Managing Your Z-Wave® Network
- Choose the
Interfaces->Z-Wave->Enablemenu item. This should cause theConfigure Z-Wavedialog to open automatically (but only the first time you enable Z-Wave - you can select theInterfaces->Z-Wave->Configure...menu item to get back to the configuration dialog later): - The default
Configure Z-Wavedialog.
Adding a Z-Wave Device
- Select
New...button. You'll see theCreate New Devicedialog. - Select
Define and Sync...button. - You'll see the
Using Encryption
If you added a device to the network (Z-Wave Controller) without encryption enabled and then wish to enable encryption you must first remove it from the network. This is because the encryption key exchange can only occur with Indigo if the device has just been added to the network (within a few seconds), and before a device can be added to the network it must not be included in any networks. To do this you can use the [Interfaces->Z-Wave->Start Controller Exclusion Mode](#start-controller-exclusion-mode) menu item to put the Z-Wave Controller into exclusion mode, then follow the steps from the device's manual to have it exclude itself from the network. Once excluded (you can see the progress in the [Event Log window](ui_tour.md#event-log-window)), you can then use the New with Encryption Enabled button inside the Syncrhonize Z-Wave Device dialog to re-add it to the network with encryption.
- Select
Edit...button) - You'll see the standard
Edit Device Settings...button and you'll see the configuration dialog:
- Select
Edit...button). - Click the
Define and Sync...button. - Click on the
Syncbutton. - When the
- Select
Define and Sync...button. - Follow the instructions on the dialog to use your interface to include the device into your network if you haven't already.
Sync using nodepopup - Click on the "Sync" button.
- When the
Deleting a Z-Wave Device
- Select
- Click the
Delete...button (or press the Delete key on the keyboard).
Replacing a Z-Wave Controller
- Select the
Interfaces->Start Controller Exclusion Mode. Note you can exclude from any controller, not just the one it was included with. - Go to the Z-Wave device closest to your Mac that’s not battery powered (also skip any that require encryption) and perform its exclusion process.
- Finally, select the
Interfaces->Z-Wave->Optimize Z-Wave Network...menu item and clickStart Optimization- you can do this at night just before going to bed when the network is likely to be the least busy.
Z-Wave Menu Options
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
Reset Z-Wave Interface
