Indigo Mac Client
When you double click on the Indigo 2024.1 icon in the Applications folder, you're actually starting the Indigo Mac Client, which will start up the Indigo Server process according to the options selected in the Start Server dialog.
Home Window
Main Window Image
The Home Window has 4 areas:
  1. Outline View
  2. Item List
  3. Item Detail
  4. Status Bar
Outline View
Outline View Controls Image
  • Rename Folder... allows you to rename the folder.
Item List
Device Contextual Menu Image
This menu will:
  6. Copy a Python script string that will return an instance of the selected device. It will look like this: indigo.devices[91776575] # "Living Room Switch"
address : 3B.04.7A
batteryLevel : None
blueLevel : None
brightness : 0
buttonConfiguredCount : 0
buttonGroupCount : 1
configured : True
defaultBrightness : 100
description : valve
deviceTypeId :
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 810233868
          publish-device : true (bool)
          sub-type : Valve (string)
          voice-name : valve (string)
greenLevel : None
ledStates : []
model : LampLinc (dual-band)
onBrightensToLast : False
onState : False
pluginId :
protocol : Insteon
redLevel : None
remoteDisplay : True
states : States : (dict)
     brightnessLevel : 0 (integer)
subModel : Plug-In
subType : Plug-In
supportsAllLightsOnOff : True
supportsAllOff : True
supportsColor : False
supportsRGB : False
supportsStatusRequest : True
supportsWhite : False
version : 67
whiteLevel : None
whiteLevel2 : None
whiteTemperature : None
  1. Enable/disable the event.
  5. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.triggers[565290390] # "Motion Sensor Dawn Triggered"
  4. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.actionGroups[1703232002] # "Toggle Variable"
  4. Copy a Python script string that will return an instance of the selected device. It will look something like this: indigo.controlPages[249813574] # "iPad Landscape"
Item Detail
Device Details Tile Image
Custom States Tile Image
Device State Context Menu Image
Lights/Appliances
On Off Dimmer Tile Image
Color Controls Tile Image
Sensor Controls Tile Image
Speed Controls
Speed Controls Image
Sprinklers
Sprinkler Controls Image
Thermostats
Thermostat Controls Image
Generic Output Devices
I/O Controls Image
Triggers and Schedules
Action Group Controls Image
Control Pages
Status Bar
Event Log Window
Event Log Window Image
  • Show Event Logs Folder - this option opens the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 2024.1->General Settings... and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside of that period of time.
  • Clear Window - this option clears the log entries from the Event Log window.
Variable Window
Indigo 2024.1 Menu
Indigo Menu Image
  • About Indigo 2024.1 - this will show the About window which will show what client and server versions you're running and will show your registration code
  • General Settings... - this opens the preferences dialog
  • Advanced Web Server Settings... - this opens the Indigo Web Server Settings dialog
  • License Details... - this opens the Subscription Status window that will show you the status of your License and it's associated Up-to-Date Subscription:
Subscription Status Image
File Menu
File Menu Image
Edit Menu
View Menu
Interfaces Menu
Plugins Menu
Window Menu
Window Menu Image
The bottom of the menu will display the list of open windows, where the name of the active database will replace "Home Window".
Help Menu
Help Menu Image
  • How-To Wiki - this will change slightly based on what's selected - it will open to the How-To wiki for the selected item (if a device is selected it will go to the wiki for that device, otherwise it will just go to the landing page)
  • Email Log... - this option emails some of your event log data to the specified email address. Particularly useful for technical support
  • Show AppleScript Usage in Event Log - this option prints a list of AppleScripts that are embedded in actions that you have specified. This will help to identify and replace those scripts.
  • Show Web Assets Folder - this option switches to the Finder and open the folder that contains custom images, text files, etc., that you might want to give Indigo (and others) access to through the Indigo Web Server.
  • Show Indigo Server Install Folder - this option opens a Finder window that displays the folder of the currently running Indigo installation. This will only run from the server machine (you'll receive a warning otherwise).
  • Indigo Documentation - this option will open your browser to the landing page for all Indigo 2024.1 documentation
  • Getting Started Guide - this option opens your browser to the Getting Started Guide, the place where everyone new to Indigo should start
  • Managing a Z-Wave Network - this option opens a browser window to the Managing Your Z-Wave Network document in our Documentation wiki
  • Managing an INSTEON Network - this option opens a browser window to the Managing Your INSTEON Network document in our Documentation wiki
  • Online Support Forum - this option opens your browser to our support forum - it's very active and is the primary place where you should seek help - we answer questions there very quickly and in fact we have many helpful users that can help as well
  • Compatible Devices - this option opens a browser window on our new Compatible Devices list that shows which devices and interfaces have been tested with Indigo and includes devices supported by 3rd party plugins
  • Plugin Store - this option opens your browser to our Plugin Store where you can browse and download hundreds of 3rd party plugins that add functionality to Indigo
