Variables
Class Method
bool Boolean True will be returned if the value is one of these: "true", "on", "yes", and "1". False will be returned if the value is one of these: "false", "off", "no", and "0". If no default value is specified and the value can't be successfully converted, the method will return False.
Remember that accessing the value property of a variable object (*var.value*) will return a unicode string object so you don't need a conversion for that.
Class Method Examples
# Get a variable
unicodeValue = var.value
# Getting the boolean value
# Getting the integer value
# Getting the float value
Commands (indigo.variable.*)
Delete the specified folder.
indigo.variable.delete(123)
               ID : 552463741 (integer)
               ID : 296710860 (integer)
Update Value
Python AppleScript (which will be deprecated in a future version of Indigo 7)
```python
# Create a new variable
Updating value via command space function:
indigo.variable.updateValue(newVar, "asleep789") newVar.refreshFromServer() # refresh needed to update local's .value
changing name property
newVar.name = "goodName" newVar.replaceOnServer()
changing name and values properties:
newVar.name = "goodName2" newVar.value = "searchingForWaldo" newVar.replaceOnServer()
Getting a variable using it's ID
Getting a variable using it's name
someVar = indigo.variables["MyVarName"] |text -- Create a new variable set newVar to make new variable with properties {name:"fooName", value:"fooMonster"}
-- Update value set value of newVar to "asleep789"
-- Changing name property set name of newVar to "goodName" set newVar to variable "goodName" -- when the name changes, you have to get a fresh reference
-- Changing name and values properties set name of newVar to "goodName2" set newVar to variable "goodName2" -- when the name changes, you have to get a fresh reference set value of newVar to "searchingForWaldo"
delete variable "goodName2"
You can't get a variable using its ID in AppleScript
set someVar to variable named "MyVarName" ``` |
