Device Base Class
Device Base Class Properties
address string No the address for the device
batteryLevel integer No battery level for the device - None if the device doesn't support battery operation - shortcut for dev.states['batteryLevel']
buttonGroupCount integer No the number of groups (or buttons in the case of the RemoteLinc and ControLinc) that the controller supports - currently used only for INSTEON devices - 0 for other devices
configured boolean No true if the device has been fully configured - if it's a plugin device use this to make sure that the device's config dialog has been run at least once.
description string Yes a description of the device as specified by the user
deviceTypeId string No the typeId specified in the Devices.xml (or it’s documentation) - only used for plugin defined devices
displayStateId string No API v1.15+ only: main display stateId key which can be used as a key into states[] property below
displayStateValRaw boolean integer string or none No API v1.15+ only: raw value of main display state (ex: 72.0)
displayStateValUi string No API v1.15+ only: UI value (string) of main display state (ex: '72.0°F' )
displayStateImageSel kStateImageSel No API v1.18+ only: an enumeration specifying which state image icon is shown in Indigo Touch and Indigo client UI - see state image sel enumeration below for possible values
enabled boolean No is the device enabled - set using the indigo.device.enable() method
energyCurLevel float No API v1.11+ only: current Wattage energy being used by the device (None if not supported)
energyAccumTotal float No API v1.11+ only: current accumulated energy used since last base time specified in energyAccumBaseTime (None if not supported)
energyAccumBaseTime datetime No API v1.11+ only: the base time from which to calculate the energy total (energyAccumTotal) (None if not supported)
energyAccumTimeDelta integer No API v1.11+ only: the time delta in seconds since the last base time (None if not supported)
folderId integer No the unique ID of the folder this device is in (0 if it's not in a folder) - use moveToFolder() method to change
globalProps dictionary No an indigo.Dict() representing all name/value pairs associated with this device - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details
id integer No id or instance of the device, assigned on creation by IndigoServer
lastChanged datetime No the last date/time that the device was changed - populated by IndigoServer
model string No the model name of the device - defined either by Indigo based on type or by the plugin's device definition
name string Yes the unique name of the device - no two devices can have the same name
ownerProps dictionary No API v1.20+ only: an indigo.Dict() representing the name/value pairs defined by the plugin that created the device - this is a shortcut into the owner plugin's globalProps data
pluginId string No if protocol is Plugin, the string ID for the plugin
pluginProps dictionary No an indigo.Dict() representing the name/value pairs defined by your plugin for the device - plugin developers should publish this information if you want other plugins/scripts to create devices of this type - see About Plugin Properties below for details - use replacePluginPropsOnServer() method to change
protocol kProtocol No an enumeration specifying the kProtocol of the device - see protocol enumeration below for possible values
remoteDisplay boolean Yes should this device be displayed in remote clients (IWS, Indigo Touch, etc) - may also be set with indigo.device.displayInRemoteUI()
states dictionary No returns an indigo.Dict() of device states - the key is the state id and the value is the value. Note that enumerated states will have not only the state, but also each option for the state. So, for instance, if I had a state called status and it had 3 options (online, offline, error), then you'd not only have status as a key, but also status.online, status.offline, and status.error as keys in the dictionary. This is so that you can test each state enumeration independently in trigger actions (e.g. status.online is true).
supportsAllLightsOnOff boolean No indicates that this device should react to all lights On and all lights Off commands - always False for plugin defined devices
supportsAllOff boolean No indicates that this device should react to all Off commands - always False for plugin defined devices
supportsStatusRequest boolean No indicates if the device supports querying the status - always False for plugin defined devices
Protocol Enumeration
indigo.kProtocol
Value Description
*X10* identifies the device as an X10 device
State Image Sel Enumeration
API v1.18+ only: note Indigo Touch and Indigo client UI do not currently have icons for every image selector listed below.
indigo.kStateImageSel
Value Description
None overrides to show no device image icon
Custom overrides to show a plugin defined custom image icon (not yet implemented)
HumidifierOn overrides to show a humidity sensor on icon
DehumidifierOn overrides to show a dehumidifier icon
Method Restricted API Version Description
replacePluginPropsOnServer(newPropsdict) Yes 1.0 If you need to make a change to your plugin's property dictionary that's stored as part of the device (see #About Plugin Properties below) you just use this method to replace the entire dict with a new one. A typical usage will be to get the property dictionary from the device, make changes to the dict, then use this method to store the new dict.
stateListOrDisplayStateIdChanged() Yes 1.0 Plugins can subclass the method getDeviceStateList() to provide dynamic state list definition information. The default implementation provides a static solution by retrieving the device state list definition from the Devices.xml file. Likewise, the method getDeviceDisplayStateId() can be used to dynamically determine which device state should be displayed in the State column of the main device table UI. The problem is that the Indigo Server only calls getDeviceStateList() and *getDeviceDisplayStateId()* at very specific times, like when a plugin device dialog is dismissed. So, call stateListOrDisplayStateIdChanged() on the device instance you need refreshed at any time and Indigo will then automatically call your plugin's getDeviceStateList() and getDeviceDisplayStateId() methods (or use the base implementation of looking up the list from Devices.xml) and update the Indigo Server (and all clients). This is particularly useful for plugin updates that need to add new device states to existing device instances created by older versions. In this case, the plugin will need to update the device instances by calling stateListOrDisplayStateIdChanged(). A likely place to do this type of instance level upgrading is inside your plugin's deviceStartComm() method.
setErrorStateOnServer('error string') Yes 1.0 The supplied string will show in the state column and turn it red. Passing *None* will clear it.
updateStateOnServer(key='keyName', value='Value', clearErrorState=True) Yes 1.0 Use this method to update the value of one of your device's states on the server. The server will propagate the change out to any connected clients and fire any triggers that are defined on that state. Pass "true" (default) or "false" on the clearErrorState parameter (not required) to have the error state of the device (set with setErrorStateOnServer above) cleared.
dev=indigo.devices[123]
About Custom Device States
    <State id="playStatus">
    <State id="sep1">
    <State id="playlist">
        <ValueType>String</ValueType>
    <State id="album">
    <State id="artist">
    <State id="track">
    <State id="volume">
    <State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Commands (indigo.device.*)
All Off
indigo.device.allOff()
Enumerated Type Description
Insteon specify all INSTEON devices that support ON/OFF
X10 specify all X10 devices that support ON/OFF
ZWave specify all Z-Wave devices that support ON/OFF
HouseCodeA specify all X10 devices in house code A
HouseCodeB specify all X10 devices in house code B
HouseCodeC specify all X10 devices in house code C
HouseCodeD specify all X10 devices in house code D
HouseCodeE specify all X10 devices in house code E
HouseCodeF specify all X10 devices in house code F
HouseCodeG specify all X10 devices in house code G
HouseCodeH specify all X10 devices in house code H
HouseCodeI specify all X10 devices in house code I
HouseCodeJ specify all X10 devices in house code J
HouseCodeK specify all X10 devices in house code K
HouseCodeL specify all X10 devices in house code L
HouseCodeM specify all X10 devices in house code M
HouseCodeN specify all X10 devices in house code N
HouseCodeO specify all X10 devices in house code O
HouseCodeP specify all X10 devices in house code P
Beep (API v1.11+ only)
indigo.device.beep(123)
| Command Syntax Examples | | --- | | python indigo.device.create(protocol=indigo.kProtocol.Plugin, address='F8', name='Device Name Here', description='Description Here', pluginId='com.mycompany.pluginId', deviceTypeId='myDeviceTypeId', props={'propA':'value', 'propB':'value'}, folder=1234) |
*address* No string the address of the X10 device - plugins must set an address property in their property dictionary
*description* No string the description of the device
*deviceTypeId* Yes string the id of the device type – defined by the plugin or one of the defined X10 devices FIXME link here
*pluginId* No string the plugin ID - defaults to your plugin's id if in a Server Plugin
*props* No dictionary this is the properties for the device - they will be inserted in to the pluginId's property space as supplied above. If you are creating a device of a type defined in a different plugin, it's that plugin's id and properties.
*protocol* Yes kProtocol the protocol for the device (indigo.kProtocol.Plugin or indigo.kProtocol.X10)
*folder* No integer id or instance of the folder in which to put the newly created device
indigo.device.delete(123)
Enable/Disable
| Command Syntax Examples | | --- | | python indigo.device.enable(123, value=True) #enable indigo.device.enable(123, value=False) #disable |
Get Group List
               ID : 1280166770 (integer)
               ID : 106487666 (integer)
Ping Device (API v1.16+ only)
| Command Syntax Examples | | --- | | python result = indigo.device.ping(123, suppressLogging=True) if result["Success"]: indigo.server.log("%.3f seconds ping for %s" % (result["TimeDelta"]/1000.0, dev.name)) else: indigo.server.log("ping failed for %s" % (dev.name), isError=True) |
Status Request
Toggle
indigo.device.toggle(123)
Turn Off
indigo.device.turnOff(123)
Turn On
indigo.device.turnOn(123)
Here’s a side by site comparison of using various device properties in Python and AppleScript:
Python AppleScript
```python
# Creating a device
name="Office Lamp",
address="F7",
|text
-- Creating a device
address:"F7",¬
```python
# Getting a device
|text
-- Getting a device
```python
|text
-- Logging a message if it’s an X10 device
log "device is an X10 device"
end if
```python
if (myDevice.remoteDisplay):
|text
-- Logging a message if it’s showing in Indigo Touch
end if
```python
|text
-- Folder ID is not available in AppleScript
```python
Turning off all devices in X10 house code A
Turning off all INSTEON devices
indigo.device.allOff(indigo.kAllDeviceSel.Insteon) |text -- Turning off all devices (dimmer and relay) all off
-- Turning off all devices in X10 house code A all lights off "A"
-- Turning off all INSTEON devices is not available in -- AppleScript ``` |
DimmerDevice
Device States
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
direct parameter No kAllDeviceSel enumerated value to indicate which devices to turn off, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description
All Lights On
indigo.dimmer.allLightsOn()
Brighten
indigo.dimmer.brighten(123)
*by* No integer relative amount to brighten by where brightness is 0-100
*delay* No integer number of seconds to delay before executing the brighten command
Dim
indigo.dimmer.dim(123)
*by* No integer relative amount to dim by where dimness is 0-100
*delay* No integer number of seconds to delay before executing the dim command
Set Brightness
*value* Yes integer absolute value to set the brightness to on a scale of 0-100
Set LED State
*index* Yes integer the index of the button. Recall that Python-based arrays are 0-based, so the index is also 0-based. That is, the first object in an array is object 0.
*value* Yes boolean True to turn on the LED, False to turn it off
*suppressLogging* No boolean True to suppress logging (defaults to False)
*updateStatesOnly* No boolean True to only update Indigo's internal state - no command will be sent to the KPL (defaults to False)
Set On State
Here’s a side by site comparison of dimmer properties in Python and AppleScript:
Python AppleScript
```python
# Getting a device
|text
-- Getting a device
```python
(myDevice.onState)):
|text
-- Set a device’s brightness to 75 if it’s currently
end if
```python
|text
-- Brighten a light by 25% after 10 minutes
```python
|text
end if
```python
myDevice.folderId
# OR
``` -- Folder ID is not available in AppleScript
InputOutputDevice
Device States
Commands (indigo.iodevice.*)
Set Binary Output
*index* Yes integer 0-based index of the output to change - should be less than the *binaryOutputCount* property of the device
*value* Yes boolean True to turn the output on, False to turn it off
Python AppleScript
```python
index=1,
value=False)
-- to false set theBinaryInputs to binary inputs ¬ of device "EZIO8SA" if not item 3 of theBinaryInputs then set theBinaryOutputs to binary outputs ¬ of device "EZIO8SA" set item 1 of theBinaryOutputs to false set binary outputs of device ¬ "EZIO8SA" to theBinaryOutputs end if|
SensorDevice
  • X10 Motion Sensors
allowOnStateChange boolean No API v1.6+ only: True if UI controls should be shown or enabled to change the onState
allowSensorValueChange boolean No API v1.6+ only: True if UI controls should be shown or enabled to change the sensorValue
onState boolean No indicates that the device is currently in a triggered or ON state (None if sensor doesn't support ON/OFF)
sensorValue integer or float No API v1.6+ only: the numerical value of a sensor, such as temperature (None if sensor doesn't support sensor values)
Commands (indigo.sensor.*)
Set On State
-- none --
RelayDevice
*onState* boolean No indicates whether the device is on - shortcut to dev.states['onOffState']
Device States
Commands (indigo.relay.*)
Set LED State
Python AppleScript
```python
# Toggle the device
|text
-- Toggle the device
toggle device “Office Lamp”
SpeedControlDevice
*speedIndex* integer No indicates the current speed index for devices that support some fixed # of speeds - shortcut to dev.states['speedIndex']
*speedIndexCount* integer No indicates the number of indexes available for this device (defaults to 4)
*speedLevel* boolean No indicates the level the device is set to (0-100) - shortcut to dev.states['speedLevel']
Device States
speedIndex.ui boolean n/a a more user friendly name for the current index (e.g. high, medium, low, off)
speedLevel boolean speedLevel indicates the level the device is set to (0-100) - use dev.speedLevel property as a shortcut
Decrease Speed Index
Decreases the speed index.
*by* No integer the number of index positions to decrease by. Defaults to 1 if not specified.
*delay* No integer delays the command by the specified number of seconds. Defaults to no delay if not specified.
Increase Speed Index
Increases the speed index.
*by* No integer the number of index positions to increase by. Defaults to 1 if not specified.
Set Speed Index
*value* Yes integer index position to set the index to.
Set Speed Level
*value* Yes integer level of the motor control, from 0-100.
SprinklerDevice
activeZone integer No 1.0 the 1-based index of the active zone (None=all zones off, 1=zone 1, 2=zone 2, ...). Note this property has undergone changes in name (previously called activeZoneIndex) as well as semantics (previously the index being 0-based). As of API v1.12 (Indigo 6.0.3) the property is final and stable.
zoneEnableList list of string No 1.13 API v1.13+ only: list of booleans, starting at zone 1 through zone [*zoneCount*], that specify if a given zone is enabled (has a maximum zone duration > 0).
zoneNames list of string No 1.0 list of zone names, starting at zone 1 through zone [*zoneCount*]. You must include *zoneCount* strings in the list.
zoneMaxDurations list of reals No 1.0 list of zone durations in minutes, starting at zone 1 through zone [*zoneCount*]. You must include *zoneCount* integers in the list.
zoneScheduledDurations list of reals No 1.0 list of currently active zone durations in minutes if a schedule is running (empty list if no schedule is running), starts at zone 1 through zone [*zoneCount*]
pausedScheduleZone integer No 1.16 API v1.16+ only: the 1-based index of the paused sprinkler zone index (None=schedule not paused, 1=zone 1 paused, 2=zone 2 paused, ...).
pausedScheduleRemainingZoneDuration real No 1.16 API v1.16+ only: the paused sprinkler zone duration in minutes (None if schedule not paused)
Device States
Commands (indigo.sprinkler.*)
Next Zone
Pause Schedule
indigo.sprinkler.pause(123)
Previous Zone
Resume Schedule
indigo.sprinkler.resume(123)
Run Schedule
Run a sprinkler schedule.
Stop Schedule
indigo.sprinkler.stop(123)
Set Active Zone
*index* Yes integer 1-based index of the zone to turn on
Python AppleScript
```python
# run schedule
|text
-- AppleScript doesn't support directly running a schedule, so
-- then execute that.
-- run schedule
with properties ¬
end if
set zone durations of ¬
to [10, 15, 8, 0, 0, 0, 0, 0]
execute group actionGroupName
ThermostatDevice
coolIsOn boolean No 1.0 is the cooling system (compressor) currently running - shortcut for dev.states['hvacCoolerIsOn']
heatIsOn boolean No 1.0 is the heater currently running - shortcut for dev.states['hvacHeaterIsOn']
Fan Mode Enumeration
*indigo.kFanMode*
Value Description
AlwaysOn signal the fan that it should be running continuously
Auto signal the fan that it should only run when the HVAC system needs it to be running
HVAC Mode Enumeration
*indigo.kHvacMode*
Value Description
Cool the hvac system is only reacting to cool setpoints
HeatCool the hvac system is reacting to both cool and heat setpoints
Heat the hvac system is only reacting to and heat setpoints
Off the hvac system is turned off
ProgramHeatCool the hvac system is executing it’s built-in automatic program, which usually responds to both heat and cool setpoints
ProgramCool the hvac system is executing it’s built-in cooling program
ProgramHeat the hvac system is executing it’s built-in heating program
Device States
Decrease Cool Setpoint
value Yes integer number of degrees to decrease the cool setpoint
Decrease Heat Setpoint
*value* Yes integer number of degrees to decrease the heat setpoint
Increase Cool Setpoint
*value* Yes integer number of degrees to increase the cool setpoint
Increase Heat Setpoint
*value* Yes integer number of degrees to increase the heat setpoint
Set Cool Setpoint
*value* Yes integer the absolute temperature of the setpoint
Set Fan Mode
Adjust the fan mode.
*value* Yes kFanMode the absolute temperature of the setpoint
Set Heat Setpoint
Set HVAC Mode
Adjust the HVAC mode.
*value* Yes kHvacMode HVAC mode identifier
Python AppleScript
```python
set the thermostat mode to auto
set the heat setpoint to 78
indigo.thermostat.setHeatSetpoint(123, value=78) |text -- increase the cool setpoint by 5 degrees set cool setpoint of device "Thermostat" to ¬ (cool setpoint of device "Thermostat") + 5
-- set the thermostat mode to auto set hvac mode of device "Thermostat" to heatCoolOn
-- set the heat setpoint to 78 set heat setpoint of device "Thermostat" to 78 ``` |
