Indigo Mac Client
Home Window
The Home Window has 4 areas:
- Outline View
- Item List
- Item Detail
- Status Bar
Outline View
Rename Folder...allows you to rename the folder.Delete Folderwill do just that. If the folder isn't empty, it will show you a sheet with 3 options:Cancel(do nothing),Delete Items(delete the items in the folder along with the folder), orMove Items(move the items to the parent first then delete the folder).Disable/Enable Remote Display(for devices, action groups, and control pages) will show/hide it in remote clients (like Indigo Touch for iOS and Web, the DomoPad 3rd party client for Android, etc).Copy ID (123456789)will copy the unique folder ID for use in Python scripts.
Item List
This menu will:
indigo.devices[91776575] # "Living Room Switch" - Copy an AppleScript string that you can use to reference the object. It will look like this:
device named "Living Room Switch"(AppleScript will be deprecated in Indigo 7.4+)
- Enable/disable the event.
indigo.triggers[565290390] # "Motion Sensor Dawn Triggered" - Copy an AppleScript string that you can use to reference the object. It will look like this:
trigger action named "Motion Sensor Dawn Triggered"
indigo.actionGroups[1703232002] # "Toggle Variable" - Copy an AppleScript string that you can use to reference the object. It will look like this:
action group named "Toggle Variable"
indigo.controlPages[249813574] # "iPad Landscape"
Item Detail
Lights/Appliances
Speed Controls
Sprinklers
Thermostats
Generic Output Devices
Triggers and Schedules
Control Pages
Status Bar
Event Log Window
Click the Clear Window button to clear the log entries. Click on Show Event Logs Folder to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 7->Preferences... and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside that period of time.
Variable Window
Menus
Indigo 7.3 Menu
About Indigo 7- this will show the About window which will show what client and server versions you're running and will show your registration codeStart Local Server...- this will open the Start Server dialogStop Server- this will stop the Indigo ServerConnect to Remote Server...- this option will allow you to connect to a different Indigo server or a server running on another MacClose Connection- this will close the connection to the serverPreferences...- this opens the preferences dialogLicense Details...- this opens the Subscription Status window that will show you the status of your License and it's associated Up-to-Date Subscription:
Check for Updates...- this will have the server your connected to contact us to see if there is an update available
File Menu
New Database...- this will close the current database and create a new one - you'll be prompted for a name and save locationSelect Database...- this will allow you to switch to a different databaseClose Window- this will close the frontmost windowNew Device...- this will switch the Home Window to the devices view and open the new device dialogNew Trigger...- this will switch the Home Window to the triggers view and open the new trigger dialogNew Schedule...- this will switch the Home Window to the schedules view and open the new schedule dialogNew Action Group...- this will switch the Home Window to the action groups view and open the new action group dialog
Edit Menu
View Menu
Interfaces Menu
Plugins Menu
Window Menu
Help Menu
Help for XXXX- this will change slightly based on what window is selected and what's selected in that window - but it will open the default browser to the page in the help documentation for that particular itemHow-To Wiki- this will also change slightly based on what's selected - it will open to the How-To wiki for the selected item (if a device is selected it will go to the wiki for that device, otherwise it will just go to the landing page)Email Log...- this option will email some of your event log data to the specified email address. Particularly useful for technical supportIndigo 7 Documentation- this will open your browser to the landing page for all Indigo 7 documentationGetting Started Guide- this will open your browser to the Getting Started Guide, the place where everyone new to Indigo should startManaging a Z-Wave Network- opens a browser window to the Managing Your Z-Wave Network document in our Documentation wikiManaging an INSTEON Network- opens a browser window to the Managing Your INSTEON Network document in our Documentation wikiOnline Support Forum- this will open your browser to our support forum - it's very active and is the primary place where you should seek help - we answer questions there very quickly and in fact we have many helpful users that can help as wellCompatible Devices- opens a browser window on our new Compatible Devices list that shows which devices and interfaces have been tested with Indigo and includes devices supported by 3rd party pluginsPlugin Store- this will open your browser to our Plugin Store where you can browse and download hundreds of 3rd party plugins that add functionality to Indigo
