Folders
Commands (indigo..folder.)
The commands to manipulate folders are within the object lists defined in the IOM Overview page (indigo.devices.folder., indigo.variables.folder., etc).
Delete the specified folder.
Get ID
indigo.device.folder.getId("Some Folder Name")
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
