Alexa
Smart Home Skill
*Note: the Alexa skill is currently available in the Alexa skill stores for most of the regions in which we sell Indigo (US, Canada, UK, the Netherlands, Australia, New Zealand, France, Germany, Spain, Italy).*
- Open the Alexa App.
- Go to the Devices list and click the link to Your Smart Home Skills.
- Click Enable Smart Home Skills.
- Tap the Search icon.
- Search for "Indigo Smart Home". You should see a skill named Indigo Smart Home Skill in English speaking regions and Indigo Smart Home everywhere else, with an icon that matches the logo of the Mac Client.
- Add the skill.
- Link the skill to your Indigo Account & license (currently by clicking/tapping the Settings button).
- Log in using your Indigo Account username and password.
- On the next page (the authorization page), if you have multiple Indigo Licenses, make sure you have the correct one selected (you must have an active Indigo Up-to-Date subscription); you can link one license to one Alexa (Amazon) account. If you see something else or don't see a license you were expecting to see, check the #Account Linking Issues troubleshooting section below for help.
Alexa Store Links
To make a device available to Alexa, you must explicitly publish it. Use thePlugins->Alexa->Manage Device Publications... menu item to open the publication dialog:
Warning: be sure to click the Save button before moving on or your changes won't be saved. Also, if you make any changes, you will need to rerun discovery from an Alexa device or the Alexa app before those changes will be reflected. As a reminder, you must either click the discover devices button in the Alexa apps or ask "Alexa, discover devices" of an Alexa enabled device.
Device Types Supported
- On/Off devices (sometimes referred to as relay) - simple appliance control plug-in modules, outlets, and switches are the most common type. This also includes Locks and Garage Doors.
- Dimmer devices - dimmer switches and plug-in modules are the most common, though in Indigo there are a variety of other device types that Indigo sees as dimmers: Blinds/Drapes, Fans, Bulbs (including color), etc.
- Thermostats
- Fans - Indigo natively only supports the Insteon FanLinc fan as a proper fan device (with the right controls) - Z-Wave fan controllers are currently implemented as dimmers, but they will work as fans in Alexa if configured correctly.
On/Off Devices
- Alexa, turn on office lamp
- Alexa, turn off bedroom fan
- Alexa, open garage door
The options are:
- Door Bell - as of this release, this will only allow you to turn on/off the doorbell, not accept ring events. We will look at adding that in a future release.
- Door Controller - if you have a device that physically operates a door (but not a garage door), you can use this device type. You can then say things like:
- Alexa, open the front door
- Alexa, what's the status of the front door
- Garage Controller - this is exactly what you think it is. You will be able to open/close (raise/lower) your garage door. Alexa uses this control type as a more secure option. When Alexa first discovers a garage door, it will not allow you to control the door by voice. Rather, it will tell you to control it manually or go to the Alexa app and configure the door for use with voice control. In the settings for the door in the Alexa app, you will be able to enter a 4 digit PIN for extra security. When you ask Alexa to open or raise the door, you will be prompted for your PIN code. If you have an automatic door controller (specified above) and want the extra security of a PIN code, you can select Garage Controller as well and it should work just like a garage door. PIN codes are set per device so each can be different. You can say things like:
- Alexa, open the garage door
- Alexa, is the garage door open
- Lock - similar to a garage door, a lock device will need to have a PIN assigned for it in the Alexa app. Once that's done, when you attempt to unlock the door (Alexa, unlock the back door), it will prompt you for the PIN. You can say things like:
- Alexa, lock the back door
- Alexa, is the back door locked
- All the rest of the types will simply respond to standard on/off commands. There is currently no distinction other than the icon that shows up in the Alexa app. You can say things like:
- Alexa, turn on bathroom exhaust fan
- Alexa turn off desk lamp
Dimmer Devices
- Alexa, brighten office lamp to 35%
- Alexa, dim office lamp by 15%
- Alexa, set color of office bulb to red (color devices)
- Alexa, set office bulb to daylight (white color temperature)
- Alexa, make office bulb warmer (white color temperature)
| Shades of White | Temperature in Kelvin |
| warm, warm white | 2200 |
| incandescent, soft white | 2700 |
| white | 4000 |
| daylight, daylight white | 5500 |
| cool, cool white | 7000 |
The options are:
Blind- use this type if your dimmer device actually controls blinds, shades, or drapes. You can say things like:- Alexa, raise the blinds to twenty-five percent
- Alexa, set the drapes to fifty percent
- Alexa, close the shades
- Alexa, what is the status of the shades
Fan- use this type if your device actually controls a fan (as of this release Z-Wave fan controllers are treated as dimmers in Indigo). Fan devices from Indigo in Alexa will support 4 modes: Off, Low, Medium, High. You can say things like:- Alexa, set ceiling fan to medium
- Alexa, set ceiling fan to highest
- Alexa, ceiling fan speed
- Alexa, turn off ceiling fan
Valve- use this type if your device controls a valve, or really any device that has a 0-100% range. You can say things like:- Alexa, set set the valve to thirty percent
- Alexa, increase valve by ten percent
- Alexa, turn off the valve
- All the rest will support standard on/off and dim/brighten. If the device supports color and/or white color temperature, those commands will be added to the standard on/off and dim/brighten commands (see the examples above). There is currently no distinction other than the icon that shows up in the Alexa app.
Indigo Fan Devices
- *Alexa, set ceiling fan to medium*
- *Alexa, set ceiling fan to highest*
- *Alexa, increase ceiling fan speed*
- *Alexa, turn off ceiling fan*
Indigo Thermostat Devices
NOTE: the Alexa implementation for thermostats is quite limited as it only fully supports thermostats that are in either heat or cool mode. In North America, most thermostats stay in auto mode, which allows (at least) two setpoints to be active at the same time to call for heat or cool depending on the temp. Alexa's support for auto mode is fundamentally read-only: you can't adjust either setpoint while in auto. Further, the error that Alexa will respond with implies that you have to manually set the mode on the thermostat itself to either heat or cool in order for you to adjust setpoints. This is incorrect in that you can say to Alexa "set the thermostat to heat", and that will correctly change mode from auto to heat (same applies to cool).
- *Alexa, set the thermostat to cool*
- *Alexa, what is my thermostat set to*
- *Alexa, turn off the heat* (<span class="dw-color-orange">**Warning**</span>: this will turn the thermostat off regardless of mode)
- *Alexa, set the AC to seventy-five*
- *Alexa, make it warmer in here*
Custom Indigo Skill
!!! warning "NOTE" the Custom Skill is available in English speaking regions only.
!!! warning "NOTE" Unfortunately, the invocation for the skill is currently different in different regions.
- US, UK - "indigo" is the invocation
- CA, AU - "indigo home" is the invocation
!!! note "Note" When naming variables for use with Alexa, you should use underscores_to_separate_words. That is how the plugin will map separate words from Alexa onto variables (which can't contain spaces).
- Alexa, ask Indigo to get "current_weather_conditions"
- Alexa, ask Indigo to look up "current_weather_conditions"
- Alexa, ask Indigo to read "current_weather_conditions"
- Alexa, ask Indigo to say "current_weather_conditions"
- Alexa, ask Indigo to speak "current_weather_conditions"
- Alexa, ask Indigo to tell me "the_status_of_the_house"
- Alexa, ask Indigo for the value of variable "current_weather_conditions"
- Alexa, ask Indigo the value of "current_weather_conditions"
- Alexa, ask Indigo the current value of "weather_conditions"
The value of variable "current weather conditions" is "mostly cloudy"
- You can use Speech Synthesis Markup Language (SSML) to mark up the text in a variable to customize how Alexa reads back the value. Any variable value that begins with a less than sign (<), which we use as a key that the text contains SSML, will be read exactly as specified in the variable without any additional words (i.e. The value of variable won't be prepended). If your markup text doesn't naturally begin with a markup tag, wrap the entire string in
<speak></speak>tags. - Variable values that contain the device (%%d:deviceId:deviceState%%) or variable (%%v:variableId%%) markup values will be correctly substituted by Indigo.
- You may also specify in the plugin's config that all variable values should be read exactly as they are stored without the added verbiage.
Get a List of Variables
- Alexa, ask Indigo to get my variable list
- Alexa, ask Indigo to list my variables
- Alexa, ask Indigo to list all variables
- Alexa, ask Indigo what variables are available
Execute an Action Group
- Alexa, tell Indigo to arm "the kitchen zone"
- Alexa, tell Indigo to do "my favorite thing"
- Alexa, tell Indigo to execute "toggle music"
- Alexa, tell Indigo to launch "rocket"
- Alexa, tell Indigo to make "the house secure"
- Alexa, tell Indigo to perform "routine maintenance"
- Alexa, tell Indigo to play "my favorite playlist"
- Alexa, tell Indigo to reset "the alarm"
- Alexa, tell Indigo to restart "the laundry timer"
- Alexa, tell Indigo to restore "the standard speaker set"
- Alexa, tell Indigo to run "routine maintenance"
- Alexa, tell Indigo to start "the laundry timer"
- Alexa, tell Indigo to set "the playlist to classic rock"
Action group names can contain letters, numbers, and spaces only. If you say "playlist eighties music", the action group name will need to be "playlist 80s music". If you are unsure how to name an action group, just attempt to execute it with one of the above utterances. If Indigo doesn't find an action group matching what you said, it will log it to the Event Log window like this:
Note: what you say before the action group name will work for any action group name. We picked the above examples only because they are normal complete English sentences, but you could just as well say Alexa, tell Indigo to arm "the laundry timer" and the effect would be the same as saying Alexa, tell Indigo to start "the laundry timer". You can also use tell Indigo interchangeably with ask Indigo.
Alexa Plugin operations
Plugin Startup
Started plugin "Alexa 2022.1.0" Alexa Finding devices to publish to Alexa... Alexa ... '010 - Smart Fan Control (14287)' published as 'office fan' Alexa ... '016 - Plug-In Appliance Module (ZL-PA-100)' published as 'office lamp' Alexa ... '038 - Lamp Module (AD130)' published as 'blinds' Alexa ... 'automatic door' published Alexa ... 'FanLinc - Fan' published as 'ceiling fan' Alexa ... 'FanLinc - Light' published as 'fan light' Alexa ... 'Fortrezz Strobe' published as 'strobe' Alexa ... 'Hue Bulb' published as 'office bulb' Alexa ... 'Insteon Dimmer' published as 'valve' Alexa ... 'Insteon On/Off' published as 'back door' Alexa ... 'Insteon Thermostat' published as 'thermostat' Alexa ... 'Kasa Plug' published as 'garage door' Alexa ... 'Office Siren' published Alexa ... 'outlet' published Alexa ... 'Simple Virtual On/Off' published as 'simple switch' Alexa A total of 15 devices are currently published to Alexa Alexa Warning If you can't control a device, rerun discover from your Alexa device.
Showing Publications
You can also select the Plugins->Alexa->Show Device Publications menu item to show this list with more details and sorted by the Alexa name:
Alexa Currently published devices (Alexa name first if different than Indigo name): Alexa 'Office Siren' ('Office Siren') - Type: RelayDevice - Subtype: Siren Alexa 'automatic door' ('automatic door') - Type: RelayDevice - Subtype: Door Controller Alexa 'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock Alexa 'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind Alexa 'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None Alexa 'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer Alexa 'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller Alexa 'office bulb' ('Hue Bulb') - Type: DimmerDevice - Subtype: Color Bulb Alexa 'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan Alexa 'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In Alexa 'outlet' ('outlet') - Type: RelayDevice - Subtype: Outlet Alexa 'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch Alexa 'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In Alexa 'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None Alexa 'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve
Discovery Requests from Alexa
Alexa Alexa discovery request received, assembling reply... Alexa ...'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None Alexa ...'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch Alexa ...'upstairs siren' ('Fortrezz Siren') - Type: RelayDevice - Subtype: Siren Alexa ...'outlet' - Type: RelayDevice - Subtype: Outlet Alexa ...'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer Alexa ...'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan Alexa ...'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock Alexa ...'automatic door' - Type: RelayDevice - Subtype: Door Controller Alexa ...'Office Siren' - Type: RelayDevice - Subtype: Siren Alexa ...'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None Alexa ...'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind Alexa ...'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In Alexa ...'office bulb' ('Hue Bulb') - Type: RelayDevice - Subtype: Plug-In Alexa ...'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In Alexa ...'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller Alexa ...'outside lights' ('Outdoor Appliance Module (45604)') - Type: RelayDevice - Subtype: Plug-In Alexa ...'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve Alexa Found 17 devices to publish, replying
Command Requests from Alexa
Full Switch
- Disable the Alexa-Hue Bridge plugin.
- In the Alexa web site, remove all devices. The simplest way is to click the
Remove Allbutton at the bottom. Note, if you are using other smart home skills, using that button will also cause those devices to be forgotten, so when you do a discover later you'll need to perform any steps needed to make discover work on for that skill. - In Indigo, follow the directions above in the Making a Device Available in Alexa to publish your devices.
- Once you have all your devices published, you can confirm that they are all published by selecting the
Plugins->Alexa->Show Device Publicationsmenu item and it will print the list of publications in the Event Log window. - In the Alexa app, website, or using an Alexa enabled device, click/touch the Discover button or say "discover devices".
Partial Switch
- Disable the device from the Alexa-Hue Bridge plugin (see the docs for the plugin for details). This is very critical in order to avoid complications/confusion later.
- In the Alexa web site, remove that specific device.
- In Indigo, follow the directions above in the Making a Device Available in Alexa to publish your device. Be sure to confirm/select the appropriate subtype.
Alexa Troubleshooting
Because this integration is made up of a variety of parts, and because Alexa itself can talk to multiple smart home skills as well as allow the definition of custom "routines", there are a variety of places where things can go wrong. This section will hopefully cover many of those scenarios.
Device Caching
- You have previously linked your license to Alexa but haven't revoked it on the Authorizations page in your Indigo Account. This may happen if you disable the Indigo Skill then attempt to re-enable it. Click on the Revoke button next to the Alexa authorization for your license to revoke the authorization then try linking again.
- Your Indigo Up-to-Date subscription has expired. To use Alexa (and similar types of integrations), you need to have an active Indigo Up-to-Date subscription and your reflector must be active.
- Your Indigo License doesn't have an active/working Indigo Reflector (included with your UTD subscription). To use Alexa (and similar types of integrations), you need to have an active Indigo Up-to-Date subscription and your reflector must be active.
Changing the Indigo Name
Changing the Device Type
- In the Alexa app, remove the device.
- Go back to the Publication Dialog, select the device, and make sure that you are satisfied with the subtype (or change it as necessary).
- Save any changes.
- Rerun discovery in Alexa.
General Issues
- Make sure that you have enabled the Indigo Skill and linked it to your Indigo Account & license successfully
- Make sure that your Indigo Up-to-Date subscription is active.
- Ensure that your Indigo Reflector is configured and connected. Check this by hitting your reflector URL in a browser: https://YOURREFLECTORNAME.indigodomo.net/
Alexa can't find a device
Watch the Event Log window for discovery requests
If you don't see any discovery requests:
- Make sure that your reflector is up and running
- Make sure your Indigo Up-to-Date subscription hasn't lapsed
- Make sure you have OAuth enabled in the Start Local Server dialog
If you see a discovery request:
- Make sure that the device you are publishing is in the list. Take note of the names of your published devices to ensure that they are unique - if you publish two devices with the same name Alexa will ignore or both of them.
- If the above step is fine, then make sure that you aren't using a name that's used by a device in some other smart home skill (some users use the Hue skill to directly control Hue lights, if you have the Alexa-Hue Bridge plugin enabled that may also be publishing a device with the same name).
- Make sure that you are giving Alexa enough time to update its caches - 10 minutes after a discovery is the recommended wait time.
- If you have a slow or unreliable internet connection, Alexa can timeout a request rather quickly and will speak some error message. If you see inconsistent behavior, this may be a hint that there is some kind of internet connection issue between the Alexa hosted servers and your Indigo Server (see below for more details).
Alexa can't control a device
- Make sure you are clearly saying the device name. Alexa can sometimes hear something slightly different than what you're saying.
- Make sure you have the device published in the plugin. You can do this by selecting the
Plugins->Alexa->Show Device Publicationsmenu item. Verify that you are saying the name that is published to Alexa if it's different than the name of the device in Indigo. - Rerun discovery from the Alexa app for an Alexa device.
- Look in the Event Log window for errors when trying to control the device.
- Make sure that the value doesn't contain any SSML markup symbols by themselves, like <, >, /, etc. Alexa will just throw a very unhelpful error ("Sorry, I'm having trouble accessing your Indigo Skills skill right now") when it thinks that the string contains malformed SSML.
- Make sure that the value of the variable is less than 8000 characters - that's the speech output limit for Alexa.
- If you have too many variables, you may get the error “There is a problem with the requested skill response”. The issue is that the speech output sent to Alexa can't be longer than 8000 characters, so if you have a lot of variables or lots of variables with long names you may run into this situation. The next release of the plugin will only speak variables that have the "Remote Display" flag set for them, so you will be able to exclude variables using that mechanism without deleting them.
If All Else Fails =
