Alexa
Smart Home Skill
*Note: the Alexa skill is currently available in the Alexa skill stores for most of the regions in which we sell Indigo (US, Canada, UK, the Netherlands, Australia, New Zealand, France, Germany, Spain, Italy).*
  1. Open the Alexa App.
  4. Tap the Search icon.
  5. Search for "Indigo Smart Home". You should see a skill named Indigo Smart Home Skill in English speaking regions and Indigo Smart Home everywhere else, with an icon that matches the logo of the Mac Client.
  6. Add the skill.
    2. On the next page (the authorization page), if you have multiple Indigo Licenses, make sure you have the correct one selected (you must have an active Indigo Up-to-Date subscription); you can link one license to one Alexa (Amazon) account. If you see something else or don't see a license you were expecting to see, check the #Account Linking Issues troubleshooting section below for help.
To make a device available to Alexa, you must explicitly publish it. Use thePlugins->Alexa->Manage Device Publications... menu item to open the publication dialog:
Alexa Type Popup Image
Warning: be sure to click the Save button before moving on or your changes won't be saved. Also, if you make any changes, you will need to rerun discovery from an Alexa device or the Alexa app before those changes will be reflected. As a reminder, you must either click the discover devices button in the Alexa apps or ask "Alexa, discover devices" of an Alexa enabled device.
Device Types Supported
  • Thermostats
On/Off Devices
  • Alexa, turn on office lamp
  • Alexa, turn off bedroom fan
  • Alexa, open garage door
Alexa Relay Subtypes Image
The options are:
    • Alexa, open the front door
    • Alexa, open the garage door
    • Alexa, lock the back door
    • Alexa turn off desk lamp
Dimmer Devices
warm, warm white 2200
incandescent, soft white 2700
white 4000
daylight, daylight white 5500
cool, cool white 7000
Alexa Dimmer Subtypes Image
The options are:
    • Alexa, close the shades
    • Alexa, ceiling fan speed
    • Alexa, turn off ceiling fan
    • Alexa, turn off the valve
Indigo Fan Devices
- *Alexa, set ceiling fan to medium*
- *Alexa, set ceiling fan to highest*
- *Alexa, increase ceiling fan speed*
- *Alexa, turn off ceiling fan*
Indigo Thermostat Devices
NOTE: the Alexa implementation for thermostats is quite limited as it only fully supports thermostats that are in either heat or cool mode. In North America, most thermostats stay in auto mode, which allows (at least) two setpoints to be active at the same time to call for heat or cool depending on the temp. Alexa's support for auto mode is fundamentally read-only: you can't adjust either setpoint while in auto. Further, the error that Alexa will respond with implies that you have to manually set the mode on the thermostat itself to either heat or cool in order for you to adjust setpoints. This is incorrect in that you can say to Alexa "set the thermostat to heat", and that will correctly change mode from auto to heat (same applies to cool).
- *Alexa, set the thermostat to cool*
- *Alexa, what is my thermostat set to*
- *Alexa, turn off the heat*  (<span class="dw-color-orange">**Warning**</span>: this will turn the thermostat off regardless of mode)
- *Alexa, set the AC to seventy-five*
- *Alexa, make it warmer in here*
Custom Indigo Skill
!!! warning "NOTE" the Custom Skill is available in English speaking regions only.
!!! warning "NOTE" Unfortunately, the invocation for the skill is currently different in different regions.
  • US, UK - "indigo" is the invocation
  • CA, AU - "indigo home" is the invocation
!!! note "Note" When naming variables for use with Alexa, you should use underscores_to_separate_words. That is how the plugin will map separate words from Alexa onto variables (which can't contain spaces).
  • Alexa, ask Indigo to get "current_weather_conditions"
  • Alexa, ask Indigo to look up "current_weather_conditions"
  • Alexa, ask Indigo to read "current_weather_conditions"
  • Alexa, ask Indigo to say "current_weather_conditions"
  • Alexa, ask Indigo to speak "current_weather_conditions"
  • Alexa, ask Indigo to tell me "the_status_of_the_house"
  • Alexa, ask Indigo for the value of variable "current_weather_conditions"
  • Alexa, ask Indigo the value of "current_weather_conditions"
  • Alexa, ask Indigo the current value of "weather_conditions"
The value of variable "current weather conditions" is "mostly cloudy"
Get a List of Variables
Execute an Action Group
  • Alexa, tell Indigo to arm "the kitchen zone"
  • Alexa, tell Indigo to do "my favorite thing"
  • Alexa, tell Indigo to execute "toggle music"
  • Alexa, tell Indigo to launch "rocket"
  • Alexa, tell Indigo to make "the house secure"
  • Alexa, tell Indigo to perform "routine maintenance"
  • Alexa, tell Indigo to play "my favorite playlist"
  • Alexa, tell Indigo to reset "the alarm"
  • Alexa, tell Indigo to restart "the laundry timer"
  • Alexa, tell Indigo to restore "the standard speaker set"
  • Alexa, tell Indigo to run "routine maintenance"
  • Alexa, tell Indigo to start "the laundry timer"
  • Alexa, tell Indigo to set "the playlist to classic rock"
Action group names can contain letters, numbers, and spaces only. If you say "playlist eighties music", the action group name will need to be "playlist 80s music". If you are unsure how to name an action group, just attempt to execute it with one of the above utterances. If Indigo doesn't find an action group matching what you said, it will log it to the Event Log window like this:
''Alexa Error an action group named 'kitchen zone' does not exist in your indigo server ''
Note: what you say before the action group name will work for any action group name. We picked the above examples only because they are normal complete English sentences, but you could just as well say Alexa, tell Indigo to arm "the laundry timer" and the effect would be the same as saying Alexa, tell Indigo to start "the laundry timer". You can also use tell Indigo interchangeably with ask Indigo.
Alexa Plugin operations
Plugin Startup
Started plugin "Alexa 2022.2.0" Alexa Finding devices to publish to Alexa... Alexa ... '010 - Smart Fan Control (14287)' published as 'office fan' Alexa ... '016 - Plug-In Appliance Module (ZL-PA-100)' published as 'office lamp' Alexa ... '038 - Lamp Module (AD130)' published as 'blinds' Alexa ... 'automatic door' published Alexa ... 'FanLinc - Fan' published as 'ceiling fan' Alexa ... 'FanLinc - Light' published as 'fan light' Alexa ... 'Fortrezz Strobe' published as 'strobe' Alexa ... 'Hue Bulb' published as 'office bulb' Alexa ... 'Insteon Dimmer' published as 'valve' Alexa ... 'Insteon On/Off' published as 'back door' Alexa ... 'Insteon Thermostat' published as 'thermostat' Alexa ... 'Kasa Plug' published as 'garage door' Alexa ... 'Office Siren' published Alexa ... 'outlet' published Alexa ... 'Simple Virtual On/Off' published as 'simple switch' Alexa A total of 15 devices are currently published to Alexa Alexa Warning If you can't control a device, rerun discover from your Alexa device.
Showing Publications
You can also select the Plugins->Alexa->Show Device Publications menu item to show this list with more details and sorted by the Alexa name:
Alexa Currently published devices (Alexa name first if different than Indigo name): Alexa 'Office Siren' ('Office Siren') - Type: RelayDevice - Subtype: Siren Alexa 'automatic door' ('automatic door') - Type: RelayDevice - Subtype: Door Controller Alexa 'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock Alexa 'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind Alexa 'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None Alexa 'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer Alexa 'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller Alexa 'office bulb' ('Hue Bulb') - Type: DimmerDevice - Subtype: Color Bulb Alexa 'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan Alexa 'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In Alexa 'outlet' ('outlet') - Type: RelayDevice - Subtype: Outlet Alexa 'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch Alexa 'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In Alexa 'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None Alexa 'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve
Discovery Requests from Alexa
Alexa Alexa discovery request received, assembling reply... Alexa ...'ceiling fan' ('FanLinc - Fan') - Type: SpeedControlDevice - Subtype: None Alexa ...'simple switch' ('Simple Virtual On/Off') - Type: RelayDevice - Subtype: Switch Alexa ...'upstairs siren' ('Fortrezz Siren') - Type: RelayDevice - Subtype: Siren Alexa ...'outlet' - Type: RelayDevice - Subtype: Outlet Alexa ...'fan light' ('FanLinc - Light') - Type: DimmerDevice - Subtype: Dimmer Alexa ...'office fan' ('010 - Smart Fan Control (14287)') - Type: DimmerDevice - Subtype: Fan Alexa ...'back door' ('Insteon On/Off') - Type: RelayDevice - Subtype: Lock Alexa ...'automatic door' - Type: RelayDevice - Subtype: Door Controller Alexa ...'Office Siren' - Type: RelayDevice - Subtype: Siren Alexa ...'thermostat' ('Insteon Thermostat') - Type: ThermostatDevice - Subtype: None Alexa ...'blinds' ('038 - Lamp Module (AD130)') - Type: DimmerDevice - Subtype: Blind Alexa ...'office lamp' ('016 - Plug-In Appliance Module (ZL-PA-100)') - Type: RelayDevice - Subtype: Plug-In Alexa ...'office bulb' ('Hue Bulb') - Type: RelayDevice - Subtype: Plug-In Alexa ...'strobe' ('Fortrezz Strobe') - Type: RelayDevice - Subtype: Plug-In Alexa ...'garage door' ('Kasa Plug') - Type: RelayDevice - Subtype: Garage Controller Alexa ...'outside lights' ('Outdoor Appliance Module (45604)') - Type: RelayDevice - Subtype: Plug-In Alexa ...'valve' ('Insteon Dimmer') - Type: DimmerDevice - Subtype: Valve Alexa Found 17 devices to publish, replying
Command Requests from Alexa
Full Switch
  4. Once you have all your devices published, you can confirm that they are all published by selecting the Plugins->Alexa->Show Device Publications menu item and it will print the list of publications in the Event Log window.
  5. In the Alexa app, website, or using an Alexa enabled device, click/touch the Discover button or say "discover devices".
Partial Switch
  4. In the Alexa app, website, or using an Alexa enabled device, click/touch the Discover button or say "discover devices".
Alexa Troubleshooting
Because this integration is made up of a variety of parts, and because Alexa itself can talk to multiple smart home skills as well as allow the definition of custom "routines", there are a variety of places where things can go wrong. This section will hopefully cover many of those scenarios.
Device Caching
Changing the Indigo Name
Changing the Device Type
  3. Save any changes.
  4. Rerun discovery in Alexa.
General Issues
  2. Make sure that your Indigo Up-to-Date subscription is active.
  3. Ensure that your Indigo Reflector is configured and connected. Check this by hitting your reflector URL in a browser: https://YOURREFLECTORNAME.indigodomo.net/
Alexa can't find a device
Alexa can't control a device
  2. Make sure you have the device published in the plugin. You can do this by selecting the Plugins->Alexa->Show Device Publications menu item. Verify that you are saying the name that is published to Alexa if it's different than the name of the device in Indigo.
  1. Make sure that the value doesn't contain any SSML markup symbols by themselves, like <, >, /, etc. Alexa will just throw a very unhelpful error ("Sorry, I'm having trouble accessing your Indigo Skills skill right now") when it thinks that the string contains malformed SSML.
  1. If you have too many variables, you may get the error “There is a problem with the requested skill response”. The issue is that the speech output sent to Alexa can't be longer than 8000 characters, so if you have a lot of variables or lots of variables with long names you may run into this situation. The next release of the plugin will only speak variables that have the "Remote Display" flag set for them, so you will be able to exclude variables using that mechanism without deleting them.
If All Else Fails =
