| Property |
Type |
Writable |
Description |
description |
string |
Yes |
description of the action group |
folderId |
integer |
No |
unique ID of the folder this action group is in |
id |
integer |
No |
a unique id of the action group, assigned on creation by IndigoServer |
name |
string |
Yes |
the unique name of the action group - no two action groups can have the same name |
remoteDisplay |
boolean |
No |
True if this action group is shown in remote clients, False otherwise |
indigo.actionGroup.delete(123) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the action group to delete |
Display In Remote UI
indigo.actionGroup.displayInRemoteUI(123, value=True) |
indigo.actionGroup.displayInRemoteUI(123, value=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
No |
integer |
id or instance of the action group |
*value* |
Yes |
boolean |
True to show the action group or False to hide it |
indigo.actionGroup.duplicate(123, duplicateName="New Name") |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the action group to duplicate |
*duplicateName* |
No |
string |
name for the new action group trigger |
indigo.actionGroup.execute(123) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the action group to execute |
indigo.actionGroup.moveToFolder(123, value=987) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
*value* |
Yes |
integer |
id or instance of the folder to move the action group to |
