneOff("working in office scene", sendCleanUps=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
sendCleanUps |
No |
boolean |
suppressLogging |
No |
boolean |
updateStatesOnly |
No |
boolean |
Send Scene Fast ON
indigo.insteon.sendSceneFastOn(11) |
indigo.insteon.sendSceneFastOn(11, sendCleanUps=False) |
indigo.insteon.sendSceneFastOn(11, suppressLogging=True) |
indigo.insteon.sendSceneFastOn(11, updateStatesOnly=True) |
indigo.insteon.sendSceneFastOn("working in office scene") |
indigo.insteon.sendSceneFastOn("working in office scene", sendCleanUps=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
sendCleanUps |
No |
boolean |
suppressLogging |
No |
boolean |
updateStatesOnly |
No |
boolean |
Send Scene Fast OFF
indigo.insteon.sendSceneFastOff(11) |
indigo.insteon.sendSceneFastOff(11, sendCleanUps=False) |
indigo.insteon.sendSceneFastOff(11, suppressLogging=True) |
indigo.insteon.sendSceneFastOff(11, updateStatesOnly=True) |
indigo.insteon.sendSceneFastOff("working in office scene") |
indigo.insteon.sendSceneFastOff("working in office scene", sendCleanUps=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
sendCleanUps |
No |
boolean |
suppressLogging |
No |
boolean |
updateStatesOnly |
No |
boolean |
Send Scene Start Change
This command will tell the specified PowerLinc scene to begin increasing/decreasing in value. It will continue to ramp each device in the scene until either the corresponding #Send Scene Stop Change command is called or until the devices are at 100% for increase ramping or 0% for decrease ramping.
indigo.insteon.sendSceneIncrease(11, increase=True) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
increase |
Yes |
boolean |
True if you want to ramp up, False if you want to ramp down |
suppressLogging |
No |
boolean |
This command will tell the specified PowerLinc scene to stop any ramping activity started by a #Send Scene Start Change command.
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
suppressLogging |
No |
boolean |
Send Status Request
| python
indigo.server.log("reply success: %d, ack value: %02X" % (reply.cmdSuccess, reply.ackValue)) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
string |
the target INSTEON address as a hexadecimal string. |
waitUntilAck |
No |
boolean |
true if the caller wants to wait for the result. (default is True) |
suppressLogging |
No |
boolean |
Send Raw
| python
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
string |
cmdBytes |
Yes |
list |
a list of 2 integer bytes that represent the command to be sent. |
waitUntilAck |
No |
boolean |
True if the caller wants to wait for the result. (default is True) |
waitForStandardReply |
No |
boolean |
True if the caller wants to wait for a follow-up direct standard reply. (default is False) |
waitForExtendedReply |
No |
boolean |
True if the caller wants to wait for a follow-up direct extended reply. (default is False) |
suppressLogging |
No |
boolean |
Send Raw Extended
| ```python
Get KeypadLinc info (LED states, brightness, etc.)
if reply.cmdSuccess:
indigo.server.log(" backlight brightness: %d" % (reply.replyBytes[10],))
indigo.server.log(" button states bitmap: 0x%02X" % (reply.replyBytes[12],))
|python
Change the Keypad LED brightness from dim to bright
setKeypadLedBrightness = [
0x2E, 0x00,
0x00, # unused
0x07, # change LED backlight brightness
0x11, # brightness between 0x11 and 0x7F
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
string |
cmdBytes |
Yes |
list |
a list of 2 to 16 integer bytes that represent the command to be sent. |
calcCrc |
No |
boolean |
automatically calculate 8 bit CRC byte for message (used by i2CS firmware). (default is True) |
calc16bitCrc |
No |
boolean |
automatically calculate 16 bit CRC byte for message (used by specific modules). (default is False) |
waitUntilAck |
No |
boolean |
No |
boolean |
No |
boolean |
suppressLogging |
No |
boolean |
reply = indigo.insteon.sendPowerLincSetButtonPress() |
| Parameters |
| Parameter |
Required |
Type |
Description |
suppressLogging |
No |
boolean |
