Indigo Web Server
Security Certificates
Advanced Web Server Settings
Select the Indigo 2024.2->Advanced Web Server Settings... menu item and you'll get this dialog:
The menu has three options:
Web Assets Folder Structure
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/images
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/plugins
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/public
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/static
As a convenience, you can access these folders under the Indigo Help menu: Help --> Show Web Assets Folder
images folder
plugins folder
public folder
This directory can be used to publish files from the Indigo Web Server that will be made available to anyone *without any authentication*. If someone knows the URL of your reflector, they will have access to any files that are in this directory, so use it wisely.
For example:
static folder
This directory can be used to publish files from the Indigo Web Server that will be made available to anyone *with authentication*. If someone knows the URL of your reflector, they will have access to any files that are in this directory once they have entered the appropriate authentication credentials for your reflector.
For example:
Authentication
API Keys
Local Secrets
In addition to authentication via API Keys and the Indigo Reflector (recommended), users can create their own local secrets (another type of key) that don't require an internet connection to validate. Users can create a JSON list of their own "secrets" that will be loaded whenever the web server is restarted. The secrets file is located in the install folder's /Preferences directory and is named //secrets.json//:
    "here-is-a-key",
    "this*is*another*key"
Additionally, if the user wants to completely disable API Keys, they may add the string "do-not-use-api-keys" to their list of secrets.
    "here-is-a-key",
    "this*is*another*key",
The effect would be the same as unchecking the "Enable OAuth and API Key authentication" checkbox in the Start Local Server dialog, but with different logging when an authentication try fails. While valid, this configuration is not recommended; instead, users should use the OAuth setting when the server is first started (to avoid confusion).
*http:*localhost:8176/v2/api/indigo.devices/123456789?api-key=my-local-secret//
Custom Web Page Example
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8">
  </head>
      Hello world.
    </div>
  </body>
</html>
Using a plain text editor, save this code as index.html within the .../Web Assets/static folder (to serve it with authentication) or within the .../Web Assets/public folder (to serve it without authentication). You can refer to assets located in other folders by referencing them with the Web Assets folder as the root.
