Triggers
Trigger Base Class
trigger=indigo.triggers[123]
Commands (indigo.trigger.*)
indigo.trigger.delete(123)
direct parameter Yes integer id or instance of the trigger to delete
*duplicateName* No string name for the newly duplicated trigger
Enable/Disable Trigger
*value* Yes boolean True to enable, False to disable
*delay* No integer number of seconds to delay before disabling or enabling the trigger
*duration* No integer number of seconds before the trigger is switched back to its original state
Execute Trigger
*ignoreConditions* No boolean will ignore any conditions associated with the trigger if True (default) and will evaluate conditions if False
*value* Yes integer id or instance of the folder to move the trigger to
DeviceStateChangeTrigger
State Change Type Enumeration
indigo.kStateChange
BecomesEqual *stateSelector* becomes equal to *stateValue* *ActiveZone* \ AnalogInput \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput
BecomesFalse *stateSelector* becomes *False* *BinaryInput* \ BinaryOutput \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ Zone
BecomesGreaterThan *stateSelector* becomes greater than *stateValue* *AnalogInput* \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput
BecomesLessThan *stateSelector* becomes less than *stateValue* *AnalogInput* \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput
BecomesNotEqual *stateSelector* becomes not equal to *stateValue* *ActiveZone* \ AnalogInput \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput
BecomesTrue *stateSelector* becomes True *BinaryInput* \ BinaryOutput \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ Zone
Changes *stateSelector* has any change *ActiveZone* \ AnalogInput \ AnalogInputsAll \ BinaryInput \ BinaryInputsAll \ BinaryOutput \ BinaryOutputsAll \ BrightnessLevel \ HumidityInput \ HumidityInputsAll \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanMode \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ SensorInput \ SensorInputsAll \ SetpointCool \ SetpointHeat \ TemperatureInput \ TemperatureInputsAll \ Zone
State Selector Enumeration
indigo.kStateSelector
Value Description
ActiveZone monitor the sprinkler’s activeZone to become =, !=, or any change
AnalogInput monitor (one of) the analog input(s) available on the device for =, !=, <, >, or any change - stateSelectorIndex is required to be in the range of available inputs
AnalogInputsAll monitors all of the analog inputs available on the device for any change
BinaryInput monitor (one of) the binary input(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available inputs
BinaryInputsAll monitors all of the binary inputs available on the device for any change
BinaryOutput monitor (one of) the binary output(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available outputs
BinaryOutputsAll
*BrightnessLevel* monitor the brightness level of a device for =, !=, <, >, and any change
HumidityInput monitor (one of) the humidity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs
HumidityInputsAll monitors all of the humidity sensors available on the device for any change
HvacCoolerIsOn monitor the thermostat for any time the air conditioning turns on, off, or has any change (coolIsOn is the current compressor state)
HvacFanIsOn monitor the thermostat for any time the fan turns on, off, or has any change (fanIsOn is the current fan state)
HvacFanMode monitor the fanMode of the thermostat for any change
HvacFanModeIsAlwaysOn monitor the fanMode of the thermostat for a change to/from kFanMode.AlwaysOn
HvacFanModeIsAuto monitor the fanMode of the thermostat for a change to/from kFanMode.AutoOn
HvacHeaterIsOn monitor the thermostat for any time the heater turns on, off, or has any change (heatIsOn is the current heater state)
HvacOperationMode monitor the hvacMode of the thermostat for any change
HvacOperationModeIsAuto monitor the hvacMode of the thermostat for a change to/from kHvacMode.HeatCoolOn
HvacOperationModeIsCool monitor the hvacMode of the thermostat for a change to/from kHvacMode.CoolOn
HvacOperationModeIsHeat monitor the hvacMode of the thermostat for a change to/from kHvacMode.HeatOn
HvacOperationModeIsOff monitor the hvacMode of the thermostat for a change to/from kHvacMode.Off
HvacOperationModeIsProgramAuto monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramAuto
HvacOperationModeIsProgramCool monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramCool
HvacOperationModeIsProgramHeat monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramHeat
KeypadButtonLed FIXME
OnOffState monitor the device for a change to/from on/off
SensorInput monitor (one of) the sensor input(s) available on the device for =, !=, <, >, or any change - stateSelectorIndex is required to be in the range of available inputs
SensorInputsAll monitors all of the sensor inputs available on the device for any change
SetpointCool monitor the cool setpoint of the thermostat for =, !=, <, >, or any change
SetpointHeat monitor the heat setpoint of the thermostat for =, !=, <, >, or any change
TemperatureInput monitor (one of) the temperature sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs
TemperatureInputsAll monitors all of the temperature sensors available on the device for any change
Zone monitor (one of) the binary output(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available outputs
| Command Syntax Examples | | --- | | python indigo.devStateChange.create(name="Trigger Name Here", description="Description Here", folder=1234) |
*description* No string the description of the trigger
*folder* No integer id or instance of the folder in which to put the newly created trigger
theTrigger.deviceId = 738
theTrigger.stateValue = 80
theTrigger.replaceOnServer()
EmailReceivedTrigger
emailFilter kEmailFilter Yes the type of email filter based on the *kEmailFilter* enumeration below
emailFrom string Yes if *emailFilter* is *MatchEmailFields*, the value to match against the sender’s address
emailSubject string Yes if *emailFilter* is *MatchEmailFields*, the value to match against the subject line
Email Filter Enumeration
indigo.kEmailFilter
Value Description
AnyEmail when any email is received
MatchEmailFields when email subject/from fields match
Commands (indigo.emailRcvd.*)
| Command Syntax Examples | | --- | | python indigo.emailRcvd.create(name="Trigger Name Here", description="Description Here", folder=1234) |
InsteonCommandReceivedTrigger
INSTEON Command Enumeration
indigo.kInsteonCmd
Value Description
AllBrighten when an all brighten command begins
AllDim when an all dim command begins
AllInstantOff when an all instant (fast) off is received
AllInstantOn when an all instant (fast) on is received
AllOff when an all off is received
AllOn when an all on is received
AnyCommand when any command is received
Brighten when a brighten command begins
Dim when a dim command begins
InstantOff when an Instant (Fast) off is received in response to a double-tap
InstantOn when an Instant (Fast) on is received in response to a double-tap
Off when an off command is received
On when an on command is received
StatusChanged when a status change broadcast is received
indigo.kDeviceSourceType
Value Description
*NoDevice* when the source uses no device or address (only used for X10 RF A/V remotes)
Device when the source is an existing device, the ID is specified
Address when the source is a raw X10 address
AnyAddress when the source is any X10 address or INSTEON device
| Command Syntax Examples | | --- | | python indigo.insteonCmdRcvd.create(name="Trigger Name Here", description="Description Here", folder=1234) |
theTrigger.buttonOrGroup = 1
InterfaceFailureTrigger
| Command Syntax Examples | | --- | | python indigo.interfaceFail.create(name="Trigger Name Here", description="Description Here", folder=1234) |
InterfaceInitializedTrigger
| Command Syntax Examples | | --- | | python indigo.interfaceInit.create(name="Trigger Name Here", description="Description Here", folder=1234) |
PluginEventTrigger
| Command Syntax Examples | | --- | | python indigo.pluginEvent.create(name="Trigger Name Here", description="Description Here", folder=1234), pluginId="com.mycompany.myplugin", pluginTypeId="myEvent", props={"propA":"value","propB":"value"} |
*pluginId* No string the plugin id of the plugin that owns the device you're creating - if it's not present it defaults to your plugin's id
*pluginTypeId* Yes string this is the id of the as specified in the Events.xml or in the documentation for the plugin
*props* No dictionary this is the properties for the trigger - they will be inserted in to the pluginId's property space as supplied above. If you are creating a trigger of a type defined in a different plugin, it's that plugin's id and properties.
PowerFailureTrigger
| Command Syntax Examples | | --- | | python indigo.powerFailure.create(name="Trigger Name Here", description="Description Here", folder=1234) |
ServerStartupTrigger
| Command Syntax Examples | | --- | | python indigo.serverStartup.create(name="Trigger Name Here", description="Description Here", folder=1234) |
X10CommandReceivedTrigger
X10 Command Enumeration
indigo.kX10Cmd
Value Description
AllLightsOff when an all lights off is received
AllLightsOn when an all lights on is received
AvButtonPressed when an A/V button press is received
ExtendedData when an extended data X10 command is received
PresetDim when a preset dim command is received
StatusOffResponse when a status off response is received
StatusOnResponse when a status on response is received
X10 A/V Button Enumeration
indigo.kX10AvButton
Value Value
*0* *Left*
*1* *Menu*
*2* *Mute*
*3* *Pause*
*4* *PC*
*5* *Play*
*6* *Power*
*7* *Recall*
*8* *Record*
*9* *Return*
AB *Rewind*
ChannelDown *Right*
ChannelUp *Stop*
Display *Title*
Down *Up*
Enter *VolumeDown*
Exit *VolumeUp*
Forward
| Command Syntax Examples | | --- | | python indigo.x10CmdRcvd.create(name="Trigger Name Here", description="Description Here", folder=1234) |
myTrigger.address = "F7"
myTrigger.replaceOnServer()
VariableValueChangeTrigger
variableValue string the value to compare against the variable’s value if *variableChangeType* is =, !=, >, <
indigo.kVarChange
Value Description
BecomesEqual variable value becomes equal to
BecomesFalse variable value becomes false
BecomesGreaterThan variable value becomes greater than
BecomesLessThan variable value becomes less than
BecomesNotEqual variable value becomes not equal to
BecomesTrue variable value becomes true
Changes variable value has any change
| Command Syntax Examples | | --- | | python indigo.varValueChange.create(name="Trigger Name Here", description="Description Here", folder=1234) |
