Indigo Plugins and APIs
Indigo has a long history of extensibility - AppleScript Attachment scripts were available from the start (which will be deprecated in a future version of Indigo 7). Later, the Indigo Web Server was added along with the IWS plugin and the ability to add custom images.
Back to Top
Folder Structure Image
in this location:
You'll notice these two folders in particular: Plugins and *Plugins (Disabled)*. These two folders are where the plugin bundles are stored (see the next section for details). Plugins that are enabled from the UI are located in the Plugins folder and when a user disables a plugin it’s moved to the *Plugins (Disabled)* folder.
Back to Top
The Indigo Plugin Bundle
Bundle Layout Image
The Info.plist File
<plist version="1.0">
<dict>
    <key>PluginVersion</key>
    <string>1.2.3</string>
    <key>ServerApiVersion</key>
    <string>2.0</string>
    <key>CFBundleIdentifier</key>
    <key>CFBundleVersion</key>
    <string>1.0.1</string>
    <key>CFBundleURLTypes</key>
    <array>
        <dict>
            <key>CFBundleURLName</key>
        </dict>
    </array>
</dict>
</plist>
  • PluginVersion - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, "1.0.5.2" is valid, but "1.0.5b2" is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.
  • ServerApiVersion - this is the version of the server plugin API as defined by us - for Indigo 7.0, it is 2.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.
  • Bundle name (CFBundleName) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. "ShortName Device Controls"). If it's not provided we'll use the bundle display name instead.
  • Bundle identifier (CFBundleIdentifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the *com.yourorgidentifier.** namespace. This key is required.
  • Bundle version (CFBundleVersion) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 7.0 it will be 1.0.1. This key is required.
  • URL types (CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called "About [PLUGIN NAME]" - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's GitHub repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
You can drop Python scripts and AppleScripts (AppleScript support will be deprecated in a future version of Indigo 7) into this folder and they will show up in your plugin's sub-menu on the new "Plugins" menu. When the user selects the menu item, the script is executed. This is a really simple way of giving your plugin some visible UI.
Resources Folder
This folder is meant to contain any assets (like images, templates, etc.) that your plugin might need. If there is an icon.png file in here, it will be displayed in the Plugin Store once you submit the plugin (see #Plugin Store below for more details).
Indigo Server Plugins
Back to Server Plugins
Indigo Plugin Host
Plugin Failure Handling
  • Plugin Fatal: Errors that occur because of invalid XML or a failure inside the plugin initialization code (init method) are considered fatal. They will log an error and cause the Indigo Server to temporarily suspend the plugin -- the plugin will remain enabled but won't be running. Once the errors are corrected, the plugin can be restarted by its Reload menu option. Because the plugin is still in the enabled state, it will also be restarted on the next Indigo Server restart.
Server Plugin Folder
Server Plugin Folder Image
Indigo Plugin XML Conventions
Important: Most of the major elements will have an id of some kind. It's extremely important that you follow these rules when creating the //id//:
  • id's cannot contain spaces
Configuration Dialogs
<ConfigUI>
    <Field id="autoLabel"
            type="label"
            visibleBindingValue="false">
    </Field>
    <Field id="exampleButton"
            type="button"
        <Title>Find Node ID</Title>
    </Field>
    <Field id="nodeID"
            type="textfield"
            readonly="YES"
        <Label>Node ID:</Label>
    </Field>
    <Field type="checkbox"
            id="manualEntry"
            defaultValue="false">
    </Field>
    <Field id="manualNodeID"
            type="textfield"
            visibleBindingValue="true">
        <Label>Enter Node ID:</Label>
    </Field>
</ConfigUI>
Back to Configuration Dialogs
Text Field
    <Label>Text Field:</Label>
</Field>
enabledBindingId No 1.0 (1.9) If you want to conditionally enable/disable this field based on the value of a checkbox, set this value to the id of that field. \ \ API v1.9: You can also bind to a list field and this field will only be enabled if something is selected in the list.
enabledBindingNegate No 1.9 Set this to "true" to negate the binding. So if the target binding field's value is true then the binding will be false.
Configuration UI Menu Image
    <Label>Popup Menu:</Label>
</Field>
defaultValue No 1.0 (1.9) You can enter a default value here. The value must be one of the values from the List element described below. \ \ API v1.9: If you specify a default value of "" (empty string) and there is no matching option, then the first menu item will be selected when the dialog is first run. This way you can avoid the user seeing "- no selection -" at the bottom of the menu.
</Field>
    return valuesDict
List
Configuration UI List Image
```xml
| *`defaultValue`* | No | 1.0 | You can enter a default value here. The value must be a comma separated list of values, each value must be listed as an option in the *`List`* element. |
| *`enabledBindingId`* | No | 1.0 (1.9) | If you want to conditionally enable/disable this field based on the value of a checkbox, set this value to the id of that field. \\  \\ <span class="dw-color-green">API v1.9</span>: You can also bind to a list field and this field will only be enabled if something is selected in the list. |
| *`enabledBindingNegate`* | No | 1.9 | Set this to "true" to negate the binding. So if the target binding field's value is true then the binding will be false. |
| *`hidden`* | No | 1.0 | If this attribute is set to *`true`* then the field will never be displayed regardless of what other options you have set for it. It’s useful if you need to contain some kind of state variables for the dialog that are controlled by button presses rather than controlled directly by the user. |
| *`id`* | Yes | 1.0 | This is a unique identifier for this *`Field`* within the context of this *`ConfigUI`* element. |
| *`readonly`* | No | 1.0 | This attribute will make the field readonly - useful to show the user data that changes in some other way rather than being manipulated directly by the user. |
| *`rows`* | No | 1.4 | Use this attribute to specify the number of rows that will show in the list. The minimum (and default) is 4. |
| *`tooltip`* | No | 1.0 | The tooltip will be shown when you hover over the actual list control. |
| *`type`* | Yes | 1.0 | This must be *`list`*. |
| *`visibleBindingId`* | No | 1.0 | If you want to conditionally show/hide this field based on the value of another field, set this value to the *`id`* of another field. If you set this, you must also include a *`visibleBindingValue`* |
| *`visibleBindingValue`* | No | 1.0 | If you specify a *`visibleBindingId`*, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to *`false`* will mean the menu field is visible only when the checkbox is unchecked, and a *`true`* means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of *`Option`* values (*`item1, item2`*). You can even bind it to the value in a text field, but that’s probably of limited use. **Note**: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups. |
Static list fields are constructed almost identically to static popup menu fields - with a *`Label`* element and a *`List`* element which contains multiple *`Option`* elements. Each *`Option`* element must have a *`value`* attribute and that attribute is what is what will be passed back to your plugin when the dialog is validated; it may not contain comma or semicolon characters. The text inside the *`Option`* element is what is displayed for each line in the user interface.
As with *`menu`* fields, you may also specify a list dynamically at runtime - that is, when the UI is created, the client will call into your plugin to get the list items. This will allow you to dynamically adjust the list items every time the UI comes up. You can also specify some built-in dynamic items that the IndigoServer will provide automatically for you. See the [#Dynamic Lists](#dynamic-lists) section below for details.
[Back to Configuration Dialogs](#configuration-dialogs)
#### Dynamic Lists
```python
</Field>
Class: indigo.devices
Optional Filters Description
indigo.relay relay devices
indigo.dimmer dimmer devices
indigo.sprinkler sprinklers
indigo.thermostat thermostats
Class: indigo.triggers
</Field>
    return myArray
</Field>
</Field>
Serial Port
Configuration UI Serial Port Socket Image
Configuration UI Serial Port RFC2217 Image
Checkbox
```xml What's on the right side of the checkbox
| *`id`* | Yes | 1.0 | This is a unique identifier for this Field within the context of this *`ConfigUI`* element. |
| *`type`* | Yes | 1.0 | This must be “checkbox”. |
| *`defaultValue`* | No | 1.0 | You can enter a default value here. The value must be either *`true`* or *`false`*. |
| *`visibleBindingValue`* | No | 1.0 | If you specify a *`visibleBindingId`*, you must specify the value(s) here. For instance, if you are binding to a checkbox, setting this to *`false`* will mean the menu field is visible only when the checkbox is unchecked, and a *`true`* means the opposite. To make the field dependent on another list or menu, set this value to a comma separated list of option values (*`item1, item2`*). You can even bind it to the value in a text field, but that’s probably of limited use. **Note**: the string comparison is a contains - so if any option contains the specified string it will match. This offers some extra flexibility in defining dependency groups. |
Checkboxes contain the standard required Label element. They also contain an optional element, *`Description`*, that’s used to deliver extra information on the right side of the checkbox. Many checkboxes may not need this extra information.
Like [button fields](#button), you can specify a *`CallbackMethod`* element in your field definition:
```xml
</Field>
    return valuesDict
Label
Configuration UI Label Image
```xml <Field id="exampleLabel" type="label"
Label fields are used to present text that span the width of the dialog. As you may have noticed,  each control has an element called *`Label`* (with the exception of *`Separator`*, discussed next). When the dialog is displayed, each of those Label elements is right aligned and the actual control is left aligned directly to the right of the label. This field gives you a way to communicate a much longer chunk of text - like instructions, etc. It will actually span the entire width of the dialog and will wrap as necessary. The following table describes the attributes that are available for label fields.
| *`alignText`* | No | 1.4 | This will control how the label text is justified. Valid options are: "left" (default), "center", and "right". |
| *`alignWithControl`* | No | 1.4 | If set to "true", this will align the left margin of the label with the left margin for the actual controls (not their labels). Anything other than "true" will be considered "false" (which is also the default if not specified). This is very useful in conjunction with specifying font characteristics described below when you want to add some help specific to a control - just insert the label right below the control field and it will align with the actual control above. |
| *`fontColor`* | No | 1.4 | Use this attribute to control the color of the label text. Valid options are: "black (default), "darkgray", "red", "orange", "green", and "blue". |
| *`fontSize`* | No | 1.4 | Use this attribute to specify the size of the font. Valid options are: "regular" (default, same size as all other text in the dialog), "small, which is a point or two smaller, and "mini which is yet another point size or two smaller. |
| *`type`* | Yes | 1.0 | This must be *`label`*. |
Labels have a single element, *`Label`*, that holds the text to be displayed. **Note**: in a label field type, the *`Label`* element is required. This field type is read-only, which means that you can't have an error message attached to it from a validation method or a button method (see below for details).
#### Separator
![Configuration UI Separator Image](images/configui_separator.png)
```xml
<Field id="simpleSeparator1"
        type="separator"
        visibleBindingValue="1"/>
Button
Configuration UI Button Image
```xml Visible Button Title ConfigButtonPressed
| *`type`* | Yes | 1.0 | This must be *`button`*. |
Aside from the standard *`Label`* element, the button field also contains two other required elements. The first is the *`Title`* element - this is the string that is displayed inside the button. The other required element is the *`CallbackMethod`* element, which contains the name of a Python method in your code that’s called when the user presses the button. This field type is read-only, which means that you can't have an error message attached to it from a validation method or a button method (see below for details).
The process flow is this:
1. A dictionary containing all the values of the fields in the dialog are sent to the method that you identify in the *`<CallbackMethod>`* element.
1. Your plugin can then do whatever it needs to and it returns a the dictionary back to the dialog containing any field changes.
Each button's method signature will match the parameters that are used in the [#validation methods](#validation-methods) described below. For instance, if you specify a method called "beginPairing" in a button field of the *`<ConfigUI>`* XML for a device like this:
```xml
    <Name>Music Server</Name>
    <ConfigUI>
            <Title>Begin Pairing</Title>
        </Field>
<!-- SNIP -->
</Device>
    return valuesDict
Validation Methods
action validateActionConfigUi(self, valuesDict, typeId, deviceId) typeId - action type specified in the type attribute \ deviceId - the unique device ID for the device the user selected for the action if you specify a *deviceFilter* \ *valuesDict* - the dictionary of values currently specified in the dialog
    return True
    return (True, valuesDict)
    errorDict = indigo.Dict()
Validating serialport Fields
    errorsDict = indigo.Dict()
    if len(errorsDict) > 0:
Notice that at the top of the validation method after we define the errorsDict, we call self.validateSerialPortUi(). This method will look for the fields that make up the specified field ("devicePortFieldId" in this case). It will make sure that a valid serial port is selected if it's a physical connection or that the address field is formatted properly if it's one of the network connections. If not, it will automatically add the appropriate errors to the errorsDict and will attempt to correct any URL prefix errors ("socket:%%%%" or "rfc2217:%%%%"). You can then continue to validate the rest of the fields in your dialog and use the length check on errorsDict to see if there were any errors discovered. If so, return False along with both dicts. If it's empty, just return true with the valuesDict.
Dialog Close Notification
Dialog Type Method Signature
PluginConfig.xml
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 7.3/Preferences/Plugins/
Devices.xml
Name Type Required Notes
Custom Device Type
    <State id="temperature">
        <ValueType>Number</ValueType>
    <State id="heatSetPoint">
    <State id="coolSetPoint">
    <State id="mode">
Events.xml
<Events>
    <Event id="updateAvailable">
    </Event>
</Events>
<Event id="sep1"/>
Actions.xml
<Actions>
    <Action id="resetInterface">
        <Name>Reset Interface</Name>
    </Action>
</Actions>
<Action id="sep1"/>
uiPath Attribute No Added in API v1.4. You can specify where in the menu hierarchy your action will be placed. By default, Indigo will create a submenu at the bottom of the Actions list and put your actions there. If you specify "DeviceActions", Indigo will create a submenu on the Device Actions menu and put your actions there. If you specify "NotificationActions", Indigo will insert your action n the Notification Actions menu without a submenu (be sure to name your action appropriately so that it's clear what it does). Added in API v2.0: use "hidden" to hide the action in the UI. Useful for actions that are only intended to be used from scripts/plugins (an API of sorts).
def writeToLog(self, action):
    if theType:
        indigo.server.log(theMessage)
Notice the call to self.substitute() - this method is defined in the plugin base class. If your user inserts %%v:12345%% into their string where 12345 is the ID of a variable, the call will return a string with all variable occurrences substituted. If your user inserts %%d:12345:someStateId%% into their string where 12345 is the ID of a device and someStateId is a valid state identifier, the call will return a string with all device state occurrences substituted.
<MenuItems>
    <MenuItem id="menu1">
    </MenuItem>
    <MenuItem id="menu2">
    </MenuItem>
    <MenuItem id="menu3">
        <ConfigUI>
            <Label>Light:</Label>
        </Field>
        </ConfigUI>
    </MenuItem>
    <!-- Added in v1.2 -->
    <MenuItem id="menu4">
    </MenuItem>
</MenuItems>
CallbackMethod Element No 1.0 (1.1) This is the name of the method defined in your plugin that will be called when your user selects this menu item. \ \ API v1.1: If you specify a for the menu, then this property is optional. If it's present, then the the method will be called with arguments much like a validation (see example below). If it's not present (in which case a ConfigUI must be present), then the dialog will contain only a single "Close" button. In that case the functionality in the dialog will be completely left up to buttons contained within the dialog.
ConfigUI Element No 1.1 (1.2) If you want a menu to open an associated dialog, you can include a standard ConfigUI element (see Configuration Dialogs above for details). \ \ API v1.2: You may also specify an actionId attribute on this element with the id of one of your actions and that action UI will be executed rather than having to specify the UI itself. If it requires a device ID that will be added at the top of the dialog. Ex: <ConfigUI actionId="actionIdHere"/>
def checkForUpdates(self):
As of API v1.1 you can have your menu item open a dialog which will allow you to gather input from a user before executing the action. Just add a element to your MenuItem definition and define that dialog just like any other. There are a couple of differences between this dialog and other dialogs. First, the CallbackMethod for menu items will be used rather than a validation method. It will, however, operate in much the same way. If you specify a CallbackMethod then it will get called with the valuesDict and the menu item's ID. You can return True, which will cause the dialog to close, or return false with an error dictionary which will mark the invalid fields just like the validation method would.
You also have the option of adding a ButtonTitle element - which will allow you to change the name of the button (it defaults to "Execute").
If you don't specify a CallbackMethod then the dialog will not have Execute and Cancel buttons but rather will have just a single "Close" button. Why? We wanted to allow you the flexibility of making a dialog perform multiple actions if you like using button field types within the dialog itself. When doing that it would be awkward to have an "Execute" button that didn't really do anything.
In API v1.x
plugin.py
General Plugin Methods
```text
init(self,
pluginId,
pluginDisplayName,
pluginVersion,
pluginPrefs)
def init(self, pluginPrefs):
def del(self):
indigo.PluginBase.del(self)
def startup(self):
shutdown(self) No This method will get called when the IndigoServer wants your plugin to exit. If you define a global shutdown variable, this is the place to set it. Other things you might do in this method: if your plugin uses a single interface to talk to multiple devices, this is the place where you would want to shut down that interface (close the serial port or network connection, etc). Each device and trigger will already have had a chance to shutdown by the time this method is called (see the methods below). \ \ ```python
def shutdown(self):
runConcurrentThread(self) No This method is called in a newly created thread after the startup() method finishes executing. It’s expected that it should run a loop continuously until asked to shutdown. \ \ ```python
while True:
# Do your stuff here
self.sleep(60) # in seconds
except self.StopThread:
# do any cleanup here
pass
self.stopThread = True
Device Specific Methods
```text
getDeviceStateList(self,
dev)
```text
getDeviceDisplayStateId(self,
dev)
```text
deviceStartComm(self,
dev)
```text
deviceStopComm(self,
dev)
```text
origDev,
newDev)
```text
deviceCreated(self,
dev)
``` Deprecated in 1.4 This method was deprecated in v1.4 of the API. It will continue to be called internally, but you'll find the device passed to it not fully created in most circumstances. Use *deviceStartComm()* instead.
```text
deviceUpdated(self,
origDev,
newDev)
```text
deviceDeleted(self,
dev)
Trigger Specific Methods
```text
triggerStartProcessing(self,
trigger)
```text
triggerStopProcessing(self,
trigger)
```text
origTrigger,
newTrigger)
```text
triggerCreated(self,
trigger)
```text
triggerUpdated(self,
origTrigger,
newTrigger)
```text
triggerDeleted(self,
trigger)
Schedule Specific Methods
Action Group Specific Methods
Name Required Notes
Variable Specific Methods
Name Required Notes
```text
bundleID)
```text
browserOpen(self,
url)
```text
debugLog(self,
msg)
``` *msg* - the string to insert into the event log None (DEPRECATED - see Logging below) If, at any point in your plugin, you set *self.debug = True*, then any time debugLog is called the string will get inserted into Indigo's event log. If *self.debug = False* (the default) any call to debugLog does nothing.
```text
errorLog(self,
msg)
``` *msg* - the string to insert into the event log None (DEPRECATED - see Logging below) If you want an error to show up in the event log (in red text), use this log method rather than indigo.server.log().
```text
openSerial(self,
ownerName,
portUrl, baudrate, bytesize,
parity, stopbits, timeout,
dsrdtr, interCharTimeout)
``` *ownerName* - the name of the device or plugin that owns this serial port (used for error logging) - make sure that it's ASCII text with no unicode characters \ *other args* - all other arguments are passed directly to the pySerial's Serial contructor serial.Serial instance This method is identical to creating a new pySerial Serial object except that it never throws an exception. If the serial connection cannot be opened then None is returned and an error will be automatically logged to the Indigo Server event log.
```text
sleep(self,
seconds)
``` *seconds* - the sleep duration as a real number None This method should be called from within your plugin's runConcurrentThread() defined method, if it is defined. It will automatically raise the StopThread exception when the Indigo Server is trying to shutdown or restart the plugin. See runConcurrentThread documentation above for more details.
```text
substituteVariable(self,
inString,
validateOnly=False)
``` *inString* - the string which contains valid variable ID \ validateOnly - whether to return the actual string or a validation tuple where the first item is a boolean whether the formatting is valid and the variable ID exists and the second item is the error string to show (defaults to False) String \ if *validateOnly* is False \ \ (BOOL, errStr) \ if *validateOnly* is True This method will allow any string with the following markup to have a variable value substituted: %%v:VARID%%VARID is the unique variable ID as found in the UI in various places. It's recommended that you call this method twice: first, when the validation method for your action is called so that you can validate at that point if the syntax is correct and make sure the variable exists. The second time you call this method would be when you execute the action - call it before you actually use the string so that the substitutions will be made. Errors will show up in the event log if the variable doesn't exist (or if there's a formatting problem) at action execution time.
```text
substituteDeviceState(self,
inString,
validateOnly=False)
``` *inString* - the string which contains valid device ID and state key \ validateOnly - whether to return the actual string or a validation tuple where the first item is a boolean whether the formatting is valid and the variable ID exists and the second item is the error string to show (defaults to False) String \ if *validateOnly* is False \ \ (BOOL, errStr) \ if *validateOnly* is True This method will allow any string with the following markup to have a variable value substituted: %%d:DEVICEID:STATEKEY%%DEVICEID is the unique device ID as found in the UI in various places and the STATEKEY is the identifier for the state. It's recommended that you call this method twice: first, when the validation method for your action is called so that you can validate at that point if the syntax is correct and make sure the device exists. The second time you call this method would be when you execute the action - call it before you actually use the string so that the substitutions will be made. Errors will show up in the event log if the device doesn't exist (or if there's a formatting problem) at action execution time.
```text
substitute(self,
inString,
validateOnly=False)
``` *inString* and validateOnly as described in the previous two methods \ substituteVariable(), substituteDeviceState() See above Validation works the same and should be called when your dialog validates user input. This method calls substituteVariable() first followed by substituteDeviceState(). The ordering was carefully chosen such that the variable substitution could, in fact, add more device markup to the string before the device substitution happens. So the user can even more dynamically generate content by inserting device markup into a variable value. However, only device markup will be honored in variable values - we don't recursively call variable markup on variable values.
Logging
Attribute Description
The logger module defines 5 levels of logging: logging.DEBUG, logging.INFO, logging.WARNING, logging.ERROR, logging.CRITICAL. Instances of the Logger object can be set to log messages at any of those 5 levels, and the level logged can be changed at any time. By default, the self.logger instance is set to logging.DEBUG (we'll see why a bit further down). You can change this if you want using the setLevel() method. We've named the self.logger instance "Plugin", because it's the name of the class from which your plugin begins. We'll see why this is important later in the examples.
The debugLog(), errorLog(), and exceptionLog() methods are now just wrappers around the corresponding method above. There is another convenience method defined in the logging module: self.logger.exception("Error log message with exception appended"). If you call this method from within an except block in your plugin, it will automatically create a logging.ERROR level message and append the stack trace to whatever message you supply.
self.indigo_log_handler
self.plugin_file_handler
Log Levels
Logging from submodules
Event and Message Flow
Plugin Preferences File
Back to Top
3rd Party Python Libraries
