Indigo Mac Client
Home Window
Main Window Image
The Home Window has 4 areas:
  1. Outline View
  2. Item List
  3. Item Detail
  4. Status Bar
Outline View
Outline View Controls Image
  • Rename Folder... allows you to rename the folder.
Item List
Device Contextual Menu Image
This menu will:
  6. Copy a Python script string that will return an instance of the selected device. It will look like this: indigo.devices[91776575] # "Living Room Switch"
  1. Enable/disable the event.
  5. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.triggers[565290390] # "Motion Sensor Dawn Triggered"
  4. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.actionGroups[1703232002] # "Toggle Variable"
  4. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.controlPages[249813574] # "iPad Landscape"
Item Detail
Device Details Tile Image
Custom States Tile Image
Lights/Appliances
On Off Dimmer Tile Image
Color Controls Tile Image
Sensor Controls Tile Image
Speed Controls
Speed Controls Image
Sprinklers
Sprinkler Controls Image
Thermostats
Thermostat Controls Image
Generic Output Devices
I/O Controls Image
Triggers and Schedules
Action Group Controls Image
Control Pages
Status Bar
Event Log Window
Event Log Window Image
Click the Clear Window button to clear the log entries. Click on Show Event Logs Folder to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 7->Preferences... and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside that period of time.
Variable Window
Indigo 7.4 Menu
Indigo 7 Menu Image
  • About Indigo 7 - this will show the About window which will show what client and server versions you're running and will show your registration code
  • Preferences... - this opens the preferences dialog
  • License Details... - this opens the Subscription Status window that will show you the status of your License and it's associated Up-to-Date Subscription:
Subscription Status Image
File Menu
File Menu Image
Edit Menu
View Menu
Interfaces Menu
Plugins Menu
Window Menu
Window Menu Image
Help Menu
Help Menu Image
  • Email Log... - this option will email some of your event log data to the specified email address. Particularly useful for technical support
  • Indigo 7 Documentation - this will open your browser to the landing page for all Indigo 7 documentation
