Managing Your Z-Wave® Network
Adding a Z-Wave Device
Using Encryption
If you added a device to the network (Z-Wave Controller) without encryption enabled and then wish to enable encryption you must first remove it from the network. This is because the encryption key exchange can only occur with Indigo if the device has just been added to the network (within a few seconds), and before a device can be added to the network it must not be included in any networks. To do this you can use the [Interfaces->Z-Wave->Start Controller Exclusion Mode](#start-controller-exclusion-mode) menu item to put the Z-Wave Controller into exclusion mode, then follow the steps from the device's manual to have it exclude itself from the network. Once excluded (you can see the progress in the [Event Log window](ui_tour.md#event-log-window)), you can then use the New with Encryption Enabled button inside the Syncrhonize Z-Wave Device dialog to re-add it to the network with encryption.
Z-Wave Dialog Settings Image
  4. Click on the Sync button.
Deleting a Z-Wave Device
Replacing a Z-Wave Controller
Z-Wave Menu Options
Z-Wave Menu Image
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
Optimize Z-Wave Network
Reset Z-Wave Interface
