Connecting an Insteon (or X10 power line) interface to Indigo requires a couple of steps, described below.
Install the FTDI VCP Drivers
For earlier versions of the OS, you can get the driver installer at FTDI's web site - be sure to get the installer that's appropriate for the architecture of your machine (Intel or PowerPC). If you select PowerLinc 2412U/2412S/2413U/2413S/2448 from the Interface type popup menu in the Preferences dialog (see below), then Indigo will alert you if the driver is not installed on your Mac. If you're using a PowerLinc 2412S/2413S with a separate USB to serial adapter, you can ignore that warning alert. Note: there are known issues with the FTDI driver and macOS High Sierra and Mojave on some Macs - check out our blog post for details.
Connecting the Interface
  1. Choose Indigo 7->Preferences... menu, then make sure the Interfaces tab is selected.
First, make sure that Indigo has enabled communication with the interface. If Indigo is not online with the interface, then choose the Interfaces->INSTEON/X10 Power Line->Enable menu item. See connecting the Interface above for more details.
To add a new Insteon device:
  2. Press the New... button at the top of the Home window.
Insteon Device Detail Image
Define Insteon Dialog Image
Start Sync Dialog Image
Device Links Dialog Image
Device Lnks Example Image
Manage Powerlinc Scenes Image
Defining the Scene
Executing the Scene
Resetting your PowerLinc
  5. Release the button
Replacing Your PowerLinc
The Interfaces->INSTEON/X10 Power Line submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI:
Insteon Menu Image
Execute Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
if insteonPlugin.isEnabled():
    actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
Set Siren Alarm Sound
Set Siren LED Mode
Set OutletLinc Load Sense
