About this Reference
# some code here
# that does something
| Term | Meaning |
Introduction
For Scripters and Developers:
For Developers:
| Devices | ||||
| Schedule | ||||
Schedule (indigo.Schedule) |
| Triggers | ||||
| Action Groups | ||||
| Variables | ||||
| General Commands | ||||
IOM Class Hierarchy
Indigo specific data types
- keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
Built-in objects
| Object | Description |
The other additional method is subscribeToChanges(). This method doesn't return anything - rather, it tells the IndigoServer that your plugin wants notification of all changes to the specific object type. Use this method sparingly as it causes a significant amount of traffic between IndigoServer and your plugin. What kind of plugins would use this? One good example is a logging plugin - one that's logging activity within Indigo (like our SQL Logger). Another example is a plugin that's doing some kind of scene management - you would probably want to issue a indigo.devices.subscribeToChanges() at plugin start so that you'll always be notified when any device changes - you can then determine if your scene "state" has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change. Use the lower-level subscribeToIncoming() and subscribeToOutgoing() methods in the indigo.insteon and indigo.x10 command spaces to see commands regardless of their effect on device state.
Iterating Object Lists
for dev in indigo.devices:
# do stuff with dev here
Here's a list of all device filters: | Filter | Description | | --- | --- | | indigo.zwave | include Z-Wave devices | | indigo.insteon | include INSTEON devices | | indigo.x10 | include X10 devices | | com.mycompany.myplugin | include all devices defined by a plugin | | indigo.responder | include devices whose state can be changed | | indigo.controller | include devices that can send commands | | indigo.iodevice | input/output devices | | indigo.dimmer | dimmer devices | | indigo.relay | relay, lock, or other 2 state devices | | indigo.sensor | sensor devices (motion, temperature, etc.) | | indigo.speedcontrol | multi-speed controlled device (fans, motors, etc.) | | indigo.sprinkler | sprinklers | | indigo.thermostat | thermostats | | self | include devices defined by the calling plugin | | self.myDeviceType | include myDeviceType's devices defined by the calling plugin | | com.company.plugin.xyzDeviceType | include xyzDeviceType's defined by another plugin |
Triggers also have filters:
for var in indigo.variables:
# all variables
Common Python Exceptions
| Possible Exceptions | |
ArgumentError |
IndexError |
KeyError |
PluginNotFoundError |
TypeError |
ValueError |
Classes and Commands
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
- Device classes
- Trigger classes
- Action classes
- Action Group class
- Variable class
- Folder class
