Folders
Commands (indigo..folder.)
The commands to manipulate folders are within the object lists defined in the IOM Overview page (indigo.devices.folder., indigo.variables.folder., etc).
Delete the specified folder.
Get ID
Since folders aren't available in AppleScript (Deprecated in a future version of Indigo 7), we're only providing Python examples here.
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
