Indigo Overview
Object Definition
Here is the device dialog:
Device Dialog New Image
Device Dialog Z-Wave Image
Device Options
Triggers
Trigger Dialog Image
We'll look at each of the specific trigger types next, but first we'd like to point out a couple of other features. First, you'll notice that there are three tabs in the dialog: Trigger, Condition, and Actions. The first tab lets you define the trigger event. The second allows you to specify conditions which will be evaluated at runtime to determine whether the actions should be executed. See the #Conditions section for more information. Lastly, the Actions tab allows you to define the actions that this trigger will execute. See #Actions and Action Groups for more information.
Device State Changed
Variable Changed
Note-Wave Command Received Trigger Image](images/zwave_command_received_trigger.png)
Match Raw Packet
* 0x7D 0x84 0x07 *
INSTEON Command Received
X10/RF Command Received
Plugin Events
Schedules
Schedule Dialog Image
Time
Date
Other Options
Actions
Action Type Menu Image
Device Actions
Universal Controls
Universal Controls Menu Image
Light/Appliance Controls
Light Controls Menu Image
Sprinkler Controls
Sprinkler Action Image
Thermostat Controls
Fan Speed Controls
I/O Action Image
Virtual Device Controls
Brand Specific Controls
Brand Specific Controls Image
Insteon
HomeSeer
Inovelli
Zooz
Zooz Specific Actions Image
Server Actions
Script and File Actions
Execute Script
Execute Script Action Image
Open File
Open File Action Image
Email Event
Email Event Image
  • String Match in Email - use this option to trigger an event when an email is received that matches a particular string pattern you choose. Select "Edit Event Settings" to choose the Email device, match in Message Text, Message Subject, or Message From, and the string pattern to match. Note that this is an exact text match, so this trigger will only fire when the string matches the target text 100 percent.
  • Regex Pattern Match in Email - use this option to trigger an event when an email is received that matches a portion of the text pattern you choose. The match is done using a Regular Expression pattern match, which allows greater flexibility and the ability to match on a portion of the target text. Select "Edit Event Settings" to choose the Email device, match in Message Text, Message Subject, or Message From, and the regex pattern to match. For more information on regular expressions, visit https://www.regular-expressions.info/tutorial.html.
  • Server Connection Error - use this option to trigger an event when the connection to a specific email server is lost. Select "Edit Event Settings" to select the email device you want to monitor.
Indigo Server Startup
Power Failure
Interface Connection Failure
Z-Wave Command Received
Match Raw Packet
* 0x7D 0x84 0x07 *
Plugin Events
Schedules
Time
Date
Other Options
Actions
Device Actions
Universal Controls
Sprinkler Controls
Thermostat Controls
Fan Speed Controls
I/O Action Image
Insteon
HomeSeer
Inovelli
Zooz
Server Actions
Execute Script
Open File
This will open the specified file (full path using *nix slashes ("/")) using the default application. If it's the path to an application (e.g. "/Applications/TextEdit.app") then it will launch that app. You can also add command-line options and include markup that will do variable (%%v:VARIDHERE%%) and device state (%%d:DEVIDHERE:STATEIDHERE%%) substitutions. Noteon:getting_started&#individual_plugin_submenu) or from the plugin's detail page in the Plugin Store.
Reload Plugin Dialog Image
Get Contents of URL
Run Apple Shortcut
Run Shortcut Action Image
Variable Actions
Modify Variable
Modify Variable Action Image
Toggle Variable
Toggle Variable Action Image
Set Variable to Variable
Notification Actions
Send Email
Send Indigo Log Email
Z-Wave Actions
Run Shell Script
Run Shell Script Action Image
This will run the specified script file optionally with the output being inserted into the specified variable. The script must be marked executable and a valid shebang (#!/path/to/shell) must be specified at the top of the script. You can also add command-line options and include markup that will do variable (%%v:VARIDHERE%%) and device state (%%d:DEVIDHERE:STATEIDHERE%%) substitutions. NoteS that supports the Shortcuts app. The configuration dialog will present a list of all Shortcuts on the server machine as well as an input field to pass optional text to the selected shortcut when it's run.
Variable Actions
Modify Variable
Toggle Variable
Send Email
Z-Wave Actions
Notection to query an API and (optionally) save the results to an Indigo variable. For more details on this action type, refer to the Get Contents of URL Action page.
Run Apple Shortcut
Variable Actions
Modify Variable
Toggle Variable
Send Email
Z-Wave Actions
: if you're running a Python script you'll probably just want to use the Execute Script action since script files run from this plugin won't have access to the IOM (import indigo, which is Python-only).
Log Actions
Log Actions Type Menu Image
Write to Log
Write to Log Action Image
Email Event Log Data
Email Log Action Image
This action will send an email to the specified email addresses that contains the specified number of lines from the log file. This is useful for debugging problems (among other things). Tiple Action Image](images/insert_device_state_into_variable_action.png)
Toggle Variable
Send Email
Z-Wave Actions
Enable Type Menu Image
Get Contents of URL
Run Apple Shortcut
Variable Actions
Modify Variable
Toggle Variable
Send Email
Z-Wave Actions
Send Raw Z-Wave Command
Inclusion Mode Commands
Start Z-Wave Network Optimize
INSTEON Actions
Execute INSTEON Scene
Insteon Scene Action Image
Send Raw INSTEON Command
Insteon Raw Action Image
Action Options
Lower Action Dialog Image
Managing Multiple Actions
Multiple Actions List Image
*Important!* While you can order the actions in any order you like, Indigo will attempt to execute all actions in parallel. It's not always possible for various reasons, but that's the intent. If you want to order the execution, then you'll need to add delays which will delay the action's execution from the time of the event. So, if you have 3 actions and you want the first to execute immediately, the second to execute a minute after the event, and the third to execute two minutes after the event, then add a one minute delay to the second and a two minute delay after the third.
It is important to note that individual actions are run independently. If you need your actions to be executed in a specific order, you can use "Delay by" (see image). Very often, even short delays will be enough).
To create a new action group:
Action Group Dialog Image
Control Pages
Control Page Editor
Control Page Editor Image
Page Element Examples Image
  • iPhone/iPod touch
  • iPad
Other Editor Features
Page Element Details
Device State
Variable Value
Static Image/Caption
Refreshing Image URL
You can include markup that will do variable (%%v:VARIDHERE%%) and device state (%%d:DEVIDHERE:STATEIDHERE%%) substitutions as a part of a refreshing image URL. Note: file paths that contain spaces will need to have the spaces escaped with a backslash - /some\ path/that\ has/escaped\ spaces/. When you use substitutions in refreshing image URLs, you will receive a warning in the event log (when you edit the control page -- not each time the control page is displayed):
Server Status Text
Server Status Icon
Client Actions
Server Actions
Show in Browser
In the main Control Pages view in the Indigo Client UI, you can select a Control Page and then click on Show in Browser to view the page in your default browser. Once that's done, you can take note of the URL in your browser's address field should you want to copy it and create a bookmark or other link to load the page directly in the future. The direct URL will look something like, http:*my_indigo_ip:8176/web/controlpage.html?id=123456789 where *123456789// is the Indigo ID of the page.
Variables
Variable Window Image
Conditions
Conditions Tab Image
  2. if it's too cold outside
Sprinkler Condition Image
Complex Condition Rule Image
    "If dark"
The *return False* component is optional since only a *True* return will be acted upon.
