Getting Started Guide
Welcome to Indigo 2024.1!
Z-Wave
- Thermostats, and
- Locks.
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
The Indigo 2024.1 application can be found here:
/Applications/Indigo 2024.1.app
/Library/Application Support/Perceptive Automation/Indigo 2024.1/
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2024.1 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
Indigo 202x.y->Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 202x.y->Quit Indigomenu item. - Open the
Indigo 2024.1->License Details...menu item and clicking theDeactivate Licensebutton. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first) - Copy this folder over to the new Mac:
/Library/Application Support/Perceptive Automation/Indigo 2024.1/(if restoring from a backup, you'll need to locate this folder in whatever backup system you use) - Install Indigo 2024.1 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
!!! warning "NOTE"
this is not the Library folder that's in your home directory - it's the one at the top level of your hard drive. The easiest way to get there is to select the Go->Go To Folder... menu item in the Finder and paste in this:
It'll open the correct folder and you'll see the "Perceptive Automation" folder - that's the one you want to copy over. That should get all of your customizations and allow the installer to update anything as necessary. You may also need to install the drivers for the technology you use - see the appropriate section below for details.
If you're moving Indigo to a Mac with a different architecture, read on...
When you move your Indigo installation from one macOS architecture to another (for example from an Intel-based Mac to an M-series Mac) -- especially if you use Migration Assistant or Time Machine -- you will likely need to take additional steps because many Python libraries are compiled to the specific hardware they're installed on. One signal that this has become an issue is an error message like:
- manually remove the
In some cases, you may wish to transfer your license to another user--for example, if you sell your home along with the Indigo system. We are happy to assist you in this process, and there are only a few steps you need to take. It is important that the steps be taken in this order:
- When we're done with that, the new owner will need to deactivate/reactivate the license by selecting the Indigo 20XX.Y -> License Details... menu item and first clicking on the Deactivate License button then--in the resulting dialog--log in using the username/password they created in the step 1 above.
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2024.1->License Details... menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2024.1 menu if the server is still running before you quit the Indigo Mac Client).
/Library/Application Support/Perceptive Automation/Indigo 2024.1/~(your user folder)/Library/LaunchAgents/com.perceptiveautomation.IndigoServer2.plist- Optional : If you don't use Python 3.11 for anything (other than Indigo 2024.1), you can delete this folder:
Uninstalling the Mac Client
/Applications/Indigo 2024.1.app~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-2024-1.plist~(your user folder)/Library/Preferences/Indigo 2024.1 Client Prefs.indiPref~(your user folder)/Library/Preferences/Indigo 2024.1 Client Settings.indiPref
To uninstall older versions but leave 2024.1 installed correctly, delete these:
Indigo 2023.2:
Indigo 2023.1:
Indigo 2022.2:
Indigo 2022.1:
Indigo 2021.2:
Indigo 2021.1:
Indigo 7.5:
Indigo 7.4:
Indigo 7.3:
Indigo 7.2:
Indigo 7.0 and 7.1:
Indigo 6 and prior (substitute the previous version # for 6):
Starting Indigo Server
- Double click the
Indigo 2024.1application (/Applications/Indigo 2024.1.app). - If this is the first time to run
Indigo 2024.1on this Mac, then press theStart Local Server...button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 2024.1->Start Local Server...menu item.
Standard startup mode
Custom single app startup
Starting the Server
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 2024.1application (inside/Applications/Indigo 2024.1.app) on the remote Mac. - If this is the first time to run
Indigoon this remote Mac, then press theConnect to Remote Server...button in the connection status window. - If you are wanting to connect to a different Indigo Server, then select the
Indigo 2024.1->Connect to Remote Server...menu item. - Enter the
Connectbutton.
http://192.168.1.23:8176/
- Configuring and Managing your Z-Wave Network
- Configuring and Managing your Insteon Network
- Configuring and Using X10 devices
- Using the Virtual Devices Interface
Managing Plugins
Installing/Updating Plugins
- Click the
. You will see a different dialog if the version number is lower than an already-installed version; for safety, Indigo will ask you to confirm that you want to downgrade the plugin. - NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the
Open Withmenu item, then select Indigo 2024.1.
- Click the
Plugin Menus in Indigo
Main Plugins Menu
Individual Plugin Submenu
The next section contains:
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2024.1->Preferences... menu item and clicking the Plugins tab or by selecting the Plugins->Manage Plugins... menu item discussed above.
- the
Uninstalling a Plugin
Help->Show Indigo Server Install Foldermenu item. This will switch you to the Finder and open a window to the Indigo install folder. - Switch back to Indigo and shut down the Indigo Server by selecting the
Indigo 2024.1->Stop Servermenu item in the Mac client (you can leave the client app running). - In the Finder window opened in step 1, you'll see two folders:
PluginsandPlugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. Check to make sure that somehow there aren't plugins in both locations. - Switch back to the Indigo 2024.1 Mac client and click on the
Start Local Server...button in theServer Connection Statusdialog.
- Choose
Date & Timeicon. - Select the
Closet Citylocation is not near your location, then follow the instructions on the panel to choose your location. If you would like to precisely specify your location, then you can override the system location from within Indigo.
- Choose the
Indigo 2024.1->Preferences...menu item, then make sure theSunset & Sunrisetab is selected. - Select the
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2024.1->Preferences... menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2024.1->Check for Updates... menu item.
- Choose
Energy Savericon. - Move the
Where to Go Next
