The Indigo Reflector Service
About Reflectors
Reflectors provide:
- Hassle free setup:
Activating your Reflector
- Choose the
Indigo->Start Local Server...menu item. - Turn on the
Require authenticationcheckbox and enter a User name and good Password. You will definitely want password authentication on since you are about to enable access to the Indigo web server from the Internet. - Turn on the
Enable anywhere secure accesscheckbox. - Press the
Activate Reflectorbutton.
Lastly, switch back to the Indigo Start Local Server... dialog. It should now show that the reflector status is activated and will show a link to your new reflector URL. Press the Start Server button and that is it – Indigo will restart and automatically connect to your reflector!
Resetting Your Reflector's Activation
Indigo 7.3->Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset
Go->Go to Folder… - In the resulting dialog, copy and paste the following:
/Library/Application Support/Perceptive Automation/Indigo 7.3/Preferences/ - In the resulting Finder window, delete the folder named
Bandwidth Limits
If you have a graphical Control Page in Indigo that uses the
Refreshing Imagecontrol type then use a longer refresh duration (30 minutes or longer) for the image, especially if you plan to frequently access the page remotely. -
Not leaving Indigo Touch or an Indigo web browser page running continuously while not viewing it. By closing the browser window or leaving Indigo Touch (home button), the requests through the reflector will stop which significantly reduces daily bandwidth usage.
