Indigo Scripting Tutorial
Talking to the Indigo Server
Example Code Snippets
Note: For simplicity, some of the samples below specify objects based on name ("office desk lamp"). However, the preferred lookup mechanism is to use the object's ID which can be retrieved by control-clicking on the object's name in Indigo's Main Window. By using the ID, you ensure the object will be found even if its name is changed.
Device Examples
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
if hasattr(lamp, 'onState'):
    isOn = lamp.onState
Get the class of a device (uses Python's class property):
from datetime import datetime
Access a custom device state
# get the device
# show all the device states:
print(dev.states)
Variable Examples
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import requests
my_unicode_string = "éçø"
my_integer = 1
my_float = 1.0
import json
my_new_dictionary["my_list"]
class myCustomClass:
    def __init__(self):
        self.a=1
        self.b=2
    def __str__(self):
        return outputString
cl = myCustomClass()
Date and Time Examples
Get the current server time:
indigo.server.getTime()
import datetime
Action Group Examples
Log Examples
=Log to the Indigo Event Log window using different levels of logging
import logging
print(logList)
Folder Examples
except ValueError as e:
        myFolder = None
if lamp.folderId != 0:
    lampsFolder = None
Miscellaneous Examples
Sending emails
# Simple Example
/usr/local/indigo/indigo-host
Plugin Host Prompt Image
Connecting Remotely over SSH
What Else Can it Do?
indigo-host -e '
Executing Indigo Python Files
Executing AppleScript
indigo_attachments.py
    import indigo
except ImportError:
    raise ImportError
def log(message, label=None):
import indigo_attachments
    raise ImportError
ImportError
Scripting Indigo Plugins
Method Description
Plugin actions may return a value (a Python "primitive") when you call the executeAction method, but they are not required to. The return value can be any one of the following object types:
  • None None,
  • booleans bool,
  • integers int(),
  • floats float(),
  • strings str(),
  • Indigo Dicts indigo.Dict(),
  • Indigo Lists indigo.List().
Restart a Plugin
    airfoil_plugin.restart()
//Caveat//: For safety reasons, we do not provide the ability to enable a plugin that is disabled, or disable a plugin that is enabled.
Wait Until Done
if airfoilPlugin.isEnabled():
            'getSources',
            waitUntilDone=True
    except Exception as e:
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
          Item : (dict)
               icon : [SNIP]
