Triggers
Trigger Base Class
| Property | Type | Writable | Description | |
actions |
list of Action | Yes | a list of Action objects (action steps in AS) that are executed for this trigger Not yet implemented | |
description |
string | Yes | description of the trigger | |
enabled |
boolean | Yes | true if this trigger is enabled | |
folderId |
integer | No | unique ID of the folder this trigger is in | |
globalProps |
dictionary | No | an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
id |
integer | No | a unique id of the trigger, assigned on creation by IndigoServer - not available in AppleScript | |
name |
string | Yes | the unique name of the trigger - no two triggers can have the same name | |
pluginProps |
dictionary | No | an indigo.Dict() representing the name/value pairs defined by your plugin for the trigger - plugin developers should publish this information if you want other plugins/scripts to create triggers of this type - see About Plugin Properties below for details |
suppressLogging |
boolean | Yes | true if execution of this trigger will not be logged into the event log | |
upload |
boolean | Yes | true if IndigoServer should attempt to upload this trigger to the interface - will always be false for plugin triggers |
trigger=indigo.triggers[123]
Commands (indigo.trigger.*)
indigo.trigger.delete(123) |
| Parameters | |||
| Parameters | |||
*duplicateName* |
No | string | name for the newly duplicated trigger |
Enable/Disable Trigger
| Parameters | |||
*value* |
Yes | boolean | True to enable, False to disable |
*delay* |
No | integer | number of seconds to delay before disabling or enabling the trigger |
*duration* |
No | integer | number of seconds before the trigger is switched back to its original state |
Execute Trigger
| Parameters | |||
*ignoreConditions* |
No | boolean | will ignore any conditions associated with the trigger if True (default) and will evaluate conditions if False |
| Parameters | |||
*value* |
Yes | integer | id or instance of the folder to move the trigger to |
| Parameters | |||
DeviceStateChangeTrigger
deviceId |
integer | Yes | the unique device id | |
stateChangeType |
kStateChange | Yes | the type of state change | |
stateSelector |
kStateSelector | Yes | can use either a string or one of the enumerations listed in the state selector enumeration | |
stateSelectorIndex |
integer | Yes | a 0-based integer value to specify which of multiple options to monitor - see the About State Selector section below for more information | |
stateValue |
string | Yes | the value the current state should be compared against - will be converted to the right type by the server |
In AppleScript (which will be deprecated in a future version of Indigo 7), we didn’t describe them particularly well, but basically we use a 1-based index into an array of possible values. So, for an I/O device, for instance, you’d refer to "binaryInput1", "binaryInput2", etc. Or for a sprinkler with multiple zones, it would be "zone1", "zone2", etc. In the Python API, we’ve made it easier when referencing these events with the introduction of the stateSelectorIndex. It’s the index into list of available "things" represented by the device’s state.
State Change Type Enumeration
| indigo.kStateChange | ||
BecomesEqual |
*stateSelector* becomes equal to *stateValue* |
*ActiveZone* \ AnalogInput \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput |
BecomesFalse |
*stateSelector* becomes *False* |
*BinaryInput* \ BinaryOutput \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ Zone |
BecomesGreaterThan |
*stateSelector* becomes greater than *stateValue* |
*AnalogInput* \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput |
BecomesLessThan |
*stateSelector* becomes less than *stateValue* |
BecomesNotEqual |
*stateSelector* becomes not equal to *stateValue* |
BecomesTrue |
*stateSelector* becomes True |
Changes |
*stateSelector* has any change |
*ActiveZone* \ AnalogInput \ AnalogInputsAll \ BinaryInput \ BinaryInputsAll \ BinaryOutput \ BinaryOutputsAll \ BrightnessLevel \ HumidityInput \ HumidityInputsAll \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanMode \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ SensorInput \ SensorInputsAll \ SetpointCool \ SetpointHeat \ TemperatureInput \ TemperatureInputsAll \ Zone |
State Selector Enumeration
| indigo.kStateSelector | |
ActiveZone |
monitor the sprinkler’s activeZone to become =, !=, or any change |
AnalogInput |
monitor (one of) the analog input(s) available on the device for =, !=, <, >, or any change - stateSelectorIndex is required to be in the range of available inputs |
AnalogInputsAll |
monitors all of the analog inputs available on the device for any change |
BinaryInput |
monitor (one of) the binary input(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available inputs |
BinaryInputsAll |
monitors all of the binary inputs available on the device for any change |
BinaryOutput |
monitor (one of) the binary output(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available outputs |
BinaryOutputsAll |
*BrightnessLevel* |
monitor the brightness level of a device for =, !=, <, >, and any change |
HumidityInput |
monitor (one of) the humidity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
HumidityInputsAll |
monitors all of the humidity sensors available on the device for any change |
HvacCoolerIsOn |
monitor the thermostat for any time the air conditioning turns on, off, or has any change (coolIsOn is the current compressor state) |
HvacFanIsOn |
monitor the thermostat for any time the fan turns on, off, or has any change (fanIsOn is the current fan state) |
HvacFanMode |
monitor the fanMode of the thermostat for any change |
HvacFanModeIsAlwaysOn |
monitor the fanMode of the thermostat for a change to/from kFanMode.AlwaysOn |
HvacFanModeIsAuto |
monitor the fanMode of the thermostat for a change to/from kFanMode.AutoOn |
HvacHeaterIsOn |
monitor the thermostat for any time the heater turns on, off, or has any change (heatIsOn is the current heater state) |
HvacOperationMode |
monitor the hvacMode of the thermostat for any change |
HvacOperationModeIsAuto |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.HeatCoolOn |
HvacOperationModeIsCool |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.CoolOn |
HvacOperationModeIsHeat |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.HeatOn |
HvacOperationModeIsOff |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.Off |
HvacOperationModeIsProgramAuto |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramAuto |
HvacOperationModeIsProgramCool |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramCool |
HvacOperationModeIsProgramHeat |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramHeat |
KeypadButtonLed |
FIXME |
OnOffState |
monitor the device for a change to/from on/off |
SensorInput |
monitor (one of) the sensor input(s) available on the device for =, !=, <, >, or any change - stateSelectorIndex is required to be in the range of available inputs |
SensorInputsAll |
monitors all of the sensor inputs available on the device for any change |
SetpointCool |
monitor the cool setpoint of the thermostat for =, !=, <, >, or any change |
SetpointHeat |
monitor the heat setpoint of the thermostat for =, !=, <, >, or any change |
TemperatureInput |
monitor (one of) the temperature sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
TemperatureInputsAll |
monitors all of the temperature sensors available on the device for any change |
Zone |
| python
folder=1234) |
| Parameters | |||
*description* |
No | string | the description of the trigger |
name |
Yes | string | the name of the trigger |
*folder* |
No | integer | id or instance of the folder in which to put the newly created trigger |
| Python | AppleScript (which will be deprecated in a future version of Indigo 7) |
| ```python | |
| theTrigger=indigo.devStateChange.create(name="Temp exceeds 80 degrees") |
theTrigger.deviceId = 738
theTrigger.stateValue = 80
theTrigger.replaceOnServer()
|text
set theTrigger to make new trigger action with properties {name:"Temp exceeds 80 degrees"}
set theTrigger's trigger type to deviceChanged
set theTrigger's device name to "Main Thermostat"
set theTrigger's state change type to becomesGreaterThan
set theTrigger's state selector to "TemperatureInput1"
set theTrigger's state value to 80 ``` |
EmailReceivedTrigger
Property |
Writable | Type | Description | |
emailFilter |
kEmailFilter | Yes | the type of email filter based on the *kEmailFilter* enumeration below |
emailFrom |
string | Yes | if *emailFilter* is *MatchEmailFields*, the value to match against the sender’s address |
emailSubject |
string | Yes | if *emailFilter* is *MatchEmailFields*, the value to match against the subject line |
Email Filter Enumeration
| indigo.kEmailFilter | |
AnyEmail |
when any email is received |
MatchEmailFields |
when email subject/from fields match |
Commands (indigo.emailRcvd.*)
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
| ```python | |
| theTrigger=indigo.emailRcvd.create(name="Emails from some@body.com") |
|text
set theTrigger to make new trigger action with properties {name:"Emails from some@body.com"}
set theTrigger's trigger type to emailReceived
set theTrigger's email filter to matchEmailFields
set theTrigger's email from to "some@body.com"
InsteonCommandReceivedTrigger
deviceId |
integer | Yes | the unique device id - only used if commandSourceType is DeviceId |
command |
kInsteonCmd | Yes | the command to watch for | |
commandSourceType |
kDeviceSourceType | Yes | the source type - for INSTEON only DeviceId and AnyDevice apply - and deviceId above will only be used if set to DeviceId |
buttonOrGroup |
integer | Yes | the button or group number from which the command is received - see About Button or Group Numbers below for details |
INSTEON Command Enumeration
| indigo.kInsteonCmd | |
AllBrighten |
when an all brighten command begins |
AllDim |
when an all dim command begins |
AllInstantOff |
when an all instant (fast) off is received |
AllInstantOn |
when an all instant (fast) on is received |
AllOff |
when an all off is received |
AllOn |
when an all on is received |
AnyCommand |
when any command is received |
Brighten |
when a brighten command begins |
Dim |
when a dim command begins |
InstantOff |
when an Instant (Fast) off is received in response to a double-tap |
InstantOn |
when an Instant (Fast) on is received in response to a double-tap |
Off |
when an off command is received |
On |
when an on command is received |
StatusChanged |
when a status change broadcast is received |
*NoDevice* |
when the source uses no device or address (only used for X10 RF A/V remotes) |
Device |
when the source is an existing device, the ID is specified |
Address |
when the source is a raw X10 address |
AnyAddress |
when the source is any X10 address or INSTEON device |
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
| Python | AppleScript |
| ```python | |
| theTrigger= indigo.insteonCmdRcvd.create(name="KeypadLinc button 1 Any Change") | |
| theTrigger.command = indigo.kInsteonCmd.AnyCommand | |
| theTrigger.commandSourceType = indigo.kDeviceSourceType.Device | |
| theTrigger.deviceId = 43829874 | |
| theTrigger.buttonOrGroup = 1 | |
| theTrigger.replaceOnServer() | |
| ``` | (Can't be created in AppleScript) |
InterfaceFailureTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
| ```python | |
| theTrigger= indigo.interfaceFail.create(name="Any Interface Failed") | |
|text |
| set theTrigger to make new trigger action with properties ¬ | |
| {name:"Any Interface Failed", trigger type:interfaceFailure} | |
InterfaceInitializedTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
| ```python | |
| theTrigger= indigo.interfaceInit.create(name="Any Interface Initialized") | |
|text |
| {name:"Any Interface Initialized", trigger type:interfaceInitialized} | |
PluginEventTrigger
pluginId |
string | the unique ID of the plugin, specified in the Info.plist for the plugin (or it’s documentation) |
pluginTypeId |
string | the id specified in the Events.xml (or it’s documentation) |
| python
folder=1234),
pluginTypeId="myEvent",
props={"propA":"value","propB":"value"} |
| Parameters | |||
*description* |
name |
*folder* |
*pluginId* |
No | string | the plugin id of the plugin that owns the device you're creating - if it's not present it defaults to your plugin's id |
*pluginTypeId* |
Yes | string | this is the id of the |
*props* |
No | dictionary | this is the properties for the trigger - they will be inserted in to the pluginId's property space as supplied above. If you are creating a trigger of a type defined in a different plugin, it's that plugin's id and properties. |
PowerFailureTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
| ```python | |
| theTrigger= indigo.powerFailure.create(name="Any Interface Detected Power Failure") | |
|text |
| {name:"Any Interface Detected Power Failure", trigger type:powerFailure} | |
ServerStartupTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
| ```python | |
| theTrigger= indigo.serverStartup.create(name="Startup") | |
|text |
| {name:"Startup", trigger type:startup} | |
X10CommandReceivedTrigger
address |
string | if commandSourceType = Address, the full X10 address to listen for or just the house code if command is All* or AnyCommand | |
avButton |
kX10AvButton | if command = AvButtonPressed, the A/V button to monitor | |
deviceId |
integer | if commandSourceType = Device, the unique device id | |
command |
kX10Cmd | the X10 command to watch for | |
commandSourceType |
kDeviceSourceType | the type of source specified for this trigger |
X10 Command Enumeration
| indigo.kX10Cmd | |
AllOff |
AllLightsOff |
when an all lights off is received |
AllLightsOn |
when an all lights on is received |
AvButtonPressed |
when an A/V button press is received |
AnyCommand |
Brighten |
Dim |
ExtendedData |
when an extended data X10 command is received |
Off |
On |
PresetDim |
when a preset dim command is received |
StatusOffResponse |
when a status off response is received |
StatusOnResponse |
when a status on response is received |
X10 A/V Button Enumeration
| indigo.kX10AvButton | |
| Value | Value |
*0* |
*Left* |
*1* |
*Menu* |
*2* |
*Mute* |
*3* |
*Pause* |
*4* |
*PC* |
*5* |
*Play* |
*6* |
*Power* |
*7* |
*Recall* |
*8* |
*Record* |
*9* |
*Return* |
AB |
*Rewind* |
ChannelDown |
*Right* |
ChannelUp |
*Stop* |
Display |
*Title* |
Down |
*Up* |
Enter |
*VolumeDown* |
Exit |
*VolumeUp* |
Forward |
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
myTrigger.address = "F7"
myTrigger.replaceOnServer()
VariableValueChangeTrigger
variableChangeType |
kVarChange | the type of variable change to monitor | |
variableId |
integer | the unique variable id | |
variableValue |
string | the value to compare against the variable’s value if *variableChangeType* is =, !=, >, < |
| indigo.kVarChange | |
BecomesEqual |
variable value becomes equal to |
BecomesFalse |
variable value becomes false |
variable value becomes greater than |
BecomesLessThan |
variable value becomes less than |
BecomesNotEqual |
variable value becomes not equal to |
BecomesTrue |
variable value becomes true |
Changes |
variable value has any change |
Commands (indigo.varChange.*)
| python
indigo.varChange.create(name="Trigger Name Here",
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
| ```python | |
| theTrigger=indigo.emailRcvd.create(name="Var Changed to True") |
|text
set theTrigger to make new trigger action with properties {name:"Var Changed to True"}
set theTrigger's trigger type to variableChanged
set theTrigger's variable change type to varBecomesEqual
set theTrigger's variable name to "SomeVarWhoseIdIs9283749872"
set theTrigger's variable value to "True"
