Indigo Object Model Reference
About this Reference
# some code here
# that does something
Term Meaning
Introduction
For Scripters and Developers:
For Developers:
  • To change a device's state on the server, use myDevice.updateStateOnServer(key="keyName", value="Value")
Class Command namespace Notes
Device (indigo.Device) indigo.device.* for commands and properties that apply to all device subclasses
DimmerDevice (indigo.DimmerDevice) indigo.dimmer.* manipulate a dimmer
InputOutputDevice (indigo.MultiIODevice) indigo.iodevice.* manipulate an I/O device
SensorDevice (indigo.SensorDevice) indigo.sensor.* manipulate a sensor (motion, etc)
RelayDevice (indigo.RelayDevice) indigo.relay.* manipulate a relay, lock, or other 2 state device
SpeedControlDevice (indigo.SpeedControlDevice) indigo.speedcontrol.* manipulate a speed control/motor device
SprinklerDevice (indigo.SprinklerDevice) indigo.sprinkler.* manipulate a sprinkler device
ThermostatDevice (indigo.ThermostatDevice) indigo.thermostat.* manipulate a thermostat
Schedule
Schedule (indigo.Schedule) indigo.schedule.* manipulate a scheduled event FIXME not yet implemented
Triggers
Trigger (indigo.Trigger) indigo.trigger.* commands and properties that apply to all trigger subclasses
DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger) indigo.devStateChange.* manipulate a device state change trigger
EmailReceivedTrigger (indigo.EmailReceivedTrigger) indigo.emailRcvd.* manipulate an email received trigger
Trigger Class (indigo.InsteonCommandReceivedTrigger) indigo.insteonCmdRcvd.* manipulate an INSTEON command received trigger
InterfaceFailureTrigger (indigo.InterfaceFailureTrigger) indigo.interfaceFail.* manipulate an interface failure trigger
InterfaceInitializedTrigger (indigo.InterfaceInitializedTrigger) indigo.interfaceInit.* manipulate an interface initialized trigger
PluginEventTrigger (indigo.PluginEventTrigger) indigo.pluginEvent.* manipulate an trigger defined by a plugin event
PowerFailureTrigger (indigo.PowerFailureTrigger) indigo.powerFail.* manipulate a power failure trigger
ServerStartupTrigger (indigo.ServerStartupTrigger) indigo.serverStartup.* manipulate a server startup trigger
X10CommandReceivedTrigger (indigo.X10CommandReceivedTrigger) indigo.x10CmdRcvd.* manipulate an X10 command received trigger
VariableValueChangeTrigger (indigo.VariableValueChangeTrigger) indigo.varValueChange.* manipulate a variable changed trigger
ActionGroup (indigo.ActionGroup) indigo.actionGroup.* commands for action groups
Variables
Variable (indigo.Variable) indigo.variable.* manipulate a variable
Protocol Specific Commands
Insteon Specific Commands indigo.insteon.* commands specific to the INSTEON protocol
X10 Specific Commands indigo.x10.* commands specific to the X10 protocol
General Commands
Commonly used commands and server properties indigo.server.* for commands and properties that are more general in nature
There are a few classes that are special. One is Action and it’s subclasses (collectively referred to as "actions"). Why are these classes different? Because outside of the trigger, schedule, action group, or control page that they’re associated with they aren’t individually addressable in the IndigoServer: for instance, there is no way to identify an action without first identifying the trigger that it’s associated with.
IOM Class Hierarchy
IOM Object Hierarchy Image
Indigo specific data types
  • always retrieve values (ex: myprops["key"] or mylist[2]) as a copy and not reference of the object.
  • keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
a['c'] = c          # a COPY of list C above is inserted (not a reference)
print(str(a))
c.append(6)
print(str(a))           # no change from previous output!
a['c'].append(6)
a['c'] = c
print(str(a))           # now has a COPY of the updated object, c
print(str(a))
Built-in objects
Object Description
indigo.devices All devices in the database
indigo.triggers A ll triggers in the database
indigo.schedules All schedules in the database
indigo.actionGroups All action groups in the database
indigo.variables All variables in the database
  2. They contain a "folders" attribute that has all the folders defined for that object type
The other additional method is subscribeToChanges(). This method doesn't return anything - rather, it tells the IndigoServer that your plugin wants notification of all changes to the specific object type. Use this method sparingly as it causes a significant amount of traffic between IndigoServer and your plugin. What kind of plugins would use this? One good example is a logging plugin - one that's logging activity within Indigo (like our SQL Logger). Another example is a plugin that's doing some kind of scene management - you would probably want to issue a indigo.devices.subscribeToChanges() at plugin start so that you'll always be notified when any device changes - you can then determine if your scene "state" has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change.
Object Events
Objects that support subscribeTochanges()
Lower-level Events
Low Level Commands (Insteon and x10 Only)
indigo.x10.subscribeToIncoming()
indigo.x10.subscribeToOutgoing()
        if cmd.cmdType == "sec":    # or "x10" for power line commands
            if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
    # do stuff with dev here
Triggers also have filters:
Filter Description
indigo.insteonCmdRcvd insteon command received triggers
indigo.powerFail power failure triggers
indigo.pluginEvent plugin defined triggers
self include triggers defined by the calling plugin
self.myTriggerType include myTriggerType's triggers defined by the calling plugin
com.company.plugin.xyzTriggerType include all xyzTriggerType's defined by another plugin
for var in indigo.variables:
    # all variables
Common Python Exceptions
Possible Exceptions
Classes and Commands
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
Object Dictionaries
>>> dev = indigo.devices[123]
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
<'indigo.Device'>
>>> dev_dict = dict(dev)
<class 'dict'>
Utility Classes and Functions
Classes
Name Base Description
FileNotFoundError Exception This is a useful exception if you handle files in any way. There is no built-in processing to catch such exceptions, it's just a useful exception to use.
IndigoJSONEncoder JSONEncoder Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder))
Functions
Return Static File
*status* No int the HTTP status code to return, defaults to 200
*path_is_relative* No boolean is the path a full path or relative to the plugin, defaults to True
*content_type* No string a string to return as the mime type of the content, returns the appropriate type based on the file extension if none is specified
    "status": 404,
    "headers": {
        "Content-Type": "text/html"
    "file_path": "/Library/Application Support/Perceptive Automation/Indigo 2024.1/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
indigo.utils.validate_email_address("valid_email@someserver.com")
