Iws Plugin Guide
IWS Plugin Foldr Overview Image
/Library/Application Support/Perceptive Automation/Indigo XYZW.V/Web Assets/plugins/
  • *css* - store CSS files used in templates or static pages (see below for details on templates)
  • *images* - store image files in this directory
  • *js* - store javascript files in this directory
  • *static* - store any static HTML files that your plugin would like to serve. For instance, you might want an about HTML file that gets displayed when the user selects a help link.
  • *templates* - store template files here (see below for details on templates)
The ***init**.py* file is unused, but it’s required - it can just be empty. The meat of the functionality is in the reqhandler.py. The structure of this file goes something like this: imports, static hook methods, request handler class.
  • *PlugInName()* - this method should return a string with a human readable name for your plugin. It will be used in the Event Log when the plugin loads and will (optionally) be shown on the IWS index (landing) page.
  • *PluginDescription()* - this method should return a string with a human readable description of what your plugin does. This will (optionally) be shown on the IWS index (landing) page. to the right of the name specified above.
  • *ShowOnControlPageList()* - this method should return true if you want your plugin listed on the IWS index page (using the name and description above). If you want your plugin to show up there, you’ll need to make sure you implement an index method in your handler class (described below) so that when the user clicks on the name of your plugin in the list the index page will load.
  • *IndigoConnected()* and *IndigoDisconnected()* - these methods are called just when their name implies - when IWS connects and disconnects from the IndigoServer process. Use these methods if you need to initialize and/or deallocate resources of some type.
The plugin request handler must subclass from BaseRequestHandler and must call the parent class ***init*** method:
def __init__(self, logFunc):
def index(self):
    return thePage
index.exposed = True    # exposed = True must be set for handler func to be called
index.exposed = true
<table>
    <tr>
    </tr>
    #set $i=1
    #for $deviceKey in $totalKeys
       #if (($i % 2) != 0)
         <tr class="darkRowBg">
       #else
         <tr class="lightRowBg">
       #end if
       #set $i=$i+1
      </tr>
    #end for
</table>
    tmpl.totals = totals
    tmpl.totalKeys = totalKeys
    return tmpl.RenderTemplate()
finally:
    tmpl.ReleaseLock();
finally:
    tmpl.ReleaseLock();
Back to Top
