Plugin Testing Guide
Once you've developed a functioning plugin, it's a good idea to add automated methods to test your code before publishing plugins and plugin updates. "Unit testing" is considered a best practice, and Python provides built-in tools to help facilitate it. There are many ways to formulate unit tests, and this guide demonstrates one way to do it. The approach described below has advantages within the Indigo plugin framework because it allows direct access to the IOM (Indigo Object Model). It is extremely important to become familiar with the IOM and Indigo plugin development before attempting to tackle this guide.
Python Unit Testing
The main Python library for code testing is called *unittest*. There are lots of examples of unit testing online and it's probably a good idea to familiarize yourself with the *unittest* library before going any further with this guide. The main documentation for the *unittest* library is available at https://docs.python.org/3/library/unittest.html and is a great place to start learning about unit tests. Those who are familiar with unit testing in Python can skip ahead.
Unit Testing Indigo Plugins
Because Indigo runs plugins in a separate thread (to avoid having a misbehaving plugin bring down the whole system), plugin unit tests that need access to the IOM have to be constructed a little bit differently. For example, while some tests can be run in the "traditional" way, tests that need access to the IOM can't be run from within an IDE or from the command line without using the Indigo Integration API (which doesn't expose the full suite of IOM commands). However, it is possible to construct tests that do allow for full IOM access through the plugin itself.
Testing Elements
  1. The *unittest* library - this is a standard Python library and should be already available.
  2. The *python-dotenv* library - used for creating and managing Python environment variables.
  3. An IDE that supports unit testing - while not required, having an IDE that supports unit testing can be very helpful.
Testing Structure
Environment Variables
While optional, it is a good idea to create an environment variable framework that allows you to create and make references to elements of your development environment. Once you have installed *python-dotenv*, create a *.ENV* file at the *Server Plugin* level of your plugin (or another location that Indigo's environment path will search). It is a plain text file. The advantage of using an environment file is that it is a great place to store references that are unique to your system and -- for shared development -- each developer can have their own individual environment. IMPORTANT! Remember to add the *.ENV* file to your *.gitignore* list.
.ENV file
SECRET_CODE=zm76%g215^8sdhe
ACTION_GROUP_ID=12345678
Folder Structure
While optional, it's probably best to organize your test files and keep them separate from your main plugin files. For the purposes of this guide, we will store them in a *Tests* subfolder of the *Server Plugin* folder. For example,
../Server Plugin
  |_ Tests
     |_ __init__.py
     |_ test_my_plugin.py
     |_ ...
Of course, you can put them anywhere your plugin can see them. Depending on your development environment, you may also want to add the *Tests* folder to your *.gitignore* file to reduce the footprint of your published plugin.
Main Plugin
You'll need to add a few things to your plugin to support this testing approach.
  • A Plugin Action Item - add a plugin action to your Actions.xml file that will be used to run the tests. It is recommended that you hide the action so it's not visible to users.
<Action id="my_tests" uiPath="hidden">
  <Name>Run All Tests</Name>
  <CallbackMethod>my_tests</CallbackMethod>
</Action>
  • A Callback Method - create a callback method in your plugin (for example, *my_tests*) that will be used to run your tests.
    from Tests import test_my_plugin  # your unit test file(s)
        if result[0] is True:
Test File Structure
This is where the bulk of your testing code will reside. You could add your tests directly to your plugin but, as mentioned above, it offers a way to segregate your testing code from your published plugin to reduce its footprint by adding them to your *.gitignore* file. There is, of course, wide latitude (and debate) on how to structure tests and this guide tries to evade all that and provide a simple example just to get you started.
  • an init() file - to make your Tests available for module level imports.
  • one or more test files - that will contain your testing code.
Test File Structure
The *test_my_plugin.py* file contains your testing code. If you're familiar with unit testing (which you should be if you're this deep in the guide), the structure of these tests can be as complex as you like. A simple example:
import dotenv
import indigo  # noqa
import logging
import os
from unittest import TestCase
dotenv.load_dotenv()
test_case = TestCase()
class TestPlugin(TestCase):
    def __init__(self):
        super().__init__()
    @staticmethod
            return True, None
            return False, error
Once you have your core testing framework established and functional, it's a good idea to get in the habit of adding new tests over time as plugin errors are identified. For example, if a user encounters a traceback error--in addition to fixing the source of the problem--add a new unit test that will help you catch future errors before any other users encounter them.
Running Your Tests
except Exception as error:
    indigo.server.log(f"{error}")
Action Group                    Unit Test - Run My Tests
   My Indigo Plugin                Execute Action tests passed.
   My Indigo Plugin                Device creation tests passed.
   My Indigo Plugin                JSON parse tests passed.
Even More Tests
  • testing the structure of supporting files (like a constants file), or
  • using Indigo's integrations API for remote plugin testing.
These approaches are a bit more "traditional", can often be run directly inside an IDE, and are beyond the scope of this guide.
